Gen5DIY
Old 07-17-2010, 04:06 PM   #1
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
engine light
hi
i bought kooks lt for my l99 and when i finshed instaling the
kooks headres my check engine light came in
by the way the kooks is 1/78 lt off-road
what can i do now
ps i have diablo programer but i dont know what 2 do
orange-prince is offline   Reply With Quote
Old 07-17-2010, 10:45 PM   #2
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
Since it appears from your profile that you are not in the USA, I don't know if your car originally came with catalytic converters and the rest of the emission control system. But if it did, and if you removed the cat converters, then you will get the check engine light because the O2 sensors show that the emissions are higher now. Or maybe the header change did something else that affected the O2 sensors.
Also, adding headers to a factory-stock Camaro might disturb the air-fuel mixture somewhat, which might set the check engine light if it's too far out of range. The car probably needs to be tuned to adjust the fuel mixture to compensate for the exhaust changes. I don't know enough to tell you how exactly to do that.
This question probably would get more action in the "tuning" part of this forum.
MikeZ28 is offline   Reply With Quote
Old 07-18-2010, 02:03 PM   #3
orange-prince
QATAR 2022
so i should change my exhaust and get a tune thanks mike
by the way our cars here in qatar is 100% like americans cars in us
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
