Billet Custom
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 07-14-2010, 04:04 PM   #1
mello yellow
mello yellow's Avatar
Drives: lt1 Yellow
paint tape on engine cover
can't get masking tape or painters tape to stick. need suggestions
mello yellow is offline   Reply With Quote
Old 07-14-2010, 04:25 PM   #2
BlownSS
Firefighter / Paramedic
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
if you have properly prepared the surface by using some sort of scratch pad, and cleaning solvent, im not sure why you cant get it to stick.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger
BlownSS is offline   Reply With Quote
Old 07-14-2010, 04:27 PM   #3
christianmotox
christianmotox's Avatar
Drives: 2010 Silver LS (sort off)
Use simple green to clean it.
christianmotox is offline   Reply With Quote
Old 07-14-2010, 04:58 PM   #4
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
dish soap
Wash it with dawn dish soap and rinse thoroughly.Rough the painted surface that was factory painted with 1200 grit paper.
Get a fresh roll of blue painters tape 3M.
Also a roll of scotch 1/8 " fine line automotive body tape if doing letters.
Minimize touching surfaces as you tape the surfaces to be painted.
Just finished mine today,inferno Orange over silver panel,fine line taped the letters this am and shot summit white on letters.Looks good.Go for it .
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 07-14-2010, 05:02 PM   #5
Dyk-NO
Drives: 2010 Camaro LS M6
I don't get how you can't get it to stick, maybe you bought the wrong tape?
"From ZERO to a Tire-Burning HERO!"
Dyk-NO is offline   Reply With Quote
Old 07-14-2010, 05:41 PM   #6
mello yellow
Drives: lt1 Yellow
tried simple green, dawn & even tried alcohol( on the cover that is )fresh blue painters tape. About to try alcohol in the body.
Old 07-14-2010, 05:51 PM   #7
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Simple solution: get rid of the engine cover.
No one sees it unless you are showing it and it traps heat.
tradosaurus is offline   Reply With Quote
Old 07-16-2010, 07:54 AM   #8
Silver1lt
Chevy Tech
Silver1lt's Avatar
Drives: 2012 Equinox 2LT
Send a message via AIM to Silver1lt
scuff it a wee lil bit hit it with alcohol or some solvent to get the shitty shine spray they detailed the engine bay with when u bought the car and you should be ready to go ... i learned you need to make sure everything is nice n clean or the paint will wrinkle up bad... good luck and i switched from blue painters tape to regular white masking tape when i finally got to paintin
Rich Doherty Malden Ma
2010 Silver Camaro 1LT Black Stripes V6 6Speed K&N Intake Traded for a 2012 Equinox :( Family's growing
Silver1lt is offline   Reply With Quote
Paint type and color for engine cover gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 10-24-2012 04:04 PM
"Chevrolet" on engine cover ..decals or paint? LRod Cosmetics and Lighting Modification Discussions 5 07-05-2010 11:43 PM
Paint for engine cover gearhead440 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 02-23-2010 08:59 PM
Engine cover MOD d69chris Cosmetics and Lighting Modification Discussions 33 09-16-2009 10:02 AM
