Cold Air Inductions
Old 07-17-2010, 01:31 PM   #1
Bbrock25
Bbrock25's Avatar
Drives: 2010 1SS/RS Inferno Orange
Recycle Air
Not sure if mines working properly or not. I have a 99 Silverado v8, a 2000 Tahoe v8, a 06 Silverado v6, and of course the Camaro SS (LS3). All of them but my Camaro work great. Say you run both the Recycle Air, and the AC for a few mins, turn off the AC and for the rest of the time its COLD air blowing just from the Recycle Air (most of the time its cold even w/o using the AC) However in the Camaro its always just blah air; not hot/warm or cold/cool air. Does everyone elses Camaro do this? Or just mine. Its nothing to complain over, was only curious. And no I'm not to cheap to run the AC before anyone says lol. Always fill up with 93!
Bbrock25 is offline   Reply With Quote
Old 07-17-2010, 02:06 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
I havent actually used the recycle air on mine yet.. However the 'normal' A/C only blows fairly cold while I'm moving. Once I stop at a light or something it doesnt do much good.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-17-2010, 04:27 PM   #3
Bbrock25
Bbrock25's Avatar
Hmm never really payed attention to it at a light...I'll make a note of that to check it next time I'm out. Maybe theses cars have weak AC/fans ?
Old 07-17-2010, 05:55 PM   #4
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Got an appointment on Monday to have mine checked out. Does just what yours is doing. I thought it was due to the 90 plus degree heat we are having, but when I got in my Acura and turned on the AC I could feel the difference in the air instantly. I will post what I they find.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 07-17-2010, 05:56 PM   #5
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
I use the recycle mod when I'm behind a disel truck or smoker in traffic. Works fine to cutoff the smell from the outside air.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 07-17-2010, 06:01 PM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
You should use recycle air for A/C. Think about it, when recycle you are cooling cooled air that has been cooled by the car A/C. Example it was 95 out yesterday on my 5 hour drive from Huntsville. Within a hour I turned the fan down from the middle to just 1 click because we where freezing.
No recycle you are always having to cool hot air since you are pulling 100 percent from outside.
Recycle is still litting in some outside air and letting some cold air out so you get oxegen but it is a huge difference in this heat.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-20-2010, 02:08 PM   #7
bkscott
bkscott's Avatar
Ok, Yesterday I had the Ac serviced. The SA said it was just probably low on freon. They did a complete evac, and recharge. Today I took the car out in 95 degree heat, and did not have to move the dial past the low setting.
Before I would have been on atleast level 3. So if your Ac does not feel right take it in.
K&N AirCharger and Typhoon System | Best Prices | Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 175 09-04-2012 02:40 PM
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 02:46 PM
Vortech vs Maggie IPAINTBRIDGES31 Forced Induction - V8 34 03-27-2010 05:48 PM
YOUR WARRANTY INFORMATION Kwaz1335 5th Gen Camaro SS LS LT General Discussions 2 11-02-2009 05:23 PM
