Nickey Chicago
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 07-11-2010, 01:45 PM   #1
Apex Chase
Apex Chase's Avatar
Drives: it like I stole it.
Talking Looking for more traction? I recommend Pfadt Rear Trailing Arms!
As 5th Generation Camaro owners push the performance envelope further and further, here at Apex Motorsports we receive more and more questions about how they can increase traction and strength while reducing weight. We recommend checking out the Rear Trailing Arms from Pfadt Race Engineering.
The Pfadt 2010 Camaro Rear Trailing Arms were developed using the latest analysis software which enabled Pfadt to increase strength by 106% while simultaneously reducing mass by 17%. The decrease in trailing arm mass allows the suspension to react more quickly to the changing road surface keeping the tire in contact with the road to increase traction. Through further analysis and testing Pfadt was able to achieve a 32% reduction in deflection which helps decrease wheel hop and increase traction even further.
Included with this kit is Pfadt's leading edge Trailing Arm Bushing Kit. Utilizing lightweight 6061-T6 aluminum sleeves that are hard anodized to create incredible surface hardness and microscopic pores to hold Pfadt's special grease. These sleeves are then Teflon coated to further reduce friction.
This is then coupled with Pfadt graphite impregnated polyurethane bushings which uses deep grease grooves to hold and continuously re-lubricate the surfaces for long and quiet operation. The result is an ultra lightweight, ultra-low friction joint that is 42% lighter than the OE bushing and more durable then ever before. This kit includes the bushing for both the trailing arm and also the upright for a complete performance trailing arm upgrade.
The final arm is the result of four stages of precision manufacturing; CNC machining of the bushing housing, laser cutting of the intricate panels, CNC bending and TIG welding to finish the assembly. All of this is accomplished right here in the USA. :flag1:
STOCK
PFADT
Here is a good article from GM High-Tech Performance Magazine with lots of information including the installation.
Apex Chase is offline   Reply With Quote
Old 07-11-2010, 03:02 PM   #2
1badtie
1badtie's Avatar
Drives: 2010 camaro 2ss rs
last time i ran at the track all of first gear was bad wheel hop it feels like im damaging my car when it does that ive been looking into these alot they seem like a good investment...
1badtie is offline   Reply With Quote
Old 07-12-2010, 07:35 PM   #3
Apex Chase
Apex Chase's Avatar
That is exactly what these rear trailing arms were designed for.
Old 07-13-2010, 12:07 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I like that strength has increased and weight decreased. There's some serious engineering there
These performed well in a magazine test from a few months ago too
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 07-13-2010, 01:12 PM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Is this the magazine article you are referencing?
GM High Tech
They had bent trailing arms from street use, and documented what they did to fix it (using Pfadt)!
Old 07-13-2010, 01:33 PM   #6
PfadtRacing
Originally Posted by Apex Chase View Post
As 5th Generation Camaro owners progressively push the performance envelope further and further, here at Apex Motorsports we receive more and more questions about how they can increase traction and strength while reducing weight. We recommend checking out the Rear Trailing Arms from Pfadt Race Engineering.
STOCK
PFADT
Thanks for posting this up! We appreciate the support!
Old 07-13-2010, 01:36 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
GM High Tech
BINGO
Old 07-13-2010, 04:49 PM   #8
Apex Chase
Apex Chase's Avatar
GM High Tech
Thats a good article, thanks for bringing it up radz.
Old 07-13-2010, 04:56 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That is the only magazine (okay - on of only like three) that I give any credit to. Also, that was a kickass article. They know how to drive and what they're doing, so I trust the information. If they say it works - it does KUDOs to you for the topic and Pfadt for the product.
Old 07-14-2010, 06:12 PM   #10
Apex Chase
Apex Chase's Avatar
I agree, they put out a very good publication. Thanks for the props!
Old 07-15-2010, 06:16 AM   #11
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
estimated cost for a pair?
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 07-15-2010, 07:36 AM   #12
Apex Chase
Apex Chase's Avatar
They go for $235 shipped!
Old 07-15-2010, 02:10 PM   #13
Apex Chase
Apex Chase's Avatar
No problem, thanks for the excellent products and support on your end as well!
Old 07-17-2010, 05:29 PM   #14
Apex Chase
Apex Chase's Avatar
Can't ask for much more than stronger and lighter. Pfadt engineering is world class.
apex, pfadt, rear trailing arms, suspension
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 138 05-09-2013 03:58 PM
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! Apex Chase Transmission / Driveline 5 08-10-2010 05:49 PM
Pfadt Sway Bar Comparisons PfadtRacing Suspension / Brakes / Chassis 21 07-23-2010 02:51 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 09:17 PM
Pfadt Carbon Rear Trailing Arms and Rear Tie Rods PfadtRacing Suspension / Brakes / Chassis 20 10-18-2009 09:46 AM
