B&M Racing
Old 07-14-2010, 04:09 PM   #1
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
LS3 Lifter problem
My car is in the shop for valve train noise issues on passenger side - not extreme, but not normal either, does not go away after start up (this is a LS3 engine).
Dealer initially said he would look into oil pressure-blockage issues on that side.
1st report back from dealer yesterday, was they have determined problem is with components associated with cylinder #6 - ruled out accessible top side components, leaving problem to be either a bad lifter or bad cam.
Report today is that the lifter roller pin broke; dealer claims GM is saying only way this could happen is over rev of engine.
I have never hit red line yet (still breaking in <1,200 miles), and only came close to red line a couple times under light acceleration - besides I thought we have a rev limiter.
Anyway if anyone knows of other instances of a lifter roller pin breaking, please let me know. I may have a fight with GM on this. :(
edneyens is offline   Reply With Quote
Old 07-14-2010, 05:04 PM   #2
edneyens
edneyens's Avatar
Anyone have any information?
Old 07-14-2010, 05:05 PM   #3
edneyens
edneyens's Avatar
Well I am heading out to dealer to get some pictures...
Will post them later.
Old 07-14-2010, 09:02 PM   #4
edneyens
edneyens's Avatar
Well here are some pictures.
I was surprised how big the pin is and I am amazed that it could break.
Strange thing is all of the parts were in place no missing needle bearings, no apparent damage to valve, push rod, rocker arm or cam. Quite puzzling.
Big issue is damage done by broken pin - it scraped the "lifter cylinder" as it worked its way out of the lifter. May have toasted the block.
Old 07-14-2010, 10:13 PM   #5
BillAz5.0
Drives: 2011 DOHC 5.0
Mission Control - What we have here is a factory defective LS3 lifter - the dealer should fix this engine promptly - over reved my ass !!!
BillAz5.0 is offline   Reply With Quote
Old 07-14-2010, 10:14 PM   #6
electlatino
electlatino's Avatar
Drives: 2SS with RS and Ground Effects
not a car expert, but i would think the engine is supposed to be able to take high reving.
if you have few miles on your car, and the thing broke even if you were red lining, then there's something wrong with the engine and warranty should cover it.
i'd expect gm to pick this up because of the warranty. always remember, and i'm an attorney, being polite and professional always works better. don't be demanding, but stand your ground.
JBA full system, RotoFab CAI and w/w relocated, ADM scoop, tune, NLP spoiler....more to come
electlatino is offline   Reply With Quote
Old 07-14-2010, 10:22 PM   #7
edneyens
edneyens's Avatar
Yes I totally agree, I am talking nicely, however insisting that I have not abused the car and have expectations of being treated fairly.
Thanks for your input.
Old 07-15-2010, 03:53 PM   #8
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
You can clearly see the metal defect in the pin!!! It has a bad cast. I've never seen a pin brake from over revving without any other damage. I would seem to think that a bent push rod or valve would be the first indication of over rev. Even then, if it breaks the first time you over rev it, GM has put a low quality part in a high power output engine. They don't make sense. I thought these cars were built for punishment and the occasional miss shift or over rev? Man, I guess the engine is non-forgiving?
I would like to hear the engineers explanation to the theory of over revving and how this happened due to it.
canadian ss is offline   Reply With Quote
Old 07-15-2010, 04:47 PM   #9
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
Originally Posted by gm service View Post
Ed
Your issue has been discussed and resolved. Call your dealer. Welcome to the new GM and thanks for buying a Camaro.
that's a first! unless it is someone playing a prank
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 07-15-2010, 05:45 PM   #10
edneyens
edneyens's Avatar
Nope it doesn't seem to be a prank - got a call from my service manager telling me GM is going to put a new engine in my Camaro...
If it is a prank (the post here) it was a lucky guess.
Old 07-15-2010, 06:14 PM   #11
BillAz5.0
One of the guys at a reputable performance speed shop informed me that the lifters have occasionally been know fail due to pin slippage and are 'assembled' in Mexico. He also used the word cheap to describe them but I have never personally experienced problems with previous LS1/LS2s. Maybe the assembler was hungover and used a BFH to install the lifter pin !
Old 07-16-2010, 02:17 AM   #12
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
wasnt there a tsb for the Ls3 lifters a while back?
firestone_ss is offline   Reply With Quote
AFM: how does it works? tommygun6644 5th Gen Camaro SS LS LT General Discussions 9 02-28-2010 04:36 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
Pin stipes alfie43 5th Gen Camaro SS LS LT General Discussions 17 11-08-2009 12:30 PM
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 11:54 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
