Old 07-27-2010, 09:16 AM   #29
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
Originally Posted by 1977and2010 View Post
What's the purpose for the spacers? Is it to raise the d-bushings up to fit the clamps better next to the frame? I just ground the clamps down to slide between the swaybar and frame.
if sways walk , they can rub in specific areas..spacers are used to keep all clearances intact
mikepage0007 is offline   Reply With Quote
Old 07-27-2010, 11:20 AM   #30
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm sorry - I'm lost...
Are these spacers supposed to be used with the clamps or are these supposed to take the place of the clamps? Also, I'm a little confused with the new Solution B swaybars - are they revised further?
Thanks everyone
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-27-2010, 12:26 PM   #31
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Thanks everyone
Me too, I got the clamps with mine and had to grind the bottoms down to fit between the bar and frame. This is the first I've seen of the spacers.
1977and2010 is offline   Reply With Quote
Old 07-27-2010, 12:46 PM   #32
Mr Twisty
Mr Twisty's Avatar
Originally Posted by mikepage0007 View Post
thanks for input sting...thanks for staying on top of this mike and good communication with me...i,m not mad at pedders or mike , was just getting a little frustrated...i will call extreme perf. today as i am back in florida and let them know parts are coming..i know friday they had the coilovers on but not sure if they got all my bushings in ...but not in rush as long as i know brackets are in transit...thanks
It's my fault you didn't get everything in a timely manner, I knew there was a fix coming but never got with Mike.
Use the yellow and if anyone asks, tell them you have Pedders custom fabbed skunkworks bars
-- Benjamin Franklin
Old 07-27-2010, 12:46 PM   #33
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
The spacers are to be used with the clamps so no modification of the clamp is necessary due to the very close tolerances of the bar to the subframe
Hope that helps
mike
Info@PeddersUSA.com is offline   Reply With Quote
Old 07-27-2010, 01:27 PM   #34
Info@PeddersUSA.com
Originally Posted by sting808 View Post
Just got the spacers in the mail today. They look great as compared to my backyard butchered pieces. I can finish off the front before car goes into body shop.
OT,
Mike, was that you in the Street Customs 69 GTO body on a 2006 chassis episoide? Now, that car looked great, except for the star logos. Classic looks with a modern rolling chassis and interior. Hate to see the price tag. Should've gotten a 2010 Challenger or Camaro. (Mopar deserves respect, too)
No that was Pete. He gets all the fun stuff! LOL The build was quite cool and drove seriously well!. They had the GTO on display at SEMA. It always amazes me that talent and creativity we see with so many of the outstanding builders.
mike
Old 07-27-2010, 01:31 PM   #35
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Hope that helps
mike
Got it - thanks
Old 07-27-2010, 02:31 PM   #36
Info@PeddersUSA.com
Revised Pedders Sway Bar Install Sheet for Camaro
Below is our revised Pedders Sway bar Installation Instructions. We have updated them for the front and rear locking collars, and front spacers to adjust for clearances for the collars.
Here is a closer shot of the front bracket assembly. The larger face of the bushing points inward. The spacer pictured is our prototype. The actual unit is color matched
Here is a closer look at the bracket assembly as it would appear installed
Why has Pedders gone thru all this effort? The concerns are welding collars on a piece of spring steel at a very stressed area with bar deflection, can create weakness in that area. We are being very picky about it, but this is our concern. Adding the spacers allows perfect clearance, good geometry, and easiness of installation.
thanks to all
mike
Old 07-27-2010, 02:44 PM   #37
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
thanks to all
mike
Thanks - I believe that makes your concerns very clear as far as why you went this direction.
Old 07-27-2010, 02:58 PM   #38
Info@PeddersUSA.com
thanks,
By the way, what brakes does the front look like on your Signature Picture??
thanks
mike
Old 07-27-2010, 03:02 PM   #39
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
thanks,
thanks
mike
I was going to be a smart @$$ and post a pic' of those brakes on your Pedders car, but I don't have one with those brakes Good call on that - it makes total sense, to me, for them to use those. I wonder if they're going to keep the rear binders and rotors though; I imagine they'd be just fine. KUDOs to you guys.
Old 07-27-2010, 03:07 PM   #40
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
BTW - I got a day-long ride in Mindz's car, with your Xas, and, umm... yeah - that was bad @$$!!! Not once did I feel the suspension crash and bottom out. There was one on-ramp, in particular, where he rolled onto the throttle, right in the middle of it, and we rode over a huge dip and it didn't upset the car one, single bit. I thought for SURE we were going to slide right across the freeway into the median, but shit - we didn't. That f'ing car seemed to bite harder the faster we went through the curve, and it didn't even have the complete content of one of your solutions. I'm sold now - without a doubt. Z28 is going to have to handle like one bad SOB in order for me to not work really hard to go with some Xas/Supercars!
Old 07-27-2010, 03:15 PM   #41
Info@PeddersUSA.com
Thank you for the complement! Pedders works hard at making the Camaro the best we can and will continue this process for a long time!
I have been waiting for someone to comment on the brakes and the picture for a while. Also, I am not surprised on how many guys I have chatted with that are like you and waiting for the Z28! Have one guy who already has already installed a complete Pedders track kit, and loves it. But will trade it in for the Z28 because he has to have the best! The Z28 will be soooooo cool!
mike
Old 07-27-2010, 03:52 PM   #42
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
mike
Well - even on a car that didn't have the full complement of your catalog on it, I was more suprised than I can express. KUDOs to you guys
Well - in Post 6 I didn't really suggest where I've seen those before, but those were one of the things I looked at first, lol
