Old 07-11-2010, 11:32 PM   #1
BMR Suspension
Drives: 2016 Camaro 2SS
Talking BMR Launches New Product - Rear Cradle/Diff Bushing Kit - Street Version (BK020)
BMR Fabrication
Rear Cradle/Differential Bushing Kit for 2010 Camaro (Street Version)
Minimize wheel-hop and reduce rear cradle movement in your 2010 Camaro with a Rear Cradle/Differential Bushing Kit from BMR Fabrication. Manufactured from low-deflection polyurethane, this kit includes the BMR “street version” differential bushing kit (BK001) and rear cradle insert bushings (BK016). The BMR Rear Cradle/Differential Bushing Kit (BK020) minimizes rear cradle movement and provides additional rigidity for the differential which ensures maximum power transmission to the wheels. The rear cradle insert bushings install inside the air gaps of the stock rubber bushings without removing the rear cradle from the vehicle for an easy installation. The differential bushings are made from 68 durometer polyurethane to allow more consistent launches and better handling without significantly increasing noise, vibration, or harmonics.
BMR is running an Introductory Sale on ALL Camaro bushing kits. CLICK HERE for details
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
BMR Suspension is offline
Old 07-12-2010, 06:59 AM   #2
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
In case you guys are wondering, we don't launch new products without having sufficient inventory on hand. Not only do we have hundreds of each part number ready to ship but the pricing is much better than other options out there.
BMR guy is offline
Old 07-12-2010, 10:19 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is BK024 a complete rear cradle bushing kit? It looks like it, but I just wanted to verify.
Thanks
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
radz28 is offline
Old 07-12-2010, 03:56 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks
The BK024 rear cradle bushing kit is the full kit that uses our BMR pro differential bushings which are a bit higher durometer then the street differential buhings.
Correction: I just realized I confused our BK024 pro rear cradle bushings with our BK029 pro differential bushings. The BK024 is a complete cradle kit that uses cradle bushings as opposed to just cradle bushing inserts. hope this clarifies it a bit more.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
BMR Sales is offline
Old 07-12-2010, 04:03 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Sweet. Thanks.
radz28 is offline
Old 07-14-2010, 02:08 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
how hard are these things to install
olblue75 is offline
Old 07-14-2010, 02:34 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The Differential bushings are a bit of bear to install, but the cradle bushings are pretty easy as long as you have the tools to do it. The cradle has to be lowered enough to slide the insert of the top of the stock cradle bushings, then the insert has to be slid in the bottom of the stck cradle bushing. Once all that is done the cradle has to be bolted back into place.
T.C. Davis
813-986-9302
Old 07-14-2010, 02:49 PM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
The inserts are really very simple. You basically just lower the exhaust, remove the 4 main cradle bolts and lower the cradle about 3 inches. The inserts install into the voids of the OE rubber bushings, making the bushings essentially solid poly/rubber. There is a little more to it but you can view a more detailed set of instructions HERE if you are interested in the procedure.
The differential bushings are not near as easy, mostly due to the press fit of the bushing into the differential. For this install you must lower the differential and hole saw the OE bushing out, then pry the bushing shell out of the differential. Again, if you are interested in more details, check HERE for complete installation instructions.
We also have lots of other bushings available for your 2010 Camaro. To check them out, visit our website at: http://www.bmrfabrication.com/F5.htm
BMR guy is offline
Old 07-14-2010, 06:43 PM   #9
oachalon
Drives: 2010 Camaro 1SS
BMR, i notice that you offer both rear cradle bushings street (inserts) and full replacements (pro). At what point do you believe you would upgrade to pro or use pro to begin with. I am in the process of thing adding an e-force supercharger to my car, and what to tighten the suspension a little.
I know pedders recommends anything over 500rwhp you should upgrade to their solid bushings and not the inserts.
oachalon is offline
Old 07-15-2010, 10:20 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
With the addition of the supercharger I would definitely do the BMR full replacement bushings (pro). With that kind of power controlling the movement in the rear suspension is key and the pro cradle bushings do that the best.
T.C. Davis
813-986-9302
Old 07-16-2010, 10:41 AM   #11
BMR Suspension
There has been a little bit of confusion regarding differential and rear cradle bushing kits. Here is a little bit of extra info. I hope this clears up any confusion.
BK001 - This is the street version of our differential bushings. These bushings have a 68 durometer. This part number does not include rear cradle bushings.
BK016 - This is the street version of our rear cradle bushings. These are inserts only. This part number does not include differential bushings.
BK020 - This is a combo kit that includes BK001 and BK016. There is a $20 discount if you buy the combo kit.
BK029 - This is the Pro version of our differential bushings. These bushings have a 95 durometer. This part number does not include rear cradle bushings.
BK024 - This is the Pro version of our rear cradle bushings. These are complete bushings, so the stock rubber bushings must be removed before installation. This part number does not include differential bushings.
BK030 - This is the combo kit that includes BK029 and BK024. There is a $20 discount if you buy the combo kit.
Old 07-27-2010, 02:31 PM   #12
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Don't miss out - 20% off these kits until August 8th!
BMR guy is offline
Old 08-17-2010, 01:49 AM   #13
vanquisheder
Drives: 2010 Camaro 2SS/RS
I missed the discount but If I find the installation instructions for the suspension bushings easy to follow, I'm definitely going to order the kit.
vanquisheder is offline
Old 08-17-2010, 02:07 AM   #14
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Oops......missed this one completely.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up PfadtRacing Suspension / Brakes / Chassis 9 01-28-2014 08:15 PM
BMR Rear Trailing Arms, Tie Rods, Bushings, and More! | FREE Shipping!! AJ@ECSMotorsports Suspension / Chassis / Brakes 19 11-13-2010 04:55 PM
BMR Launches New Product - G8/2010 Camaro Adjustable Toe Rods (TR003) BMR Suspension Suspension / Brakes / Chassis 0 04-12-2010 06:37 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 01:14 AM
