| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2012 2SS Black on Black Join Date: May 2010
check engine light with k&n cai
I am planning to get a k&n cold air intake.. I just want to know if it will in any way set off the check engine light and if it does how do you fix it. thanks
![]() ![]() ![]() Drives: 2010 IBM Camaro SS Join Date: Jun 2007
IF it does, the fix is a tune, which IMO isnt a good fix. There is a post on the forum someplace from Janetty Racing that did a test on several CAI and I believe it indicates which ones need a tune and which ones do not.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
![]() Drives: 2011 IBM 2SS/RS LS3 Join Date: Jun 2010
I put a K&N on mine right after the break in period. I am approaching 5,000 miles and it has not thrown a single code or light. I kept all of the stock pieces and boxed them up in the K&N box. If there ever became an issue that I believed the K&N caused, I would simply pull it off and reinstall the factory equipment. I fuse pull and the computer system should take care of everything else. By the way I love my K&N its a good product.
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
No, it won't cause a CEL unless, as any other CAI, it is not installed correctly. Ensure you follow the instructions, get a good seal on all connections, and enjoy it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Thick Skin or GTFO Join Date: Jun 2009
Like USA1 said, no way, Jose!
I've had mine for probably 3000 miles and nothing. You'd have to mess up the MAF but then I don't think the car would even start.
#6 |
![]() Drives: 2010 Silver Ice Metallic Camaro LS Join Date: Feb 2010
Had mine for awhile now, no problems. Just make sure you disconnect the battery like it says in the instructions.
#7 |
Banned
Ughh! i dont want to disconnect the battery.
can i just pull the fuse(s)? |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
Battery disconnect takes 2 minutes. You just have to take the negative side off...
#9 |
Do the battery DC. It literally takes one minute. And you don't lose any settings whatsoever. Your compass will need to be reset but that does it by itself when you start driving.
#10 |
Camaros Of Northwest Ohio
Drives: 2010 IOM 1LT, 1974 Corvette Join Date: May 2010
I just installed the K&N Typhoon last weekend. No CEL. Disconnected battery, all settings intact but I did need to re-index my driver window.
Camaros Of Northwest Ohio is on Facebook!
http://www.facebook.com/#!/pages/Nor...93610744003149 |
#11 |
Banned
okay! fine. i just didnt want to take out my sub to get to the battery >.<
#12 |
I put a K&N in my car today and I drove around all day with nothing wrong but maybe like 5 hours later the check engine light came on. I had the dealership put it in and I thought that maybe they didn't disconnect the battery so I did that and checked all the fittings and cycled the car and the light is still on. Any ideas?
2010 V6 |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Camaro Convt RS,2011 Camaro RS Join Date: Mar 2009
I installed mine no problems with it so far been two weeks.
![]() TEAM LLT 1992 Camaro Rs Convertible ![]() 2011 Camaro 1lt Rs ![]() |
#14 | |
TEAM L99 RIP Betty 2010 Camaro LS PLEASE EXCUSE MY SPELLING ON THE FORUM I DO NOT USE SPELL CHECK AND MY IPHONE HAS A MIND OF ITS OWN. |
#15 |
![]() ![]() Drives: 2010 2SS RS M6 Join Date: Mar 2011
I installed a K&N Typhoon last evening. All went well and it looks and sounds great. I drove it around our neighborhood a little afterwards and, WOW, could I ever feel the difference in the butt dyno at times and it roared like a lion!
I've put CAI's on before and didn't disconnect the neg battery and didn't last evening either. Drove the 26 miles to work (secondary roads and highway) and, at least so far, no CEL. I have heard on this forum of instances where the K&N Aircharger has thrown one but I don't know why that model may be any more prone to doing so than the Typhoon, which I haven't heard doing it to anyones car. |
#16 |
E85 ethanol tuned
i have the K&N aircharger and have had it installed for like 5-6 months/ atleast 7k miles and have never had a problem or CEL. dont get why some get CEL some dont
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
The Hunter, if you're unable to get your CEL to go away on it's own I would suggest at least contacting your dealer to see if they would be willing to take a look at the vehicle to make sure the installation was done correctly. I hope that helps you.
Jeff Morris, Chevrolet Customer Service |
| Thread Tools | |
| Check Engine Light | VALOR | 5th Gen Camaro SS LS LT General Discussions | 13 | 06-01-2010 12:48 PM |
| Check Engine Light Codes | Kjhallex | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 04-17-2010 04:55 PM |
| Need help with check engine light | fontenl | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 04-15-2010 08:04 AM |
| Pfadt Race Engineering releases new Camaro V8 Engine Mounts | PfadtRacing | Suspension / Brakes / Chassis | 6 | 01-15-2010 12:58 PM |
| Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 236 | 04-22-2008 12:43 AM |
