Old 07-15-2010, 09:39 PM   #1
billyspeed
BILLYSPEED
billyspeed's Avatar
Drives: 2016 black camaro SS
REAR WHEEL MAX SIZE
what would be the max sizi tires i could put on the rear of my camaro 1ss?
thanks for all info...
2010 camaro ss sold
2011 camaro 2ss/rs convertable sold
2015 ZL1 sold
2016 camaro SS
billyspeed is offline   Reply With Quote
Old 07-15-2010, 10:51 PM   #2
adub
adub's Avatar
Drives: Shopping
Assuming you mean width, theres plenty of guys running 315 width. If you mean height, theres a 2010 Camaro on 28" rimz on Miami craigslist LOL
______________________
2010 2SS RS Auto - Black
1970 Chevelle SS 396
adub is offline   Reply With Quote
Old 07-16-2010, 08:48 AM   #3
billyspeed
BILLYSPEED
billyspeed's Avatar
thanks.. yeah i saw that post... that is just wrong !!
2010 camaro ss sold
2015 ZL1 sold
2016 camaro SS
Old 07-16-2010, 08:51 AM   #4
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
305's fit perfectly.
stratman2SSRS is offline   Reply With Quote
Old 07-16-2010, 10:43 AM   #5
turbo222
Drives: 2010 Summit White Camaro 1SS
315's fit amazing lol (just got them!)
Engine: 402whp & 394TQ Hp-tuned, Kooks 1 7/8" catted headers, 3" Kooks Cat-back Exhaust, Roto-fab Intake (Summit white), Skip shift Eliminator.
Exterior: Blacked-out Tail lights / Reverse lights / Side Markers / F & R Bowties, Stealth turn signal bulbs, AAC Blue Dome and Footwell lights.
Wheels/Tires/Suspension: ForgedStar F14 Rims (semi gloss) 20x9.5 & 20x11, Nitto NT05's 275/40/20 & 315/35/20, Pfadt Lowering Springs.
ICE: Audison LRx 5.1k Amp, 2 Hertz Hi-Energy 250w Componet Speakers, 2 Bravox Audio CF 260w Coaxial speakers, 12" Hertz Hi-Energy 1200W Subwoofer, ******** Box and Amp Rack.
turbo222 is offline   Reply With Quote
Old 07-17-2010, 08:40 AM   #6
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Max width tire is 315 wide. Fits perfectly, even on lowered cars. Of course, you will need a 10.5 to 11.0 wide wheel to accommodate that tire width properly. And an experienced wheel source to get the proper fitment
Fquick.com/NineBall
Old 07-17-2010, 09:30 AM   #7
se7en
Drives: 87 Pinto on 32's
I wouldn't put bigger than a 305 on stock rim's. If you plan on ordering aftermarket (see Tony) and get a 10.5 or 11 inch then slap on 315's.
se7en is offline   Reply With Quote
Old 07-17-2010, 01:11 PM   #8
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
bws_82, not intending to be offensive, however, I think you are pushing it to far recommend putting a 305 tire on the stock wheels. The recommended ranges for the 9 inch wheel shows a 295 tire as the largest tire for a 9 inch wheel, I would not recommend anything larger for a tire on the stock wheels.
Here are the recommendations:
295 tires: 9 to 11
305 tires: 9.5 to 11.5
315 tires: 10 to 12
I would recommend staying mid to wide side of the width range when buying wheels for the tire size you want to use.
edneyens is offline   Reply With Quote
Old 07-17-2010, 04:22 PM   #9
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i assume you would need correct offset of 35mm on rear to fit a 315? you would not say a wheel with offset of 25mm can fit under fender?
mikepage0007 is offline   Reply With Quote
Old 07-17-2010, 08:01 PM   #10
edneyens
edneyens's Avatar
The stock rear wheel has a +40 mm offset, if you use a new wheel with same offset and the 315 tire this combination will stick out an additional 0.8 from stock position. If you go to a +35mm offset it will stick out an additional 1.0 inch, +30mm -> 1.2 inch. Pick up the trend?
I have the 305 tire and am using a +40mm offset and seeing 0.6 inches from stock - the tires are still within the wheel well - this set up works great for me.
I think +40mm would work fine for me as well for the 315 tires. The front wheel/tire combination seems more sensitive to offset however I think for most wheel/tire combinations something in the range of +30mm would be the target offset.
Old 07-18-2010, 08:03 AM   #11
Nine Ball
Nine Ball's Avatar
Be careful when discussing offsets. Offset measurements must be included and referenced to a specific wheel width, or the information means nothing. Both are linked directly. A 20x9 wheel and a 20x10 wheel with the same offset do not fit anything alike.
Fquick.com/NineBall
Old 07-18-2010, 09:46 AM   #12
Mr Twisty
Mr Twisty's Avatar
Nine Ball has good advice.
Here's a good calculator: http://www.rimsntires.com/rt_specs.jsp
-- Benjamin Franklin
Old 07-18-2010, 03:53 PM   #13
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I bought my wheels from Nine Ball. I have 11" wide rims and 315 wide tires on the back. My car is lowered and they look and fit great!
Old 07-18-2010, 04:08 PM   #14
edneyens
edneyens's Avatar
Nine Ball; I do not agree, a 20X10 and a 20x9 wheel with the same offset and the same tire (assuming the tire is properly sized - or works with both wheels) will have the same inside and outside clearance. You see the tire is what determines the clearance being it has the greatest width not the wheel.
Please check into this a little bit more. Regards.
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 03:44 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
