Old 05-16-2007, 06:29 PM   #1
selil
selil's Avatar
Drives: Chevy Avalanche
4th Gen General Questions
I'm looking at a 2002 Camaro Z28 Convertible to replace my Avalanche. What kind of gas mileage can I expect? Will it make a good daily driver? Love my Avalanche but I never use it as a truck so I've been looking for something sports with a manual transmission to drive. I figure fit an finish should be similar and I can't imaging gas mileage being worse.
selil is offline   Reply With Quote
Old 05-16-2007, 07:05 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Expect probably- 24-26 mpg on average, if you drive decently, obviously milage will fluctuate with driving style. Good daily driver in the summer, but the soft top could be a problem in the winter - and the fact that it's a Camaro anyways, I wouldn't drive it in the winter.
but those who have owned 4th gens for a longer time than I have will have better insight.
Old 05-17-2007, 01:11 AM   #3
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Well...if you are looking at a 4th Gen for a daily driver, you won't have any problems at all sporting an 02 Z28 vert. Seriously. I've been driving 4th Gens for the past 7 years. Let me start by saying you are going to get a hell of a lot better gas mileage in a 4th Gen than an Avalanche!
In my 02 Z28, I was never able to put in more than 15 gallons at the pump. In my 02 SS, I haven't been able to put in over 14.2 gallons...kinda weird. Maybe I need to run it dry just to see how much gas it takes and the relative size of the gas tank. I think it's supposed to be a 15 gallon tank.
BUT...I have driven from Northern San Antonio (Bulverde area) down to Port Aransas and back (roughly about 340 miles) on one tank of gas. That meant on highway miles I was getting approximately 24 miles to the gallon. During regular city driving, I might get around 17mpg. The only thing it takes getting used to, is parking further away from curbs...yes, I've cracked a front facia. In the avalanche, you can just park on top of them if you want...
You'll be more than happy with a 4th Gen. The Z28 has a ton of power. The only other thing you might need to worry about is a case of "heavy foot."
Old 05-17-2007, 09:38 AM   #4
selil
selil's Avatar
Thanks so much! I've been test driving a couple of them. Wowser!
Old 05-17-2007, 11:17 AM   #5
Mr. Wyndham
Curious TAG, whats the GVW, gross vehicle wieght, on a Z28 4th Gen?
Old 05-17-2007, 11:43 AM   #6
TAG UR IT
TAG UR IT's Avatar
Can't remember off the top of my head. I remember weighing in at the track to the tune of something like 3,400 but I could be way off. I'll get back to you and let you know in a few.
Old 03-05-2008, 12:05 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think the GVW on a fourth Gen. is close to 4100 lbs. I believe the maximum passenger weight is somthing like 900 lbs. (from the owners manual.) My car, with SFCs, bigger wheels and tires, and some other stuff knocked the scale to 3625 lbs. without me in it. Like Tag said, I believe V8s with M6s came right in at about 3400+ lbs.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-05-2008, 05:15 PM   #8
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
my pewter '02 Z28, with 19" CCWs, 12 bolt rear end, half a tank of gas and all other mods, weighed in at 3825 with me in the driver's seat... and I weighed in at over 270lbs at that time... so a Z28 weighs in pretty close to 3300lbs without a driver... the Z28 'verts weigh in slightly heavier due to the structural reinforcements that had to be done to make it crash and rollover safe.
I've recently had the chance to talk to several 'vert owners, as I was looking into getting one for a daily driver for Naomi... it would seem that everyone has the same praises (love top down cruising, easy operation of the roof, not much noisier than a normal t-top 4th gen) and the same gripe: the roof wears out pretty quickly if you leave it outside every day and every night... so if you have a garage, I'd recommend keeping it in there... and the 'vert owners I talked to were all automatic owners, so they said they were getting about 20mpg average with their cars... so expect a manual to be slightly higher, probably in the above mentioned 24mpg range.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 04-04-2008, 08:30 PM   #9
brotherben
brotherben's Avatar
Drives: 1994 camaro 6 cil. all stock
my 94' v6 gets 18 or 19 city and 27 high way average about 22
brotherben is offline   Reply With Quote
General Motors rolls out its heritage at the Woodward Dream Cruise KILLER74Z28 5th Gen Camaro SS LS LT General Discussions 4 09-13-2014 12:25 AM
I'm not sure if I'll buy a 5th Gen. Camaro Moose 5th Gen Camaro SS LS LT General Discussions 68 06-13-2009 06:18 PM
5th gen Cargo space rray200 5th Gen Camaro SS LS LT General Discussions 81 02-05-2008 11:00 AM
5th gen and winter driving rray200 5th Gen Camaro SS LS LT General Discussions 28 03-08-2007 02:55 PM
Sweet 4th Gen 4 Sale on Ebay TAG UR IT Off-topic Discussions 3 10-11-2006 12:12 PM
