Solo Performance
Old 07-15-2010, 10:55 PM   #1
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Clutch squeak??
So I've noticed a "squeak" per se that appears to be in the clutch. Like it occurs when I'm backing out, applying gas or not, and seems to be isolated to the clutch movement. It happens whenever it's engaging/disengaging.
Is this normal by any means? And has anyone had this occur??
Between this and the other issue I'm concerned I'm having clutch issues hard core...
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 07-16-2010, 01:26 AM   #2
ffrcobra_65
Can u replicate the squeak sound just sitting still and pumping the clutch pedal? If so, look in the footwell where the clutch pedal is and make sure the white tiny little grommet has not slipped off the end of the clutch pedal spring.
Old 07-16-2010, 08:40 AM   #3
3min3m2
3min3m2's Avatar
It only does it in gear, hence the concern...
2012 2SS/RS VR 6M.
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Clutch Sticking F N MUSCLE Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 12-07-2009 05:00 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
