07-12-2010, 01:35 PM | #1 |
delete
delete
07-12-2010, 01:39 PM | #2 |
Drives: 2010 2SS Join Date: Jan 2010
I wash down with Dawn (dish washing liquid) takes all the wax off. Just don't let the car dry in the hot sun when claying, rinse it down when your done with a section.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged, Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera. |
07-12-2010, 02:03 PM | #3 |
Drives: The shiny ones. Join Date: Mar 2010
Wash
Clay Rewash Dry Polish Polish Polish Polish Polish Polish Polish (get my point) Wax or sealant If the paint isn't heavily contaminated you can go Wash Dry Clay Polish as needed Wax or sealant The only reason to do a secondary wash is to eliminate the possibility of swirls coming in from contaminants on the surface. This way will save time, but you add a level of risk so pick your routine accordingly. |
07-15-2010, 10:15 PM | #4 |
Drives: Corvette Join Date: Jul 2010
You can really do either.
Wiping the area down with a clean microfiber is fine, especially if you plan on following up with machine polishing, because any micro-scratches that might be a result of the microfiber wipe will be corrected by the polish stage.
Shawn
09-10-2010, 05:29 PM | #5 | |
Drives: 2010 Camaro 2SS - Black on Black Join Date: Aug 2010
So it is okay to clay an entire car while its still wet? In order words, after I do my first 2 bucket wash, I dont have to dry the car before claying? Since the car is black I am worried about water spots, although I realize I am going to wash the car again right after claying.. Also, should I expect the clay to remove the existing water spots I got from washing my car in the sun two weeks ago? If it doesnt remove them, should I use the vinegar/water mix or do you have a better method? Thanks in advance! |
09-10-2010, 05:33 PM | #6 |
Yes, you can clay while the finish is wet. You may end up using more lubrication as the water will dilute the spray down a little, but yes... you can clay a wet finish.
If you don't have a place to work in shade then it might not be a good idea though. As long as the existing spots have not etched the clear you should have no problem removing them with clay... if that doesn't completely remove them the polishing process will. |
09-10-2010, 05:41 PM | #7 | |
Im definitely a noob so I am not sure how to tell if they have etched the clear but I guess I will find out...thanks again |
09-10-2010, 08:51 PM | #8 |
NorCal Camaro➎ Member
I've always washed, new bucket of soap as lube, clay, re-wash then polish and seal.
09-14-2010, 01:14 PM | #9 |
I plan to clay my car for the first time this weekend, but I do not plan on polishing afterwords.
Is there any need for me to wash the car again after claying? The plan is to: Wash Dry Clay ? (Wash again or just wipe down with detail spray) Wax |
09-14-2010, 01:17 PM | #10 |
Drives: 2010 Camaro 1ss IOM Join Date: May 2009
What about the dishwashing liquid you recomend that????
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now! |
09-14-2010, 01:42 PM | #11 | |
"Detailing Devil Dog"
Drives: 2001 Corvette Coupe Join Date: Jan 2010
Washing the car properly after claying is a whole lot cheaper, less work and better for the paint than just wiping it down with detail spray afterward. The only reason that dishwashing liquid (Dawn in particular) is recommended to use before claying is because it strips all the wax and other substances off the car. This in turn keeps your clay from becoming dirty with unnecessary contaminants. This IS NOT something that you use on a regular basis, it is used ONLY to strip the paint of all protection.
"Marines - Making the other guy die for his country for over 200 years."
Similar Threads | ||||
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Detailing questions answered here! | Moose | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 636 | 06-04-2011 12:27 PM |
JEEEZZZ! CHECK YOUR PAINT! | PHEOX | 5th Gen Camaro SS LS LT General Discussions | 26 | 05-02-2010 12:26 PM |
Claying and Detail Spraying! | wantsa2ssrs | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 13 | 04-27-2010 01:41 PM |
All About the Clay Bar Process | Junkman2008 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 0 | 01-11-2010 10:22 AM |
