JUICEDMOTORSPORTS
Old 07-11-2010, 11:43 PM   #1
mbspeed
mbspeed's Avatar
Drives: 2015 CAMARO SS LS3
skip shift ???
Hi all i have the LS3 ss and keep reading about skip shift is this on all LS3 Camaro s i put about 900 miles on car and not had to go from 1st to 4 th am i missing something dont see any shift light on dash
mbspeed is offline   Reply With Quote
Old 07-11-2010, 11:59 PM   #2
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
You are probably keeping the RPM's high enough before shifting out of 1st that it doesn't get triggered.
Sterling is offline   Reply With Quote
Old 07-12-2010, 02:29 AM   #3
mbspeed
mbspeed's Avatar
ok i am going to try to activate it just to see how it works thanks for the info
Old 07-12-2010, 04:58 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
It activates when:
● the transmission is in 1st gear
● you are applying 35% throttle or less
● the vehicle is traveling between 15 and 21 mph
● engine coolant temperature is greater than 171 F (77 C)
Old 07-13-2010, 10:19 PM   #5
mbspeed
mbspeed's Avatar
humm i cant make this work i guess i am lucky does a light come on in the dash and force the driver to go into 4 th or is it giving you the option to do so
Old 07-14-2010, 05:08 AM   #6
Apex Motorsports
There is no option, it locks you out of 2nd and 3rd. Looks like you are lucky, go buy some scratch offs!
Old 07-14-2010, 09:14 AM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I generally find it to be a non issue ... I keep the rpm up enough, or when turning and I know traffic is going to be slow I start it in 2nd ...
Old 07-20-2010, 05:03 PM   #8
Alpinestar750
Alpinestar750's Avatar
Drives: '10 SW 2SS/RS LS3
how easy is it to install the Apex SSE? any install pics?
Alpinestar750 is offline   Reply With Quote
Old 07-20-2010, 08:09 PM   #9
Apex Motorsports
Its a little too tight for good pics but there are a few floating around. Its very simple. All you have to due is unplug a wiring harness and place the Skip Shift Eliminator in line between the harness and the plug it was connected to. It takes longer to lift the car than it does to actually install it and it comes with directions.
Old 07-21-2010, 01:06 PM   #10
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
2 mins. super easy.
9/26/09 Took delivery!
Old 07-24-2010, 07:02 AM   #11
RipperFox
Grrr!!!
RipperFox's Avatar
Drives: BLK/IOM '11 2SS/RS
So you SSE is a fix for you basic daily driver? Someone like me that hotdogs all the time wouldn't incounter the CAG much?
Rules for ordering a car.
1. Dealers are liars
2. Buy off the lot
3. See rule #1
RipperFox is offline   Reply With Quote
Old 07-24-2010, 01:27 PM   #12
Apex Motorsports
It's a fix for anyone who doesn't want a computer deciding when you should be able to use what gear. There are people who say it doesn't bother them, but it really irritates a lot of people and for less than $20 it's a cheap fix.
Old 07-28-2010, 09:02 AM   #13
Blackfly
Blackfly's Avatar
Drives: 2002 Camaro SS/ 2011 Camaro SS
Ummm..I have yet to experience a lock-out of third gear in either of my SS's. I have trained my thought process to go to third gear in-case of lockout of 2nd. simple fix.
It is ALMOST a non-issue. If your "racing" your RPM's are above the requirements anyways. One should experience a forced skip-shift while granny shifting.
Even with my '02 M6 It was a non issue. I did tune it out on my 5th year of owning the '02.
It is, by far, a personal preference.
2002 Black/Black SS- Finally! 350RWHP!
2011 IOM Camaro 2SS
Automotive Blog- Cars, Fast cars and Faster Cars!
Blackfly is offline   Reply With Quote
Old 08-04-2010, 09:51 PM   #14
LoneCynic
LoneCynic's Avatar
Drives: 2015 BVM 1SS/1LE
I read about this occurrence in the car's manual. When exactly would a lockout occur? I don't race, It is merely my daily driver. So, if I am doing what I consider normal shifting (When the RPMs get up to about 2250) between gears, would I even ever encounter this? Why would you go directly from 1st to 4th? I don't entirely have a grasp of what this is if you couldn't tell already..
LoneCynic is offline   Reply With Quote
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 12 04-13-2018 08:32 AM
CAGS (aka: Skip Shift) Apex Motorsports 5th Gen Camaro SS LS LT General Discussions 108 06-25-2010 08:26 PM
Hurst Billet/Plus 2 Shifter $319.95, get Skip Shift Eliminator FREE! Apex Motorsports Transmission / Driveline 22 06-15-2010 09:55 AM
M6 Owners and Skip Shift Beware! DkknightX 5th Gen Camaro SS LS LT General Discussions 173 01-26-2010 04:14 PM
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 01:50 AM
