sjm autoprod
Old 07-14-2010, 01:20 PM   #1
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Question on gears.
HP aside if you swapped out for 4.10's or 3.73's what would the Top speed be reduced to in 6th? Assuming you have removed the electronic limiter.
9/26/09 Took delivery!
Old 07-14-2010, 02:07 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Many people are concerned that their top speed will be significantly impacted by going to a more aggressive gear ratio, but in the case of these cars and the 3.73 or 4.10 ratios it is not. You will obviously lose a few top end miles per hour but these ratios are not so aggressive that you will hit a wall at 120mph. The car still has plenty of legs.
Old 07-15-2010, 12:31 AM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The Camaro does not reach top speed in 6th, though it might if you used 4:10 gears.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-15-2010, 09:55 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
top speed in 6th with 4.10's: 226 mph
top speed in 6th with 3.73's: 249 mph
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is online now   Reply With Quote
Old 07-15-2010, 09:56 AM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
The Camaro doesn't have the power to do that
Old 07-15-2010, 10:25 AM   #6
Camarorss350
camaro blogger
Camarorss350's Avatar
Drives: 2010 Black on Black SS/RS
Send a message via AIM to Camarorss350
Id like to seriously know, which people prefer with each trans...
Camarorss350 is offline   Reply With Quote
Old 07-15-2010, 10:55 AM   #7
ademster
Loud Pedal Motorsports
Drives: 2010 Camaro.
With an Automatic trans the deeper gears would perform better. because the transmission naturally slips the little extra ratio would help.
With the Manual trans I would go with the 3.73s due to the fact it is more of a direct drive system with little power loss.
all honesty 3.73s vs 4.10s isnt that HUGE of a difference only .37, inho don't think it would be a HUGE difference in performance with 3.73 or 4.10s. they would darn near feel the same.
Adam
480-598-LOUD
(5683 )
ademster is offline   Reply With Quote
Old 07-15-2010, 11:14 AM   #8
Apex Motorsports
Generally, we have found that with the M6 the 4.10s offer the best bang for the buck and are still good for daily use. For those who hit the track a lot 4.33s are also available. If horsepower levels over 550-600+rwhp are a factor then we recommend no more than 4.10.
For the A6 the 3.73 is the best option for most with 4.10 as an option for the hardcore.
Old 10-17-2010, 12:44 PM   #9
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
That's what I was thinking, changing gears on a stock vehicle would obviously affect high end power in 6th. gear. But, if mod'd and have 600+rwhp. probably wouldn't make much of a difference on a daily driver, but I guess if you're tracking you might want to get as much as you could on the high end.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 10-17-2010, 02:28 PM   #10
JustaCamaro
Drives: 2010 Camaro SS
Using the ratios supplied in the Helms manual for 5th and 6th of .79 and .63 respectively and stock sized tires, the speed in 5th and 6th at 6600 rpm should be 190 and 239.
JustaCamaro is offline   Reply With Quote
Old 10-19-2010, 10:54 PM   #11
GQ4Life
Drives: 2010 Camaro SS LS3
Stock 5th takes you to 194mph if you have the power, 6th is over 250mph
Talking manual LS3 & if you have the power to hit it in 5th.. If you put:
4.10s ur top speed 163mph in 5th.
3.73s ur top speed 180mph in 5th
Now this is if you have the power. At stock power car is drag limited to 174mph
I did not write 6th gear since the car probably wont have the power to pull in it unless you have alot of HP like over 700wHP. even with 4.10s 6th will take you to 240mph
Could do automatic if someone wants.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-20-2010, 02:34 AM   #12
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
This cars stock aero will never allow it to reach max RPM in 6th with 4.10's. Running out of gear and RPM would be the least of my worries in this car even with 4.10's and 1000hp.
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
I want 2010 Camaro GEARS! Camaro4466 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 51 12-04-2009 11:39 AM
Acceleration 2. What gears fit? mmbarberoilman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 05-06-2009 06:37 AM
