BeckyD @ James Martin Chevy
Old 08-03-2010, 08:23 PM   #15
fiero
LOVES AMERICA
fiero's Avatar
Drives: 2010 Camaro 2LT, 1986 Fiero SE
Would these hoods still be effective with another CAI besides the AIRAID? I know some intakes draw from the same location as the stock snorkel, and then the Injen draws from all the way down by the wheel- would one of these still get any more airflow down there?
Drive what you love, Love what you drive!
fiero is offline   Reply With Quote
Old 08-03-2010, 08:47 PM   #16
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
it would be interesting to see someone put a ram air hood/intake on there like the Firehawks.
http://www.highperformancepontiac.co.../photo_02.html
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 08-04-2010, 11:57 AM   #17
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
With Dragom's hood, he has the Airaid and the way its set up, he gets a fresh/cold air dump from the top. The way the hood is made, air coming in from the scoop flows right to the Airaid box so the filter is getting that air from the top and he's getting the ram air from the tube at the bottom. His only issue is that the hood doesn't come with the inner liner as stock so this prevented him from getting the seal the Airaid design uses with that setup. I suggested he get some foam pipe insulation which he did and this closed off the inside of the box once the aftermarket hood is closed. He says he loves it!
Never grow up, it's a trap!
chozn4service is online now   Reply With Quote
Old 08-05-2010, 01:06 PM   #18
2LT-RS
Drives: IBM 2LT RS
Originally Posted by chozn4service View Post
With Dragom's hood, he has the Airaid and the way its set up, he gets a fresh/cold air dump from the top. The way the hood is made, air coming in from the scoop flows right to the Airaid box so the filter is getting that air from the top and he's getting the ram air from the tube at the bottom. His only issue is that the hood doesn't come with the inner liner as stock so this prevented him from getting the seal the Airaid design uses with that setup. I suggested he get some foam pipe insulation which he did and this closed off the inside of the box once the aftermarket hood is closed. He says he loveggs it!
Couldn't we just use the foam liner from the stock hood and simply cut out the hole where the fresh air comes in?
2LT-RS is offline   Reply With Quote
Old 08-05-2010, 01:50 PM   #19
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Originally Posted by asmith10 View Post
Hmm well how would we go about putting stripes on then besides having them painted on?
i think paint is really your only option.
Old 08-17-2010, 08:57 AM   #20
x626xBlack
ARMY of one.
x626xBlack's Avatar
Drives: 2011 Black SS/RS
I had a 98 TA I Ram Aired with a Sun Coast Creations hood, and a 2002 WS-6 RAM Air....
Why would you want to channel the air to a side mounted intake? Does that not defeat the purpose of the Ram Air? It creates a restriction of air flow..... I see even the SC hood for the 5th gen is side discharge.
There is no water issue on the 4th gen Ram-Air, Both my Raptor hood and the OEM GM W-S6 hoods has baffles to keep water out.
SC Hood- 5th gen
http://suncoastramairhoods.com/2010-...ood-21018.html
Intake Box for 4th Gen
http://suncoastramairhoods.com/98-03...ood-28003.html
Or is it that there is just no room on the 5th gen for the air box in front?
x626xBlack is offline   Reply With Quote
Old 08-17-2010, 10:19 AM   #21
asmith10
Drives: Camaro 2LT/RS IBM
Even if it won't be a complete ram air system, the hood does an excellent job of extracting heat from the engine compartment, and supplies ample amounts of cold air to the intake correct? The air coming through that hood should be much colder than the air you would get from the Injen IMO, and also has the benefit of a short ram air intake with the advantage of a true cold air intake.
asmith10 is offline   Reply With Quote
Old 08-17-2010, 11:51 AM   #22
x626xBlack
ARMY of one.
x626xBlack's Avatar
I find no fault with that notion at all.... However when you compare a "possible 6-10 hp gain with the price tag of around 2100 bucks.... See where I am going with this?
Where I got 2100
Hood 900-1000 Plus 100 Taxes, plus 100 or so for shipping + 300-400 to have it painted (they arrive in gelcoat and need to be sanded and painted and fit), CAI 400 +tax...
Your looking at $200 + per 1 hp
Old 08-17-2010, 12:26 PM   #23
asmith10
I completed understand your view point on that, and I agree but I am also doing this for the aesthetic aspect of it as well. You have to admit its a pretty damn good looking Hood.
Old 08-17-2010, 01:04 PM   #24
x626xBlack
ARMY of one.
x626xBlack's Avatar
What part of Louisiana? Abbeville originally for me...
I am sure I will get some flack.. I have always preferred the TA look... This was my 98 TA with a SCC Ram Air hood. That hood made that car look like a beast...
http://www.camaro5.com/forums/showpo...6&postcount=22
In opinion.. and it is just an opinion... The Camaro hoods are a little too boxy for me..
Old 08-17-2010, 01:07 PM   #25
x626xBlack
ARMY of one.
x626xBlack's Avatar
The SCC hood looks a little softer in the angles... Has more roll to it, which I like.
Old 08-17-2010, 06:59 PM   #26
Primus
2G1FF1EV0A9113319
Primus's Avatar
Not a fan of the double mailslot. Would look nice with a V6 front though.
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Old 08-17-2010, 09:57 PM   #27
Wizzer
Drives: 2010 Cyber Grey
Wow nice pic. When I look at that i can just picture an evil red or white light in there for shows. We meet at night out here in ga due to the heat and I would love to get that hood. Thx for the picture.
Wizzer is offline   Reply With Quote
Old 08-18-2010, 07:32 AM   #28
x626xBlack
ARMY of one.
x626xBlack's Avatar
I actually prefer the break up the mail slot provides.... . With out the MS the front end has no flow and looks bland... un attractive IMHO.... The top picture in the OP with the MB delete and the stripes looks pretty good... I just need something to break it all up.
But then again the hood in the top picture also has side walls and the scoop is actually farther back..
SFX hood with MS Delete
SFX hood with out MB Delete. ( much prefer this one)
K&N AirCharger and Typhoon System | Best Prices | Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 175 09-04-2012 03:40 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Why no aftermarket Ram Air Hood? buster6070 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 07-03-2009 04:39 PM
ram air style hood? tsg1391 Cosmetics and Lighting Modification Discussions 1 10-23-2008 05:43 PM
