Solo Performance
Old 07-09-2010, 07:58 PM   #1
Tom
Drives: 2010 SS Red Jewel 6 spd manual
Oil Pan Drain Plug Torque
For those of us that like to change our own oil... anybody know what the torque is for the pan drain plug?
THANKS
Tom is offline   Reply With Quote
Old 07-09-2010, 08:05 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
http://www.camaro5.com/forums/showthread.php?t=53422
18lbs
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-09-2010, 09:11 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
I just put it on as tight as I can by hand with a socket. I've never torqued the drain plug on any of my cars. Never had an issue either.
I doubt the dealership pulls out the torque wrench when they do it.
Build Journal
Old 07-09-2010, 09:17 PM   #4
faninc
Drives: 2010 Camaro RS in SIM
Lucky if a dealer uses the right socket size...on the drain plug. LOL
Just make it very snug hand tight with ratchet, no need to really tighten it down too strong, the rubber insert bushing takes up any gap.
faninc is offline   Reply With Quote
Old 07-09-2010, 09:27 PM   #5
Huck1974
Drives: 2011 2SS
torque the drain plug?
Huck1974 is offline   Reply With Quote
Old 07-09-2010, 09:56 PM   #6
FB3
FB3's Avatar
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP
I use the Fomoto quick drain on my Camaro. Also put one on me C6 Corvette and my GXP. Really makes draining the oil easy. As far as torque goes, I really don't know, but I am sure that there is a torque value for the plug somewhere.
Experience is the best teacher but the tuition is very high.
FB3 is offline   Reply With Quote
Old 07-09-2010, 10:16 PM   #7
rmnc3r
Drives: me up the wall.
Yep, TFAR - 'That Feels About Right' is as 'bout as torquey as I get.
rmnc3r is offline   Reply With Quote
Old 07-09-2010, 10:40 PM   #8
Huck1974
Drives: 2011 2SS
I was poking fun at him a bit.
Old 07-09-2010, 10:45 PM   #9
mikel441
mikel441's Avatar
Drives: 2014 Sonic, 2010 Camaro SS
Hand tighten with a box end wrench. Should be plenty of torque on the drain plug.
mikel441 is offline   Reply With Quote
Old 07-10-2010, 11:56 AM   #10
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
Do you work for the dealer and not have the correct socket size
Oldrocker is offline   Reply With Quote
Old 07-13-2010, 06:43 PM   #11
rmnc3r
Yeah, so wuz I.
Old 07-15-2010, 01:58 AM   #12
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
18 lbs-ft just to be safe.
jagan323 is offline   Reply With Quote
Old 07-15-2010, 09:04 AM   #13
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
+1
Old 06-01-2012, 09:21 PM   #14
sherryathomas
Drives: 2010 Camaro RS/SS Black
has anybody heard about the oil filter adaptor bolts being broken, and the oil pan being replaced under warranty on a 2010 rs/ss
sherryathomas is offline   Reply With Quote
GOLD PLUG magnetic oil pan drain plug strobi Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 44 03-29-2012 03:09 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
Torque spec for the Oil pan drain bolt? AWS-GTAW Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 03-21-2010 09:23 PM
