| Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions |
Thread Tools |
#101 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2011
I just installed this yesterday and I love it! However, the hardest part is getting it to fit flush in the mailslot. I tried 3M double-sided tape, then gorilla super glue and it does not hold it flush. I will have to take another stab at it today. Peculiar how the install video kinda whizzes past this part.
![]() This time I hope to remove the light, remove all of the 3M tape and clean the surface, and try to bend it into shape a bit more (I guess) and try re-installing it. I was afraid to bend it too much, but I guess I didn't bend it enough? I don't know...
#102 |
heat gun or blow dryer should be all it takes to get it into place. I agree I love my light too
. i just installed a toggle switch so that I can turn it on and off from inside the car.. much better lol
#103 |
Thanks for the tip. How much trouble is it to install a toggle?
#104 |
not to hard, just make sure you have the drill lined up so that you have room for the nut on the switch lol, learned the hard way, but at least you cant see it... I mounted mine under the drivers side dash left of the hood release. there is a grounding point right near there as well ( Side wall of the foot well ) . there are some DYI posts on toggle switches, also one showing how to gain access through the firewall. both came in handy for me.
the switch itself is very easy to wire up. more then happy to help ya if you need it. This is the switch I used, 5 bucks at radio shack . it lights up green when the light is on. which is what i wanted so i know i am not rolling around with it turned on lol.
#105 |
Thanks man!
#106 | |
I Finally got my light in the mail. tried to install it and i got the same exact issues and answers from AAC. I pulled the light out to see if its getting signal. She said try a battery, so i went and bought a $6 duracell battery and im getting the same issues. They are supposed to be sending me a replacement remote because it will change colors (after i press it 1,000 times) and pattern works (after i press it 1,000 times) but auto/Up/on/off doesnt work at all. So once my remote comes in, we'll see if it resolves my issue. |
#107 |
![]() Drives: 2012 45th Anniv, 2SS, LS3 Join Date: Feb 2012
a must order, and wonder if this can work on my Suzuki M109?
#108 |
Pissed!
Update: I went back to re-install it to get it to sit flush in the mailslot. I just put a VERY light bend in it and it broke!
What a waste! I will not be repeating this again!![]() I may reconsider if either: 1) AAC makes a scanner specifically for the Camaro mailslot application, or 2) AAC provides SPECIFIC instructions on how get the scanner to fit flush in the mailsolt WITHOUT it breaking, versus posting a video that cleverly skips over that part! Until then, I will remain !!!!!!!
#109 |
avacamaro
Drives: 2011 SS/RS Join Date: Apr 2012
Love the looks of the scanner, but scared I'm going to have the same problems.
Can't ACC just make it like the UK did. Plug and play. It would be worth $200. |
#110 |
i never had any issues getting the light to bend. you have to use a heat gun or blow dryer though. just bending it without heat will more then likely cause it to crack.
#111 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Love to get this if only I could in purple
#112 |
think you would have to get the RGB version if you want purple.
#113 |
OK I got mine installed today and fitment was great (although hated cutting the slots out) but I have a question/comment I could not move it over to the driver side any further without covering the IR sensor but by leaving that showing the LEDs are not centered I'm one over to far to the left. Most people will probably never notice but I'm anal and it's driving me crazy. I was able to use the heat gun and got it to lay down perfectly. So I'll live with it.
Also for you that have issues after installing I tested mine before install and it worked perfectly, after install it was sporatic and not all LEDs were lighting up just like some of you have experienced. So I found the ground (bolt for radiator hold down) was not a good enough, I removed the hold down ground off some paint and did a much better job grounding the unit and it works perfect again. |
#114 | |
C5 Lighting Specialists
![]() Drives: www.CamaroLighting.com Join Date: Jul 2009
#115 | |
. but the blue and red that split in the center of the light bar = bad. :(
#116 |
![]() Drives: a Panty Dropper Join Date: Feb 2012
I have the one with the IR and i was able to center it up perfectly and you cant even see the IR sensor because its tucked behind the mailslot and the remote still works perfect
#117 |
how did you manage that? IR is line of sight.
#118 |
#119 | |
#120 |
The IR eye can go behind the bumper cover, you will need to remember where it is located because you will need to point the remote directly at the eye to get it to work.
Hope that helps
#121 | |
I don't think having a larger hole size than the light bar would look very clean. I really think a redesign is in order either move the center over one more LED to the right or mount the ir sensor dead center which seams like that would not be too difficult but IDK. |
#122 | |
#123 |
Just like this guys it does not take an engendering degree to figure it out its not hard. Look at the video and youll get the idea. You do not need to cut a larger hole in order to get it to fit just take your time and use a hair dryer to soften up the plastic and it will slip right in
#124 |
Damn Wish I would have known that you could do it this way before installing mine. I had troubles with the first light, and was told to make sure that the eye was visible.. oh well, i only use it for the knight rider theme anyway. so being centered doesn't really effect it. and since this is my 3rd light, I don't wanna mess with it and have it stop working again lol.
nice install by the way.
#125 |
![]() Drives: 2010 Camaro 2SS/RS Whipple Join Date: Jun 2010
Does anyone know where there yellow wire goes?
2.9L Whipple Supercharger, Kooks Long Tube Headers w/ high flow cats, ADM Race CAI w/ scoop, APEX water bottle relocation kit, RX oil catch can, Borla ATAK cat-backs, Ultra 431 Rims w/ orange accent (20x9 front, 20x10 back), SPL gill stripes, Hurst short throw shifter
| Thread Tools | |
| Need pics of Pedders Bushing install | jrpxxii | Suspension / Brakes / Chassis | 14 | 05-22-2012 12:58 PM |
| DIY: SIDE GILL FADE AND OUTLINE INSTALL | Milk 1027 | Wiki | 2 | 09-08-2010 09:59 AM |
| Roto-Fab CAI Install with Pics (5 Stars) | NVMY68SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 120 | 05-23-2010 01:51 AM |
| Night Rider LED | cyberbro | Cosmetics and Lighting Modification Discussions | 14 | 04-24-2009 08:57 AM |
