Old 07-22-2010, 01:09 PM   #1
barrylnv
barrylnv's Avatar
Drives: 2010 2SS IMB LS3/M6
Wheel Widening and Spacers - Help Needed
I know there have been many posts on this and I have searched and pretty well read through them all. I am still a bit confused and looking for concrete answers from those that have done what I want to do.
I want to send my 20"x9" rear wheels to either Vaughn or Weldcraft to be widened to either 10.5" or 10.75". My question is since this is entirely backside widening, do I need to run a spacer and if so how much? The tire I will run is a Nitto 315/35-20.
I know some have done this with front wheels but I want to keep my fronts as is and use the existing rears for this. Any help is appreciated!
2010 2SS LS3/M6 Imperial Blue
650HP LPE Package - 576.3 RWHP, 91-tune
4.10 Richmond Gears
ZR1 Clutch / LPE Flywheel
LPE IBM Coil Covers
Thorley Shorty Headers
Borla 140280 Cat-back
ADM Boost Gauge
MTI Shifter
Hotchkis Sway Bars
LPE Floor Mats
SRP Heel-Toe Pedals
barrylnv is offline   Reply With Quote
Old 07-24-2010, 04:10 PM   #2
barrylnv
barrylnv's Avatar
Bump - any help, anybody?
4.10 Richmond Gears
LPE IBM Coil Covers
ADM Boost Gauge
MTI Shifter
Hotchkis Sway Bars
LPE Floor Mats
SRP Heel-Toe Pedals
Old 07-24-2010, 05:34 PM   #3
icemann427
icemann427's Avatar
Drives: 1965 Mustang; 1987 Porsche 930
Barry,
It's been a while since I have seen one of the "wheel widening" threads, but there are quite a few of them out there so you should be able to find them. Do a search using the word "ADM" or "Weldcraft" and you should be able to find one relevant to you.
I can't remember exactly, but I believe you will have to use a spacer to widen them to their widest width (11") and to use the 315 mm tire. It also depends on how aggressive of a stance you want...More stock or more aggressive. Here are a couple of pictures of a Camaro 5 member's car where he used 1" spacers on the front and back of his car behind his painted stock rims. I can't remember if he widened his rims, but I think his Camaro's stance is outstanding.
I just did a quick look for you and found another thread where the member does exactly what you are asking about. He talks a little about how wide you can go without spacers, too...So this should be helpful. http://www.camaro5.com/forums/showthread.php?t=62599 Good luck!
icemann427 is offline   Reply With Quote
Old 07-26-2010, 02:21 PM   #4
barrylnv
barrylnv's Avatar
Thanks Iceman, I had read that post and had inexplicably skipped over the fact that he didn't use spacers. Guess I was up too late reading that night, haha! Thanks again, that does answer my questions. Agreed, that black Camaro's stance is sweet!
4.10 Richmond Gears
LPE IBM Coil Covers
ADM Boost Gauge
MTI Shifter
Hotchkis Sway Bars
LPE Floor Mats
SRP Heel-Toe Pedals
Old 07-26-2010, 02:31 PM   #5
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Andy at ADM Performance did mine for me. Moved the rear wheels and 275 tires up front with no changes, and widened the stock front wheels (moved to the rear) to 10.75". Running a 305 tire and using a 1" spacer.
Currently in the fleet... 2010 ZR1 Corvette, 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 07-26-2010, 08:13 PM   #6
GrinderSS
Drives: IOM 2SS/RS
Barry,
I just received a set of wheels back from Weldcraft that I had widened. It took them over 9 weeks and in the interim I lost patience and ordered a set of forged wheels. So, if you're interested in buying these let me know. I'll take the cost of the widening for them, which is $1000.
Here are some pictures, one of which is the part number to the adapter/spacer you'll need for them.
http://picasaweb.google.com/10416514...eat=directlink
GrinderSS is offline   Reply With Quote
Old 07-26-2010, 08:46 PM   #7
GrinderSS
Drives: IOM 2SS/RS
The problem with moving the rears up front is that they have thicker spokes than the front rims. I wanted to keep the subtle difference between the front and back, which is why I had the fronts widened by 1" and the rears widened by 2".
Old 07-26-2010, 11:51 PM   #8
Jay J
Prince of Zamunda
Drives: XW30
1" that's like a 25mm spacer? O.o?
Jay J is offline   Reply With Quote
Old 07-27-2010, 10:22 AM   #9
GrinderSS
Drives: IOM 2SS/RS
20mm adapter is ideal for rear wheels widened by 2".
Old 07-27-2010, 12:38 PM   #10
Jay J
Prince of Zamunda
Drives: XW30
Wait you guys are cutting your wheels to widen them and using spacers? *uhoh*....
Old 07-27-2010, 12:46 PM   #11
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
wheel widening has been around for years upon years.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 07-28-2010, 07:52 PM   #12
Jay J
Prince of Zamunda
Drives: XW30
DONE DEAL
vs a nice strong wheel built properly:
And here's a testament to how strong these wheels by Work are...The guy that owned this G35 is someone I know...I guess he was racing on the freeway; hit a dip with blown struts going North of 150+mph
The wheels have since been re-built and are on his new car.
Old 07-29-2010, 10:00 AM   #13
danhr
BAMF SS
danhr's Avatar
and how does any of that have to do with wheel widening?
there's a difference between a cracked wheel/bent wheel, and one that has had a precision cut via plasma/cnc program.
Old 07-29-2010, 02:12 PM   #14
Jay J
Prince of Zamunda
Drives: XW30
Try running an eddie current test; its not the same strength. The cracked wheel I had posted a picture of was one that was widened by a reputable source in Socal which will remain name-less....You won't ever be able to have a true-runout wheel with less than 4oz of weight on any wheel that has been cut and rewelded.....
