Gen5DIY
Old 10-12-2010, 10:07 PM   #29
Supercharged SS
Drives: 2010 Camaro
Originally Posted by danhr View Post
ummm if I remember your dyno sheet correctly, you keep making power until 6700 or so rpm. That means you should be shifting/redlining around 7000 rpms.
So for you, the max trap speed of a 3.45 gear is 147 mph
3.73 gear is 136 mph.
A couple "special" things about your setup though
A) You are running a bias ply tire. Bias ply tires are known to "grow" on the top end of the track, since they have soft sidewalls and the higher speed. So your 28" tall tire, is going to be more like a 28.4ish tall tire by the time it crosses the traps. The faster your wheel goes, the taller it will get.
B) With most forced induction, they sometimes perform better with less gear, because the motor works better when it has more of a load on it. Well at least I know this to be true with turbochargers, I don't know about superchargers.
With that being said, I can't give an honest opinion on what should perform the best. That would be something to bring up with Ted... maybe he has a better answer than me. I know if it was me, I would be throwing a set of 3.73's in there, when you do the differential bushings. That's just me though...
Ted wants to do the 4.10's. We have a pumkin all set up with his posi-mod allready done. His theory is that the car is so heavy that it needs all the help it can get. I just think thats to much gear and all I will do is blow the tires off. And won't I be into 5th? I've seen these cars with these gears and power just over power the tires and the track. I have very limited wheel spin now so thats why I was thinking the 3.45's to try if I can find an M6 rear. Maybe 3.73's at the max. I'm still unsure so I won't pull the trigget until all my research is complete.
Thank you
Old 10-12-2010, 10:29 PM   #30
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Thank you
As a general rule the higher the power of the engine, the less gear you need. You have a much better converter than stock so it will really depend on if you can plant those slicks !! On another fairly high powered car, we put in 4.11s but later switched to 3.70 (Ford 9") and ran a faster E.T. and more MPH. There are so many variables. But it was also a lighter car. These Camaros are pretty beefy.
Old 10-12-2010, 10:36 PM   #31
Supercharged SS
Drives: 2010 Camaro
Thanks Bruce. Thats Ted argument. The weight of the car but I'm convinced that with my setup I'll kill the tires with 4.10's. If I go with the tq multiplacation table I think the 3.45's should be gd and keep the car in 4th. 3.73's seem like I'll be shifting into 5th at the end of the pass.
Old 10-12-2010, 10:47 PM   #32
speedster
SST...
speedster's Avatar
Well I have a spare rear diff if you ever want to experiment. I lent it to various people to prototype Camaro components.
Old 10-12-2010, 10:50 PM   #33
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by calbert1999 View Post
Not getting it.
Smaller gear ratio # the faster I can go in a lower gear, but, achieving that higher speed in a lower gear is going to take longer than with higher gear ratio.
yes
So, the only reason why people spend big $$$ on these gears is to save themselves from shifting to a higher gear?
No. They spend the money to accelerate faster, and a consequence is having to shift more often than stock
Hmmm...... I don't get it, everyone seems to freak out at how much qucker and more responsive the vehicle is when they change their gears to 4.10's or 3.73's, is it an illusion of the mind. What's the point?
If this is correct, shouldn't I just keep my stock gears?
It is very real. 3.73's increase torque at the wheel by about 8% over stock. 4.10's give about 19% more.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-13-2010, 12:12 AM   #34
Ivan @ Southwest Speed
Well Done Dan. Thank you for the Calculator Time. I know what you put into this.
Great write up. +hp to you.
Old 03-05-2011, 02:59 PM   #35
steeleshark2
steeleshark2's Avatar
Sticky This Please
Can we get this in a Sticky??
Old 04-18-2011, 12:45 PM   #36
FiveO
FiveO's Avatar
Drives: 2011 Camaro SS 6speed Manual
Great information!!!!!
FiveO is offline   Reply With Quote
Old 04-27-2011, 10:15 PM   #37
snippy
snippy's Avatar
Drives: camaro 675 Rwhp
Wow that what I need.....
The Assistant Manager Of UAE CAMARO CLUB
snippy is offline   Reply With Quote
Old 05-17-2011, 12:55 AM   #38
Weezerj
Weezerj's Avatar
Drives: 2012 Camaro 2SS -- 02 Escalade
Awesome write up man.....(now if I could just wrap my mind around how the limited slip diff works)
Weezerj is offline   Reply With Quote
Old 01-16-2012, 09:50 PM   #39
Tigg
Irreverent Schmoe
Tigg's Avatar
Drives: Black 2010 2SS
So if I am as good as the testers are and I can turn a 13 flat with a stock SS..What kind of times could I expect to get with a gear swap to 3.73'S or 4.10's ?
Black 2SS,M6,Sunroof,R6P.11390
Tigg is offline   Reply With Quote
Old 01-16-2012, 10:04 PM   #40
v8
v8's Avatar
Drives: GT500 and 14 ZL1
good question
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
v8 is offline   Reply With Quote
Old 01-20-2012, 11:07 PM   #41
Tigg
Irreverent Schmoe
Tigg's Avatar
anyone?...
Old 01-21-2012, 03:39 AM   #42
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
What do you have to do to get the speedo correct when the gears are changed? Does this require a tune? Don't want to knock it out of warranty.
Toyaholic is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 07:59 PM
Changing rear end oil and trans oil? caverman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 03-01-2010 11:09 PM
4:10 rear end or LT headers & tune? wildthing001967 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-06-2010 11:21 AM
