SDTW Custom Wheels & Tires
Old 07-09-2010, 06:52 PM   #1
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
Do I want a Hurst short throw?
Finally putting my order together: Yellow 2SS/RS with a manual trans. Been waiting a year for HUD
My question: I've driven stick trucks and semis all my life but never a muscle car, so i don't know what a "short throw" shifter feels like. Is the shift pattern just closer together as the name implies? If that's the case, should i go with the standard shifter in the camaro since i'm used to trucks with long "throws"?
John Deere Boy is offline   Reply With Quote
Old 07-09-2010, 07:11 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Yes....you'll want some kind of short throw shifter. The Hurst may or may not be the right one for you.
Unless you just have to have it from the factory I wouldn't order it from GM. You can add it as an aftermarket cheaper and you won't necessarily have to wait. Things may have changed but those that tried to order a 2010 with a Hurst got their build put off because they weren't actually putting them in at GM. Everyone typically cancelled their order for the Hurst in order to get their car. Things may have changed but I haven't heard of anyone taking possession of a Camaro with a factory installed Hurst.
So....do your research on which short thorw to buy. There is Hurst, MGW, Barton, MTI. I had a Hurst and didn't like it. I went with MGW and the Race Knob and LOVE it. Alot of people like the Hurst though. There are alot of people that like the Barton as well.
Again....just keep researching but I wouldn't recommend ordering through GM right now.
To me the short throw shifter is a MUST HAVE and I haven't heard of anyone that put on a short throw that went back to the factory shifter.
This isn't going to be like shifting a truck so I wouldn't compare that at all. Your elbow is more than likely going to be on the center console.....unlike your truck.
Build Journal
Old 07-09-2010, 07:14 PM   #3
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
all true
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 07-09-2010, 07:17 PM   #4
John Deere Boy
I bleed green
Thanks that's very good info. I'll definitely NOT put it on my order, and get an aftermarket later if i want.
Old 07-09-2010, 07:38 PM   #5
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
YES!
Old 07-09-2010, 07:40 PM   #6
Thrillz
Thrillz's Avatar
Drives: 2012 Charger R/T / 2012 Dodge Ram
Listen to this man he knows what he's talking about. No way i could ever go back to the factory one after having the short throw for several months now.
Quote of the year, from 6.1hemi:
"I just wanted to type some junk cause I am having some beers and I really like cars."
Thrillz is offline   Reply With Quote
Old 07-09-2010, 07:51 PM   #7
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Get the Hurst from the factory. Unless Hurst changed their design, the one they deliver to GM has been modified to meet OEM specifications.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 07-09-2010, 07:51 PM   #8
FB3
FB3's Avatar
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP
You should definitely consider the MGW shifter. Do some searches here to find out why. High quality, no noise, and a total shifter replacement. I just got one and hope to have it installed this week or next week.
Experience is the best teacher but the tuition is very high.
FB3 is offline   Reply With Quote
Old 07-09-2010, 07:53 PM   #9
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
agree on the MGW...a Real nice piece of craftmenship..a true short throw..
Capthowdy is offline   Reply With Quote
Old 07-09-2010, 09:17 PM   #10
caverman
caverman's Avatar
You'll love it! It's ever so slightly tight at first but it was designed that way. Give it about 150 miles to break in. Once you do you'll kick yourself for not getting in the car sooner.
Which knob did you get?
x10 for the MGW
Build Journal
Old 07-09-2010, 09:22 PM   #11
jackka
jackka's Avatar
Drives: 2011 Black/Black 2LT/RS M6 w/Sroof
Location: FT. Rucker, Alabama, the home of Army Aviation!
the Barton short-throw shifter also is very good stuff. and a lot cheaper also.
jackka is offline   Reply With Quote
Old 07-09-2010, 09:28 PM   #12
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I had the hurst and replaced it with the Barton. Installed the MGW in a few cars. It is a good shifter. The problem I have with it is it is a housing held together by pins and set screws. Great to begin with then loosens as the unit gets broken-in. The GM main structure is cast and the Barton unit that fits in will not change under environmental conditions. IMHO !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 07-09-2010, 09:41 PM   #13
lee
lee's Avatar
Drives: 2010 2ss/rs
isnt the hurst the one that "clicks" every time you change gears? i wouldnt like it making that noise every time i switch gears
lee is offline   Reply With Quote
Old 07-09-2010, 09:52 PM   #14
FB3
FB3's Avatar
Caverman, I am going to keep the stock shift knob. I was thinking of the round retro ball, but I really like the stock one.
Which Short throw Recommended??? naga V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 07-24-2010 10:19 PM
If you installed MGW short throw: Infern0 Transmission / Driveline 14 03-07-2010 11:22 PM
short throw shifter sidewzz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 02-21-2010 09:40 PM
Just Installed My Hurst Short Throw Shifter Blueclyde V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 02-17-2010 08:47 PM
Phastek Performance - Hurst TRUE Short Throw Shifters!! Sean@Phastek Transmission / Driveline 3 02-15-2010 10:33 AM
