Old 11-06-2008, 10:26 PM   #1
CaptianSam
Car Garage
CaptianSam's Avatar
Drives: 350z,A4,SRT8...see sig
heres a question
why are the rear rotos bigger than the fronts...
there cant be too many cars like this... if any at all...
i know the rears will be thinner... but wouldnt bigger rear brakes make for more...uhh rear slide i guess...??
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes
Yes I Supercharge Everything
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC
Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707
New Autos:2012CamaroSSRS,09ChallengerSRT8
Past Autos:....too many to list
"i told you it was gettin' an LS3"
Go down deep enough into anything and you will find mathematics. Dean Schlicter
B.Sc. Hons. Mathematics
CaptianSam is offline   Reply With Quote
Old 11-06-2008, 10:28 PM   #2
TheClassicCarKid
TheClassicCarKid's Avatar
Drives: V45
Didn't know they were. Good question
All of the stang guys in one thread..wow..lol
TheClassicCarKid is offline   Reply With Quote
Old 11-06-2008, 10:31 PM   #3
CaptianSam
Car Garage
CaptianSam's Avatar
my guess is because the rear tire is fatter but it dtill doesnt make sense to me... on my 350 the fronts were 255 and the rear were 285 and the front rotors were still 14 and the rears were like 12.4
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 11-06-2008, 10:32 PM   #4
RallyFever
Senior Member
RallyFever's Avatar
Drives: 2010 Camaro 2SS
Corvette is the same way, however, the rear wheels are an inch larger as well.
RallyFever is offline   Reply With Quote
Old 11-06-2008, 10:40 PM   #5
EU4IC
Drives: 1995 Chevrolet Impala SS
Send a message via AIM to EU4IC
Maybe since the tires being an inch bigger calls for an inch bigger rotor?
Or maybe the bigger rotors give more surface area for the pads to press on..
more surface area=more friction
more friction=faster breaking
EU4IC is offline   Reply With Quote
Old 11-06-2008, 10:46 PM   #6
CaptianSam
Car Garage
CaptianSam's Avatar
dude... bigger tires in the rear were on the corvette
not the camaro ...
and friction = heat... more friction more heat the idea is to limit heat while maintaining prolonged useful stopping distance (ie racing)
the camaro has 20's all around
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 11-06-2008, 10:50 PM   #7
EU4IC
dude
More surface area would also help spread the heat out so it wouldn't be as concentrated in one spot. You asked the question.. I gave my idea.
Old 11-06-2008, 10:53 PM   #8
CaptianSam
Car Garage
CaptianSam's Avatar
well that clearly goes against every physical science law
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 11-06-2008, 10:54 PM   #9
CaptianSam
Car Garage
CaptianSam's Avatar
either way thats not the point... the point is why is there a bigger rotor in the back than the front... on every other car its the other way around
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 11-07-2008, 01:58 AM   #10
divvichild
Corvette Owner
divvichild's Avatar
Drives: '06 MS Corvette Coupe
Ok, they are the same diameter but different width's. The fronts are smaller than the backs. This is to give better handing control. Less area touching the ground means less friction to overcome when turning. The opposite is the case for the rear. Wider tire means more friction which means more traction to handle all that power!!
divvichild is offline   Reply With Quote
Old 11-07-2008, 02:29 AM   #11
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
No they're not. The fronts are 14" diameter, the rears are 14.4".
If you look at the rotors themselves, there is less actual swept area on rotor by the caliper. Brake bias is tuned in the hydraulics anyways.
Anyhow, I'm pretty sure the rear rotor is larger to incorporate the parking brake assembly, which I believe on the CTS-V (the Camaro looks to be getting that setup) was inside the rotor hat. I can assure you it has nothing to do with tire width. Don't believe me? Look at the C6Z.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 11-07-2008, 06:23 AM   #12
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Do you like the way it looks???? Good, thats why. Its purely for appearance. Thats a quote from GM at Indy.
Old 11-07-2008, 06:55 AM   #13
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
GM needlessly gave themselves more engineering costs for a larger rear brake rotor for looks? I doubt it.
Old 11-07-2008, 08:38 AM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I doubt you are going to tell the .4 difference in the rear. Why did GM do this? Who knows, but I doubt it will affect stopping performance one way or another ..
Crowley
Crowley is offline   Reply With Quote
gauge question and video jordan 572 5th Gen Camaro SS LS LT General Discussions 1 10-21-2008 10:32 PM
Interior Question Aaron1121 5th Gen Camaro SS LS LT General Discussions 5 10-21-2008 05:00 PM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 09:26 PM
