Rick@Livernois
Old 07-20-2010, 06:29 PM   #1
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Strengthened Driveline
OK, we all see that there are some problems with the driveline. That makes me HESITATE to upgrade. Lets get the best minds together--WHAT IS THE 99.9% solution to having a bulletproof driveline at the 750 HP level? Jannetty, ADM, Lingenfelter, etc, GIVE IT YOUR BEST SHOT!! What and how Much!! Thanks!!!
BoostedX2 is offline   Reply With Quote
Old 07-20-2010, 09:57 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Supporting mods are always necessary, no one builds their cars to handle double the factory power numbers. GForce 4340 axles and a clutch upgrade would be the first two things I would look into.
Old 07-21-2010, 04:55 PM   #3
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
If you want to do it once and do it right give us a call,we have a bolt in 9 inch irs system that goes in like factory and will hold all the power you can throw at it...
Hendrix-Engineering is offline   Reply With Quote
Old 07-21-2010, 07:02 PM   #4
flyby
Drives: 2010 Silver SS
Please PM me I need one ... mine is in the shop at tune time in NJ...
flyby is offline   Reply With Quote
Old 07-22-2010, 04:11 AM   #5
BoostedX2
BoostedX2's Avatar
Please PM with price...Thanks!
Old 07-22-2010, 09:04 AM   #6
Hendrix-Engineering
Hi Guys
We have sold out the first run but we will have 12 more ready in about 30 days.If you would like to get one out of that run please give me a call so we can get you on te list.This will require a deposit...I will try to start a thread and post pictures up asap...Thanks guys
Old 07-22-2010, 10:02 AM   #7
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Pm me a price please
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 07-22-2010, 12:34 PM   #8
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Here are my thoughts on a bulletprof upgrade to handle 750 flywheel HP MAX:
Level I upgrade:
I would obviously go with a new clutch, probably the RAM, upgraded tranny fluid, and 1000HP axles.
If you have any thoughts of really beating on the car or upping the power to a higher level:
Level II:
RAM clutch, fluid upgrade, cryo tempering of the trans internals, poly couplers, 1000HP axles...and if you plan on changing gear ratios I would use an entire new housing like the 9inch.
That is my thoughts. In case you wonder why I said RAM... I have tried a coupel clutches and so far the RAM holds like crazy and it drives like stock. I am also running amsoil fluid, and fidanza clutches in case anybody was curious... I am not just making this stuff up, I am using it!!
ZZcamaro is offline   Reply With Quote
Old 07-22-2010, 04:13 PM   #9
BoostedX2
BoostedX2's Avatar
Level I upgrade:
Level II:
So in general, you believe the stock ring and pinion is up to the task <750 hp? I did a 4.10 Gear swap, I know a FEW folks had some issues but mine sems stout. Thoughts? I just want it to be just about as reliable as stock with a few mods at the 500-600 hp level... Thanks for your input!!!
Old 07-22-2010, 07:58 PM   #10
jrpxxii
jrpxxii's Avatar
If you only have 500-600 rear wheel horsepower, then you really only need axles and a clutch. If you want to make sure you eliminate wheel hop which will break things quickly, replace toe rods, trailing arms and bushings. As far as driveline goes, with that power level you are fine with axles and clutch. I had 850hp to the rear wheels and replaced all that I have mentioned and nothing broke. I am now going up in power ALOT more and will be replacing driveshaft, trans and rear diff completely. 500-600hp in these cars is easy to achieve and alot of the problems people have breaking stuff is from driver error such as dumping the clutch and wheel hop which will snap stuff like pretzels.
Old 07-22-2010, 10:59 PM   #11
busaboy
busaboy's Avatar
Drives: Black RS/SS M6
A spool will handle so much more.
busaboy is offline   Reply With Quote
Old 07-30-2010, 11:22 AM   #12
flyby
Yeah, a spool will handle a lot of horsepower but try and corner with it
Old 07-30-2010, 12:55 PM   #13
fastfaster
Drives: xxxxxxxxxxxxxx
I Have 742 HP At The Rear Wheels With Stick Shift. My "Jannetty Racing" Differential Has A Wonderful Relationship With The Big Horsepower.
I Would Give You Details Of The Jannetty Racing Differential, But I Was Sworn To Secrecy (Its An Italian Thing ).
fastfaster is offline   Reply With Quote
Old 07-31-2010, 12:39 PM   #14
GFORCE1320
Drives: 05 GTO
Our 4340 race axles will handle 750hp no problem.
You could also up-grade to our 300m axles if you want something that you won't ever have to worry about down the road when you start putting down 1000+hp.
We also have spools and big 35 spline stubs if your not worried about street driving everyday.
We will have our 9" IRS done soon too. Lots of options under one roof
Give me a call if you have any questions 316-733-2100
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Driveline noise/clunking SS2w/aSCREW V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 08-23-2012 07:07 PM
Who has the most power on stock tranny and driveline Jeanius Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 04-14-2010 12:04 AM
Driveline for dragging Ivas V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 02-05-2010 07:20 PM
Driveline noises Sajonf 5th Gen Camaro SS LS LT General Discussions 14 09-10-2009 06:46 AM
