Emblempros
Old 07-19-2010, 04:55 PM   #1
JustinTXranger
JustinTXranger's Avatar
Drives: 2010 Black LS3
back pressure
ok so all i ever hear nowadays when i talk about upgrading my exhaust is that its gonna mess with my back pressure. ive already done a muffler delete but i also put in a CAI and so far so good. im thinking my next project is gonna be a set of headers and an x-pipe (nonresonated because i like the drone) but i dont really know wat to do about the cats? im not really worried about emissions or anything because i live in texas and i know people who can inspect my car for me. but i am worried about wat it will do to the back pressure if i take them out along with adding headers and the xpipe. can a tuner eliminate this problem? and correct me if im wrong but doesnt the ls3 has 2 cats on each side? could i just remove 1 set of cats and still keep a little backpressure? haha i know its a lot of questions so just whatever u know will help
JustinTXranger is offline   Reply With Quote
Old 07-19-2010, 05:28 PM   #2
SK360
Drives: 2005 Pontiac GTO
You want the freest flowing exhaust possible, wanting backpressure is a myth.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
SK360 is offline   Reply With Quote
Old 07-19-2010, 06:18 PM   #3
ssmike
Missing Big Red
Drives: '13 Equinox CRT
Except when using a supercharger, you'll need to increase boost or change the pully size when using a freeer flowing exhaust, as I understand it.
Old 07-19-2010, 06:44 PM   #4
JustinTXranger
but ive heard of people removing certain parts of their exhaust and losing substantial amounts of power?
Old 07-19-2010, 06:51 PM   #5
jagssrsbeast
Drives: inferno orange ssrs
back pressure is a myth
jagssrsbeast is offline   Reply With Quote
Old 07-19-2010, 06:56 PM   #6
SK360
"Boost PSI" is a measure of restriction. When you open up the exhaust you will see lower PSI but the engine is still ingesting the same amount of air.
Old 07-19-2010, 07:07 PM   #7
JustinTXranger
so headers, no cats, xpipe, and no mufflers will go pretty good with this car?
Old 07-19-2010, 07:08 PM   #8
SK360
I run Longtubes, no cats, X Pipe and straight through Magnaflow mufflers, and my car is def not lacking power
Old 07-19-2010, 07:10 PM   #9
JustinTXranger
haha well i definitely like hearing that
Old 07-19-2010, 08:16 PM   #10
Skoulikimou
Skoulikimou's Avatar
Drives: Camaro SS LS3 2010
this in my future planned mode plus the CAI
Skoulikimou is offline   Reply With Quote
Old 07-19-2010, 08:28 PM   #11
JustinTXranger
about how much power do u think an exhaust similar to that would add to the camaro when its coupled with a cai but no tune??
Old 07-19-2010, 08:49 PM   #12
SK360
Maybe 20-30rwhp? Not sure...
Old 07-20-2010, 01:53 AM   #13
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
As was stated earlier. Your boost goes down because your exhaust is less restrictive. The SC is still churning the same RPM, thus pushing the same amount of air or a little more since it's now more efficient. This means you should be making the same or more HP. Boost pressure doesn't equal HP. People up their pulleys to keep the boost pressure up but also get a bit more HP from doing that.
A catback yeilds relatively nothing in terms of HP. You may gain a few HP from the Xpipe but that's about the only place to make HP over the stock exhaust. In OEM form, it's 2.5in pressbent, but very few bends and no hard bends. The mufflers are straight through design so there's no restriction there either. If you want a more aggressive sound, get a catback or axleback. If you want power, get LT's with no cats or highflow cats, or keep the stock manifolds and get high flow cats or delete them. It's been shown by a trusted vendor here that there was no difference in HP gains from high flow cats vs no cats.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-20-2010, 08:03 AM   #14
ssmike
Missing Big Red
Thanks for the supercharger clarification!
backpressure, exhaust, headers, tuner, x-pipe
betcha ain't nobody doing this... zebra Member Car Journals 53 09-06-2010 10:24 PM
Muffler Delete? phenixdragon Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 07-04-2010 12:48 PM
Correct tire pressure Heelhook22 Wheels and Tires Talk Sponsored by The Tire Rack 34 12-21-2009 05:07 PM
Cutouts and Back Pressure Camaro007 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 05-26-2009 10:34 PM
The perfect background song for the first Camaro TV commercial...Get Back! Rob53 5th Gen Camaro SS LS LT General Discussions 44 01-12-2009 06:53 PM
