Flowmaster Exhaust
Old 07-18-2010, 09:31 PM   #1
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
Who's broken an A6 tranny?
as the title says....
I very rarely get on my car simply because we don't have enough open roads where I live. so today I got on my car and it did something weird. it shifted fine in 1st, 2nd and 3rd. but then it kinda slipped in 4th which is something I never noticed before. the shift wasn't as firm as the first three gears.
I was able to reproduce this instance multiple times. I'm wondering if this is a sign of a dead A6 tranny on the way?
what do u guys think?
bumblebeecamaro is offline   Reply With Quote
Old 07-18-2010, 10:15 PM   #2
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
List your modifications, if any.
StlRomAniaN is offline   Reply With Quote
Old 07-18-2010, 10:44 PM   #3
I tap shift the hell out of mine and no problems at all.
Old 07-18-2010, 11:59 PM   #4
bumblebeecamaro
Car Lover By Nature
my mods? to put it simple, it has a Maggie 2300 with L/T headers.
Old 07-19-2010, 12:21 AM   #5
StlRomAniaN
Tapshifting won't do anything to the tranny. GM put it there for a reason, no harm.
But, with that much power going through it, the clutches are probably worn out. You can get it rebuilt and you won't have to worry about anything then! I was quoted for $2,700. They'll even modify the manual valve body or whatever to allow higher line pressure, which eliminates a lot of any delay you're experiencing with tapshift.
Anyways, get it checked out and just build it up. Abuse it as much as you want then.
Old 07-19-2010, 12:56 AM   #6
GrinderSS
Drives: IOM 2SS/RS
It could be as simple as the transmission filter being clogged. Get the transmission serviced and a new filter installed.
GrinderSS is offline   Reply With Quote
we added some extra protection from the FL heat for my A6 tranny (pics inside) bumblebeecamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 38 12-29-2012 01:11 AM
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 09:25 PM
Car got broken into omerc10696 USA - NY / NJ / PA 20 02-01-2010 08:37 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 10:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 02:28 AM
