Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions
Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions Performance driving discussions
Old 07-24-2010, 12:59 PM   #1
d-ball2ss
d-ball2ss's Avatar
Drives: red jewel 2010 camro 2ss/rs
WTF???
i have a cold air intake (K&N) and catback exhaust and i was running at Gate Way in stl MO and the fstest time i got was a 14.2 at 101mph.... its a L99 and my R/T was about.465 wtf... was it the hot weather are what. it was about 96 out when i was racing
d-ball2ss is offline   Reply With Quote
Old 07-24-2010, 01:01 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Reaction time does not affect ET. Hot weather is definitely a factor. Are you experienced at launching/drag racing? If not, that is a HUGE factor. Just cause the car is capable of doing a certain time does not mean that everyone can do it. It takes LOTS of practice.
Old 07-24-2010, 01:15 PM   #3
mlee
H-Town Camaro Club
mlee's Avatar
Drives: Number Twenty-Three
It will get better when you get more miles on the car... Most do run around 14 that I've seen in the heat.
Old 07-24-2010, 01:45 PM   #4
d-ball2ss
d-ball2ss's Avatar
it has 5400 on it and how should i launch with a l99
Old 07-24-2010, 01:50 PM   #5
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
you should definitely be running in the 13's.
2010 SSRS is online now   Reply With Quote
Old 07-24-2010, 02:09 PM   #6
The_Blur
Moderator, USN
The_Blur's Avatar
Drives: 2000 Firebird Formula NHRA SE
Can we see the time slip? The numbers throughout the slip might help us diagnose what happened.
newborn gifts
Old 07-24-2010, 02:09 PM   #7
toehead93
Drives: 2010 SS, 1993 Z28
What were your 60' times?
2SS A6 Black
360 RWHP/382 FTLBS - tune only
Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned
toehead93 is offline   Reply With Quote
Old 07-24-2010, 02:30 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
We need to see your full time slip.
Your 14.2 @ 101 mph run would be 13.5- 13.6 @ 105 - 106 mph corrected. I know the DA's are running well over 3000 ft in your area.
Even with 101 mph trap speed, you should be running high 13s if you get a decent launch (60' time around 2.0). Then your corrected time would be very low 13s @ 105 - 106 mph.
At a 4000 ft. DA your losing around 50 hp from your engine.
Old 07-24-2010, 02:39 PM   #9
SGOS252382
SGOS252382's Avatar
I've consistantly gotten 1.9x sec 60' times with this launching technique in my
L99.
(D -traction control off) or (M - Sport with TC off)
I do not use the tap shifts.
I do a quick burnout to clean off my tires. Then I stage the car. I hold the car on the line with one foot on the gas and one foot on the brake (brake stall). I rev to about 1000 rpms or so, while holding the car in place with the brake. On the last amber/yellow light, I roll into the gas and lift up on the brake.
As mentioned, I roll into the gas. If the track is slippery, I roll into the gas slowly as I lift up on the brake. If the track is sticky, I roll quickly into the gas.
I rarely ever brake stall over 1000 rpms. When I try to brake stall over 1000 rpms (stock tires), I get wheel spin and slower 60' times.
Practice makes perfect. You should be able to get your 60' times down to
1.97 or so even in a stock L99 with a decent launch.
Old 07-24-2010, 03:13 PM   #10
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
Turn the A.C. off...
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 07-24-2010, 04:18 PM   #11
d-ball2ss
d-ball2ss's Avatar
ok here is the time of my best one...
R/T .469
60' 2.180
330 6.123
1/8 9.306
MPH 77.42
1000 12.004
1/4 14.230
MPH 101.32
Old 07-24-2010, 05:19 PM   #12
acatlover13
Emerald Coast Camaros
acatlover13's Avatar
Drives: 2010 2SS/RS Camaro IOM/IO
Send a message via AIM to acatlover13 Send a message via Skype™ to acatlover13
Have you done the fuse pull? I dropped about 8 tenths after the fuse pull (that is when I was stock--if you have a tune, then no fuse pull should be necessary.).
Looking at your "time slip," that is what it looks like you need. I have more experience with 1/8 mile times than 1/4 mile, and with a 9.30 1/8 mile time, you should be in the mid 8's in the 1/8th after the fuse pull.
ECC on Facebook
2010 Camaro SS/RS IOM, IO interior, Custom Striping by Eddie's Autobody, Razzi body kit
ADM CAI w/scoop/Dynatech Headers & Hi-Flow Cats/Solo Performance Exhaust, FTI 3600 Stall/Comp Cams custom grind cam/LS3 conversion/FAST 102 Intake
acatlover13 is offline   Reply With Quote
Old 07-24-2010, 05:59 PM   #13
d-ball2ss
d-ball2ss's Avatar
so do you guys all think fuse pull?????
Old 07-24-2010, 06:09 PM   #14
9c1ny
9c1ny's Avatar
Drives: C6 Zed-oh-six
yeah something is wrong with those times unless you were on top of a mountain
9c1ny is offline   Reply With Quote
Old 07-24-2010, 06:20 PM   #15
d-ball2ss
d-ball2ss's Avatar
yea i have a cold airand exhaust too ok im doing it right now
Old 07-25-2010, 12:07 PM   #16
383ss
Drives: 1985 IROC, 2011 Camaro
I was running the same times in Kansas city a few weeks ago in the same type weather. Mine does not need a fuse pull and I doubt yours does either. Its a combination of the weather and a poor 60'. Get your 60' in the 1.9 to 2.0 range and you will pick up 3-4 tenths. Weather in the 60-70's and low humidity will get you and another 3-4 tenths.
the smartest person on Camaro5! Thanks for enlightening us!
Originally Posted by hsdguru View Post
31000 for ss1 no options and who in the hell would buy a SS1 V6 for kids SS1 for girls LS3 the only way to go G8 Gxp 200lbs more my bad so lets think here 200lb more 27 less hp so 5 tenths slower now 373 gear now mabe 3tenths slower 4 door car sad so so sad
383ss is offline   Reply With Quote
Old 07-25-2010, 12:39 PM   #17
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
You picked up 24mph from the 1/8 to the 1/4 so you're making the power you should be.
Ovenmitt is offline   Reply With Quote
Old 07-25-2010, 02:54 PM   #18
Stl_Camaro
Stl_Camaro's Avatar
Drives: 2008 Equinox, 2002 Trans Am WS6
So, Are you going to Gateway this Tuesday? If so, Ill be there. Ill be looking to see if you get better times
Stl_Camaro is offline   Reply With Quote
Old 07-25-2010, 05:14 PM   #19
cmiller8006
Drives: 2009 Cobalt SS/TC
Off topic, but can the fuse pull be done on the L99 and LS3? If so I need to tell the guys at the track, none have gone faster than 13.3 yet. What fuse to pull as well?
2009 Cobalt SS/TC: 10.89 at 133mph
cmiller8006 is offline   Reply With Quote
Old 07-25-2010, 05:37 PM   #20
Wikedwil
Co-founder of CDCNY
Wikedwil's Avatar
Drives: 2012 Camaro Black LS A6
Do a search on here.........Fuse Pull
Wikedwil is offline   Reply With Quote
Old 07-25-2010, 05:57 PM   #21
DarricSS
DarricSS's Avatar
#5 and #20
Old 07-25-2010, 06:11 PM   #22
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
post time and date of when the run was made at. DA (especially in the middle of summer) plays a HUGE factor. Those could actually be really good times.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Camaro has 1400 km and it leaks oil!!! WTF Ex-stang Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 16 04-20-2010 02:37 PM
Already Rusting? WTF? SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 04-06-2010 01:34 AM
WTF California...WTF? Mindz Off-topic Discussions 71 02-26-2010 03:02 PM
GM CANCELLED MY ORDER - WTF ARE THEY THINKING siliconewolfgang Camaro Price | Ordering | Tracking | Dealers Discussions 32 07-07-2009 11:35 AM
24 hours old,back in shop wtf salvie87 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 06-28-2009 12:10 AM
