| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
#51 | |
![]() ![]() Drives: 2013 1LE on order TPW 12/31 Join Date: Jan 2010
was there any two side tape also holding the spoiler
#52 |
Thanks....took the car to the dealership today for them to look at it. It's scheduled to go in next Tuesday for the repair.. The body shop manager said there would be no problem fixing the paint chip and pin stripe and should only have the car one day. My only issue, is he couldn't promise me it would look perfect. I told him he better put his best guy on it....or I'm leaving it there until it is..LOL |
#53 |
![]() Drives: 2010 SS - Transformer Edition Join Date: Aug 2010
Well, after about 2 weeks of just camping on the dealership's butt, they finally fixed my car. I have had it back for about a week and all looks good. GM needs to get off the dime and stand behind their products and not give us, the comsumers, such a time about fixing their mistake.
#54 |
Just took a peek last night along the edges of my spoiler and guess what i found lol?! Cant wait for this headache to go along with my notchy grinding 6speed transmission should be a fun day at the dealership next week.
#55 | |
. I kept an eye on mine from the day I got the car......was looking good..thought I may be in the clear.......and then POWW!!![]() Good Luck next week! |
#56 | |
Glad all is looks good. And yes, I agree with you; they shouldn't give us such a hard time about fixing something we paid a pretty penny for and that's under warranty. |
#57 |
Voodoo Medicine Man
Drives: Black 2SS with RS package Join Date: Jul 2010
UPDATE:
My chip is back under the rear spoiler after the nuts being tightened "correctly" and the paint touched up at the dealer... Trying to decide what I want to do....
#58 | |
![]() Drives: without a license: ss 6m Join Date: Dec 2009
when I drive past the kids,
they all spit and cuss. cause I've got a bitchin' camaro and they all ride the bus! Dead Milkmen |
#59 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '12 SS/RS LS3 IBM Join Date: Dec 2009
It will need new rubber washers on the studs to correct the clearance issue. The problem they caused was tightening the nuts squished out the very soft OE washers and the gap was lost. This time they need to use loctite, not heavy torque on the nuts. And watch the gaps as tightening to make sure it is coming no where near contacting the deck lid. And repaint the decklid, new badge, new stripes... I got my rubber washers from ACE hardware, 20 cents each. Luckily caught mine before it chipped the paint. You don't want to use plastic washers. Rubber is needed - for a water seal and to cushion against the paint. The rubber cushions around the edge are single sided. Last edited by Russell James; 08-27-2010 at 09:42 PM. |
#60 | |
got any pics of the rubber washers, also you think getting another set of oem washers and putting them on will help should i do this immediatly after taking delivery and what should i be looking for when i do take delivery sorry for so many questions thanks
#61 | |
You can shine a flash light all around the spoiler edge and see in there the rubber strips and rubber washer/gasket it is sitting on. If the nuts that hold it on are tightened too tight, it will squish that rubber down and the outside edges will be touching paint to paint. It is pretty obvious when you look at the corners. You just need to be able to see a little gap. If paint is touching paint, it's going to chip. |
#62 |
The washers I bought at the hardware store are the exact size of a nickel, but with a hole. Take a nickle in with you, and look for a washer tray labeled - rubber washers. You'll need 6.
Only needed if your spoiler is touching the decklid paint to paint. If you have a slight gap everywhere, no need to mess with it. When you pop it off, you'll see the oe rubber washers are squished around the studs. Scrape those off and put in the new washers. Then when putting the nuts back on with loctite, watch the gaps and don't get the nuts so tight that it kills the gap. The loctite will hold the nuts, they don't need to be super tight. Magnetize your socket so you don't drop the nuts down in the trunk. You'll need a trim tool to pop off the push in retainers on the trunk trim. I think 4 of the access holes just have rubber plugs over them. Then to get at the two inside holes, the trim need to be removed by popping out all the push pins with the trim tool. After all 6 nuts are off, carefully pull straight up. The spoiler will have one - push in - retainer still holding it to the decklid. Just pull carefully straight up and it will pop off. You have to be real carefull, you don't want the studs bouncing around the paint. Two hands - pull straight up. When the 6 nuts are off, you'll wonder what is still holding it on. It's just needs to be firmly pulled straight up. |
#63 |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
i have a black ss/rs... same paint chipping bullshet... i'm going back to the dealer for the 3rd time, this coming Monday, to have this issue taken care of.
i have had about 17 different problems with my car. most were minor problems. but i have been down to the dealer multiple times to have my issues resolved, and i'm getting tired of it. |
#64 |
russell james- so there should be a gap just on the ends of the spoiler or a gap from the entire length of the spoiler from end to end thanks
#65 | |
The back edge is hard to tell, but if you look real close with a flash light you should see the slight gap. Toward the ends there are rubber strips that it is sitting on just in from the outer edge. The best way to put it is if you can see paint touching paint, it's too close and needs to be worked on before it chips the paint. You can slide a piece of paper in there to be sure, toward the end it won't go in far because of the rubber strips. But if you can't get paper between the edge, it's touching. On my back edge right above the SS emblem is my tightest spot. I can slide a piece of paper in there 1/4 inch and then it hits the rubber stip. Draw a line 1/4" in from the edge of a piece of paper and slide it in there. You should be able to feel it stop 1/4 " in as it hits the rubber strip. If you can't get the paper past the edge at all, too tight. I'm going to work on mine a bit more to get a hair more gap there, probably just need to loosen the outer nut up a hair more and re-loctite it. |
#66 |
are these good gaps first two pics rs car next two ss
#67 |
#68 |
#69 |
#70 |
![]() Drives: 2010 1LT/RS Join Date: Nov 2008
... just noticed mine, this morning... 3k miles and 3 months... arrgghhhh !!
#71 | |
![]() Drives: 2012 2SS/RS Join Date: May 2010
to remove the spoiler. Many thanks. |
#72 |
![]() Drives: 2010 Black 2SS/RS M6 Join Date: Oct 2008
Remove the 4 liner fasteners and pull off the plastic latch cover. You can now pull back the center part of the liner to get at the 2 spoiler nuts.
#73 | |
#74 |
Update:
Dropped my car off at the dealership body shop yesterday. I called today to get an update and the shop manager said once they got my spoiler off they found more paint chipping. I did notice before I dropped it off that the clearance between the spoiler and trunk was alot tighter on the right side where the chipping occured rather than the left side. I made sure to tell the body shop manager I wanted a rubber washer installed and to be sure both sides of the spoiler have the same distance between the spoiler and trunk. I hope they get it right....We'll see what she looks like when I pick her up tomorrow afternoon.
#75 |
![]() Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
You have Red Stripes right? Mine does too and they were applied at the factory. I hope that goes well.
2010 Blk/Blk RS/2SS w/CGM Stripes 5% tint
ADM Performance H/C/I M6 3.91s 479rwhp 435rwtq |
| Tags |
| chip, paint, spoiler |
| Thread Tools | |
| NEED opinions! About paint chip repair. | zlwebb | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 35 | 01-18-2012 09:37 PM |
| Paint your own stripes? | blackZbandit | Cosmetics and Lighting Modification Discussions | 44 | 09-18-2011 09:22 AM |
| Adam's Polish & Car care Products | Charlie@STILLEN | Wash/Wax/Detailing and Cosmetic Maintenance Parts | 50 | 04-01-2010 03:28 PM |
| touch up paint and chip warranty coverage? (pics) | traip93 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 14 | 08-21-2009 09:49 PM |
| Help! Need advice on paint chip on roof of new Camaro. | Mcbug | Camaro Price | Ordering | Tracking | Dealers Discussions | 5 | 06-24-2009 08:29 AM |
