Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Caryle Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-20-2010, 05:15 PM   #1
Drives: 2014 2SS/1LE
Help with Codes
My CEL came on today. I scanned the codes and cam up with these.
P0420-Catalyst system efficiency below threshold Bank 1
P0430-Catalyst system efficiency below threshold Bank 2
P1133-Bank 1 Fuel control shifted lean (FAOSC) (see pg. 2096)
P1153-Bank 2 Fuel control shifted lean (FAOSC) (see pg. 2098)
I have LT headers and a tune. What would cause this? I thought maybe a bad O2 sensor, but both banks are bad. I lowered the car and recently rubbed the exhaust on a speed bump. I think this may be th ecause but what component is the issue? It doesn't sound like there are any exhaust leaks. Thanks.
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 07-21-2010, 10:17 PM   #2
busaboy's Avatar
Drives: Black RS/SS M6
With both banks showing a problem it has to be system wide. Something that will effect the engine as a whole. I do wonder if you may have a slight exhaust leak.
I have seen exhaust leaks that will make very little noise and will draw air into the exhaust throwing the computer off.
How long have you driven the car after the tune? Who did the tune?
busaboy is offline   Reply With Quote
Scangauge II Xgauge codes gahammerle Tuning / Diagnostics -- engine and transmission 0 06-19-2010 04:54 PM
Clearing O2 codes ROD1 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 6 06-04-2010 08:56 PM
Maggie 2300 Codes P0068 and P0108 95droptopZ Forced Induction - V8 22 04-28-2010 02:46 PM
4 ENGINE CODES bzy-man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 04-01-2010 09:05 AM
Confused - Transmission Codes camarosource Off-topic Discussions 0 09-21-2009 05:30 PM
