Emblempros
Old 07-15-2010, 09:42 PM   #15
DjD
Classic Owner
DjD's Avatar
Drives: 1969 Ragtop
Originally Posted by danhr View Post
I don't know what you are talking about....
haha... it's fixed... I forgot to change that when I went back and changed the example. I am doing/did this write up at work... give me some slack here. lol
I'm not giving you a bad time, you asked!
...and you don't have to worry about me, I'm not telling your boss!
DjD is offline   Reply With Quote
Old 07-15-2010, 09:44 PM   #16
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2016 Charger Hellcat
I missed the link. Good thing I don't fish.
lewylew is offline   Reply With Quote
Old 07-17-2010, 10:24 PM   #17
CynAgain
CynAgain's Avatar
Drives: Chevy
Great write-up!
:party0038:
Old 07-18-2010, 08:05 AM   #18
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
Yes most helpful thank you!
Bonemaro is offline   Reply With Quote
Old 07-30-2010, 02:33 PM   #19
HumanWiki
Drives: Car
What can I say? I'm Asian.
And since I'm obviously not fulfilling the "driving a honda civic" stereotype, I gotta fill the void elsewhere.
I just had the Family Guy episode where Peter's taking a test, he pulls out that kid, pokes him and says "Come'on.... Do Math...."
HumanWiki is offline   Reply With Quote
Old 07-30-2010, 06:36 PM   #20
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Old 07-31-2010, 03:01 AM   #21
GQ4Life
Drives: 2010 Camaro SS LS3
i love family guy.. hilarious..
get write up.. been doing calculations to thinking about gears..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-11-2010, 11:43 PM   #22
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Strictly looking at the numbers then, if you want to go faster more quickly in a lowever gear; Why is the recommendation for an M6 to go with the 4.10's from the 4.33's. Wouldn't you want to upgrade to the 3.73 or 3.45's?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 10-11-2010, 11:52 PM   #23
Supercharged SS
Drives: 2010 Camaro
Hey Danhr, right now I'm trapping anywhere from 130-132 mph. I'm staring to wonder if some lower gears may be of signifigant help. Off the line and down the strip. 3.45's or 3.70's?
It seems that with any gear other than the stock 3.27's I will be shifting into 5th. With the 3.45's max speed in 4th is 133mph. Thats right where I am at currently and with the 3.73 the max speed in 4th is 123mph. Thats def not going to work.
Old 10-12-2010, 12:33 AM   #24
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Thanks for the write up! I'm understanding gears a lot better now. In my Automatic V6, I don't have limited slip differential, does differential bushings still matter to me?
jagan323 is offline   Reply With Quote
Old 10-12-2010, 02:05 AM   #25
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
While its true that the lower the number is, the faster you can ultimately go ... the reason why you go with a higher ratio is so that you accelerate quicker. Having a high top speed does you no good if you can't reach it before you run out of pavement.
Remember, these cars have 6 gears and they don't us all of them in the 1/4. A stock SS M6 will top out at about 110 mph in 3rd gear, which is about what they run in the 1/4. If you had a set of 4.10's it would max out at a little more than 90 mph in 3rd. But shift in to 4th and it can now go up to 130 mph.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-12-2010, 10:11 AM   #26
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
ummm if I remember your dyno sheet correctly, you keep making power until 6700 or so rpm. That means you should be shifting/redlining around 7000 rpms.
So for you, the max trap speed of a 3.45 gear is 147 mph
3.73 gear is 136 mph.
A couple "special" things about your setup though
A) You are running a bias ply tire. Bias ply tires are known to "grow" on the top end of the track, since they have soft sidewalls and the higher speed. So your 28" tall tire, is going to be more like a 28.4ish tall tire by the time it crosses the traps. The faster your wheel goes, the taller it will get.
B) With most forced induction, they sometimes perform better with less gear, because the motor works better when it has more of a load on it. Well at least I know this to be true with turbochargers, I don't know about superchargers.
With that being said, I can't give an honest opinion on what should perform the best. That would be something to bring up with Ted... maybe he has a better answer than me. I know if it was me, I would be throwing a set of 3.73's in there, when you do the differential bushings. That's just me though...
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-12-2010, 10:33 AM   #27
CamaroMiami
Drives: 2010 Camaro 2SS LS3, 92 Camaro RS
danhr, you did a great write-up.
I'm going to save that as a pdf, so I can always refer back to an outstanding / excellent explanation of gears 101
Last edited by CamaroMiami; 10-13-2010 at 06:27 AM. Reason: PDF made for later reference
CamaroMiami is offline   Reply With Quote
Old 10-12-2010, 09:42 PM   #28
calbert1999
Camaro SS Lover
Not getting it.
Smaller gear ratio # the faster I can go in a lower gear, but, achieving that higher speed in a lower gear is going to take longer than with higher gear ratio.
So, the only reason why people spend big $$$ on these gears is to save themselves from shifting to a higher gear?
Hmmm...... I don't get it, everyone seems to freak out at how much qucker and more responsive the vehicle is when they change their gears to 4.10's or 3.73's, is it an illusion of the mind. What's the point?
If this is correct, shouldn't I just keep my stock gears?
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 07:59 PM
Changing rear end oil and trans oil? caverman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 03-01-2010 11:09 PM
4:10 rear end or LT headers & tune? wildthing001967 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-06-2010 11:21 AM
