Jason 98 TA
Old 07-17-2010, 09:33 PM   #1
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Shifting into Third Question
Everytime I up-shift into third (never when downshifting), I can feel the gears coming together, as if I am not pushing the clutch all the way in. There isn't any grinding, but none of the other gears feel this way. Is this normal?
jeepguy_1980 is offline   Reply With Quote
Old 07-17-2010, 10:06 PM   #2
Fast vette
Fast vette's Avatar
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra
Sounds like a bad syncro, if you're still on stock tranny fluid you could try Royal Purple, might help a little but more than likely the tranny's got to come out.
There are only two auto manufacturers; GM and everybody else...
Fast vette is offline   Reply With Quote
Old 07-18-2010, 01:54 PM   #3
hamidar05
Drives: 10 Camaro/69 Bronco/08 Mazda3
Yes, agree same thing here, you are not alone.. I clunked it pretty good once trying to shift spiritedly..
I am at 1600 mi.. was thinking of changing the fluid pretty soon. What vin is yours, I also have a 1SS LS3, VIN below.
Selection Worksheet - 04/27/09
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092
Thank You Oshawa - Domo arigato Mr. Roboto
~1600 mi so far - 07/18/10
hamidar05 is offline   Reply With Quote
Old 07-27-2010, 08:32 PM   #4
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Same issue here, only 3rd gear, and only when driving "spirited". # 121,916
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 07-27-2010, 08:41 PM   #5
jeepguy_1980
2G1FS1EW9A9202312
Old 08-09-2010, 02:13 AM   #6
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I have the Hurst short throw and get that grind from 1st to 2nd often on spirited driving. I'm not too happy with that at all.
Besides driving like Miss Daisy, anyone have any suggestions? change the shifter out? Something else that could help?
Old 08-10-2010, 12:45 PM   #7
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
I seem to have the same exact issue shifting from 1st to 2nd. I have a 2011 Camaro LS M6 with under 200 miles. It seems notchy shifting from 1st to 2nd...no grinding noise just "feel" like it's grinding a little as I move it into 2nd gear. I usually shift around 3k rpm as well. Anyone have any clue as to why this may be?
larryt1026 is offline   Reply With Quote
Old 08-10-2010, 01:20 PM   #8
crazz28
crazz28's Avatar
Drives: '10 Camaro SS/RS, '10 GMC Sierra
I had the same thing but replace the tranny fluid with Mobil 1 Synthetic ATF. No problems ripping through the first 3 now, way smoother.
CGM/BLACK INTERIOR 2SS/RS LS3 M6
TTi/GMS Twin Turbo, Borla S-Type mufflers, Hurst Shifter
crazz28 is offline   Reply With Quote
Old 08-10-2010, 05:16 PM   #9
BWood
BWood's Avatar
Drives: 2010 Camaro 2SS/RS M6
I replaced the throw-out bearing and it solved all of my crunch issues. There are many threads on this issue with TONS of good info. I had to go aftermarket (Ram) 'cause my dealer sweared up and down it was driver error. The Ram bearing/housing has a longer travel so there is sufficient clutch disengagement. To the OP, you very well may have a thrashed syncro but if the dealer says all is good, you might want to consider this route.
BWood is offline   Reply With Quote
Old 08-10-2010, 05:19 PM   #10
BWood
BWood's Avatar
Oh yeah, I am also a firm believer in going with synthetic fluid in the tranny. The debate rages on about which is the best but I settled on Mobil 1 and haven't looked back!
Old 08-10-2010, 05:44 PM   #11
jeepguy_1980
I haven't taken it to the dealer yet, b/c I ran a wire through the shift boot and I don't want to give them the opportunity to blame the wire for getting in the way. I plan to re-run the wire and replace the shift boot before I take it in.
Old 08-10-2010, 06:42 PM   #12
BWood
BWood's Avatar
What's the wire for anyway?
Old 08-10-2010, 08:42 PM   #13
jeepguy_1980
QTP cutouts.
But they are in no way related to the felling I get when shifting.
Old 08-11-2010, 01:26 AM   #14
TAG UR IT
TAG UR IT's Avatar
When I go in to get my next oil change, I'll have them change out the tranny fluid with this as well. We'll see what happens. I'll ask them about this and see what they say.
Questions about shifting and something about moving on 1st gear w/o hitting the gas sheila65 5th Gen Camaro SS LS LT General Discussions 44 06-05-2010 04:39 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Strange shifting Auto v6 & fluctuating tachometer kga10734 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 11 02-12-2010 08:57 PM
