V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 04-11-2012, 09:19 PM   #451
Orange Krate
Simply Orangasmic!
Orange Krate's Avatar
Drives: Orange Krate DOB - 11/22/2010
**Orange Krate Update**
Hi folks,
I just wanted to give you a little update on my 2011 LS3. The car now has 8900 miles on it. I installed a Skip Shift Eliminator to see if that might help. Indeed it did make the car seem easier to shift but there is still the notchy feeling and I am now having intermittent issues getting the car to go into reverse. The trans will go in reverse at times partially. It feels like it is in reverse and I hear the back up sensor beep in dash, I let out the clutch and GRIND! It isn't in gear and the stick pops out of whatever it is trying to slide into. It is so strange because the only thing I can compare it to is when the old manual adjustable shifting arms on my M22 Muncie were out of adjustment I would get the same sort of partial engagement and grind. My guess is that the clutch isn't fully released due to loss of pressure or failure to disengage the pressure plate. If it were a M22 I would know what to do. The trans would be out and on the table getting all new goodies if the shifter adjustment rods didnt cure the problem. Will go back to the dealer and I am calling the Chevrolet Customer Service line.
Orange Krate is offline   Reply With Quote
Old 04-12-2012, 12:38 AM   #452
bcarkle
bcarkle's Avatar
Drives: '11 1SS M6 "SOLD" & '70 Chevelle
Originally Posted by Orange Krate View Post
I've read that it is a Tremec 6060 MG9 such as seen here:
http://knudtsenchevyblog.com/tremec-tr-6060-mg9/
I guess we won't really know until the roll off the assembly line.
This is funny I seen this post, This dealership is right down the road from me. Awesome.
2011 1SS "SOLD", 1970 Chevelle Blown Rat
bcarkle is offline   Reply With Quote
Old 04-12-2012, 10:32 AM   #453
TJeezey
Drives: 2011 SS/RS M6
Hi folks,
You may have installed the skip shit eliminator into the reverse lock out. It is a common mistake (I know from experence. haha). The correct spot should be slightly above (and maybe towards the rear) the reverse lock out spot (more harder to reach) if I remember correctly.
2011 IOM SS/RS M6 w/Hurst. C.A.I. inc Intake, Borla ATAK catback, ARH LT's with HFC, Vmax TB, Apex Scoop, 91 oct Jannety Tune
TJeezey is offline   Reply With Quote
Old 04-12-2012, 12:36 PM   #454
elegalR1der
elegalR1der's Avatar
Drives: '11 LS3
Here's a copy of the parts on order
elegalR1der is offline   Reply With Quote
Old 04-12-2012, 01:53 PM   #455
elegalR1der
Drives: '11 LS3
Looking back on Rick's post, looks like they ordered the new carbon blocking ring, so it seems like there may be a tsb out
Old 04-12-2012, 09:42 PM   #456
Orange Krate
Simply Orangasmic!
Actually you can see the install on my "The Birth of Orange Krate" journal. It is in the right spot. I had the problem with reverse both before and after the install. The shifting is better with the SSE installed but...big but... it is still grinding, it has the inherent notch as many have indicated in this thread, and it is regularly irregular which makes it hard for any shop to diagnose or duplicate. I drive a stick all day long! It is not me. As for the SSE, my install photos and DIY instructions for the SSE are now being incorporated into the product's factory instructions! They liked it that much.
Old 04-12-2012, 09:51 PM   #457
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
calbert1999 is offline   Reply With Quote
Old 04-13-2012, 09:14 AM   #458
TJeezey
My bad! That was a common symptom of a wrong SSE install so I might have thought that was the problem. Grats on the instructions!
Old 04-25-2012, 04:34 PM   #459
Dr. Krabz
Drives: 2011 2SS/RS Victory Red
Hey guys, not sure if this is still an active post but I would like some advice if anyone wishes to give it. I bought my 2011 Camaro in November and it spent a good bit of time in the garage so I just started to notice the issues discussed in this thread recently. It has been to two different dealers for a transmission related problem in the past, with a documented case on file with Chevrolet customer service. The original issue I was having related to an ungodly "shuttering" noise that the trans would make when it was under any kind of load in 1st gear and the clutch was pushed to the floor (such as slow speed parking lot maneuvering). Both dealers claimed this was a normal condition, but I find that hard to believe.
Now my car is starting to make noise when completing a 1st to 2nd gear shift, almost like the ones seen in these videos but not as severe. Keeping in mind that my car has less than 3000 miles on it, I think it is safe to say that the problem will only get worse. I am about to take this car back to the dealer soon to try and remedy this situation, I am not looking forward to the constant bickering that I assume will follow with them trying to tell me this is a normal condition once again.
Does anyone have any specific tips on how to handle this? I have been driving a manual transmission car all my life with no problems so I know this is not a normal condition or a case of operator error.
Thanks in advance!
Dr. Krabz is offline   Reply With Quote
Old 04-28-2012, 08:11 PM   #460
mstanford.us
Mark Stanford
Drives: Black 2010 SS LS3
5 qts of Redline D4 ATF really helped my M6 shift more smoothly. Especially noticeable at the strip. Amazon.com has it. My cold 1-2 shifts are greatly improved as well.
Mark Stanford
2010 1SS M6 456rwhp, 418 torque
www.Midwestracing.net
CAI Inc, Kooks 1 7/8" 3"catted + mufflers, Livernois stage 2B cam (230/240, .591"/.608" int/exh), Custom Dyno Tune, Libertyville Chevrolet (IL) by Kevin Paddock, Nitto NT05R P315/35R20 on 20X10 American Racing Torque thrust rims, BMR trailing & toe rods. Centerforce DF clutch.
mstanford.us is offline   Reply With Quote
Old 05-07-2012, 01:04 PM   #461
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Just had my 2011 SS M6 in for the Mass yearly inspection I also reported the 1st - 2nd grind with my trans, took the tech for ride and replicated the 1st to 2nd gear grind
so it's now documented with my dealer, he's following up with GM to see what can be done.. Car 100% stock.
waiting on a call back.. we will see
RogerBzSS is online now   Reply With Quote
Old 05-08-2012, 06:17 AM   #462
Dr. Krabz
I think this is a bigger problem than GM may realize. Anyone who is having this problem should come forward and say something to their dealer. If enough of us are having these issues, GM will be forced to do something.
Old 05-08-2012, 06:36 AM   #463
Stealth6
IN OMNIA PARATVS
Stealth6's Avatar
Drives: 2011 BLK 2SS/RS LS3
Something like this could force them to issue a massive Campaign..... It would not look good for them as far as negative publicity and $$$. And that is probably why they're in "denial".
Stealth6 is offline   Reply With Quote
Old 05-08-2012, 06:49 AM   #464
Dr. Krabz
I agree but I know that if they keep giving me the run around about it being a "normal condition" I am going to begin the process of seeking lemon law protection. I am tired of making constant trips to the dealer only to have them say it is normal, like it is my fault somehow. They can try and play hardball (and lose) or they can man up and fix the issue. I highly doubt a Corvette owner would be pushed aside like this and told over and over that it is normal.
Old 05-08-2012, 01:43 PM   #465
Stealth6
IN OMNIA PARATVS
Stealth6's Avatar
Doc, I couldn't agree with you more...
Old 05-08-2012, 02:54 PM   #466
RogerBzSS
RogerBzSS's Avatar
Just got a call from my SM from my Dealer, they are looking to replace transmission part #'s and have them on order.
19259991
19256242
19256241
Roger
Old 05-08-2012, 08:27 PM   #467
RogerBzSS
RogerBzSS's Avatar
As thought I wondering if the Zl1 will have this same issue. ??
Old 05-09-2012, 02:04 AM   #468
Stealth6
IN OMNIA PARATVS
Stealth6's Avatar
19259991
19256242
19256241
Roger
Looks like the Rings and Synchronizers.
Roger, any chance of a PM as far as which dealership is taking care of this for you....
Thanks.
Old 05-09-2012, 02:06 AM   #469
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
2 trips to 2 different dealers and I get the same response. The 1st tech it was a could not reproduce. 2nd tech at the 2nd dealer sees me standing on the clutch pedal and notices the extra effort to shift at RPMs above 4k and the grind. But because Chevy says it's not an issue, the dealer can't do anything for me. To top it off, I get a call from customer service telling me sorry but it is what it is and can't control how I drive my car. Yeah that call got my blood boiling...
MiSTER is offline   Reply With Quote
Old 05-10-2012, 01:27 AM   #470
partymn
partymn's Avatar
Drives: Chevy Camaro SS
Sounds bad, but its comforting knowing that everyone is getting the same response from the dealers and GM Customer Service as I am.
2011 2ss M6 Turbo
partymn is offline   Reply With Quote
Old 05-10-2012, 12:08 PM   #471
Dr. Krabz
Well I just got done with the dealer, they told me that there is nothing that can be done until my problems get worse. Their fear is breaking down the transmission and not being able to find anything to bring back to GM, thus not getting paid back for their time and effort. The only assurance they could offer was reminding me that it has a 100k mile powertrain warranty and they will replace the transmission if need be. Call me a conspiracy theorist, but I think GM corporate is really behind this pushing on the dealers to cover it up. I think this will be a long fight and may result in legal action.
Old 05-10-2012, 01:14 PM   #472
partymn
partymn's Avatar
Set the parking brake, traction control on, and dump the clutch, while in second gear, at 3500 RPM. Something will brake, Guaranteed.
2011 2ss M6 Turbo
Old 05-13-2012, 01:59 PM   #473
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: 1997 SS, 2013 ZL1, 2008 TBSS
Well with just over 9000 miles on my 2010 SS m6, I really ran into this problem yesterday. 3 good runs in the 1/4 mile and the next 4 times blocked me out of 2nd and made me feel like an idiot. The last time I was at the dealer they said my cold air intake and headers were going to void my warranty in the future.
2013 ZL1 .. 1997 SS .. 2008 TBSS
Jer4251 is offline   Reply With Quote
Old 05-13-2012, 04:43 PM   #474
Orange Krate
Simply Orangasmic!
I can assure you GM/Chevrolet is very aware of this issue. I received a private email stating as much.
Some of you may be too young to recall but back in the early 90's Ford Light Truck division had a problem with their newly released E4OD 4 speed autos. This replaced the old reliable C6 3 speed auto. It was specifically in diesels and 460 gassers. It got so bad that new transmissions were failing driving off the lot. I had a fleet and lost 6 of them in short order.
Ford started a huge campaign and just swapped them out 1 for 1. The transmissions were shipped in plastic banjo cases. Our local dealer had a RACK of them and it was a small dealer! This is what will happen if GM doesn't get their arms around this because history repeats itself!
As for a fix? Swap them out with the ZL1 trans setup and problem is solved.
Simi Valley, CA
email: orangekrate2011@yahoo.com
Old 05-13-2012, 04:46 PM   #475
Dr. Krabz
The only way i see this getting fixed is if we are all vocal about it. We need to be in contact with gm customer service and not stop until the issue is resolved.
Tremec Shifter Knobs omegaman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 12-28-2012 04:38 AM
Shifting into 1st VERY notchy with short throw robertway V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 08-28-2010 08:18 AM
HPTuners - Shifts (A6) question RickyTheStorm Tuning / Diagnostics -- engine and transmission 2 11-21-2009 10:19 PM
So we get stuck with low end Tremec? camaroguy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 07-16-2009 05:30 PM
