Caryle Racing
Old 07-24-2010, 05:39 PM   #1
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
Question Fan problems after replacing thermostat
So today I replaced my stock thermostat with the SLP 160 degree thermo. Never had any cooling problems before. Filled back up with Dexcool 50/50 exactly like directions (already pre-diluted). Within 10 minutes of driving, my car is overheating, got high coolant temp alert, then a/c turning off due to excessive engine heat, then engine overheating--idle engine, which I did and eventually made it back to the house. lucky I was only a few minutes away.
The fans didn't come on until the coolant temp was up in the 230's! I let it cool down and it just kept creeping up again, no fans kicking on. The fluid appears to be moving in the radiator, there are no leaks or unusual noises or anything. Why would the fans not be coming on now if I only replaced the thermostat? fault thermostat? I can't even drive it right now. I will likely put the stock one back in tomorrow morning and see what happens, but that shouldn't have anything to do with when the fans kick in, that should be controlled by the engine computer right?
any help here would be greatly appreciated!!
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 07-24-2010, 06:11 PM   #2
Luvpilot
Luvpilot's Avatar
Drives: GM
Install it backwards?
Luvpilot is offline   Reply With Quote
Old 07-24-2010, 06:15 PM   #3
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Heheh, ouch! I wasn't gonna go there in my reply in the other section. BUT, I guess it is possible. OP, you did have the pellet side to the engine and the jiggle pin at 12 o'clock, yes?
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 07-24-2010, 06:30 PM   #4
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
This was my first thought... Ps why would you want your engine running temp to be so low? This will cause the compression ring gaps to be larger and you will loos compression and increase blow by, no?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 07-25-2010, 01:39 PM   #5
Eric Baker
Drives: Black/Black 2SS/RS 6M
First off, there is no need for a cooler thermostat in these cars, and it actually can hurt performance.
That being said, did you fully bleed the system? Sounds like you may have an air pocket or two.
Eric Baker is offline   Reply With Quote
Old 07-25-2010, 02:39 PM   #6
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
When I did mine, it wouldn't take all the coolant the first time. had to run the engine a bit, let it cool, then put more in. I wound up taking it out since I didn't feel it added any benefit...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 07-26-2010, 02:49 PM   #7
ffrcobra_65
thermostat installed incorrectly or bad thermostat
More likely, you have trapped air in the cooling system and you need to burp the engine (run to temp with heater full blast, let cool (this is when coolant gets sucked out of the reservoir), check coolant level and add coolant to the correct level (cool), repeat process til coolant level remains at the correct level)
Old 07-26-2010, 09:16 PM   #8
Eric Baker
^The proper way to do it is run it with the radiator cap off and keep topping it off. Wait until the fans come on 2 or 3 times and wait for all the bubbles to stop, put the cap back on, and top off the reservoir.
Old 07-26-2010, 09:20 PM   #9
Michael_Js
Michael_Js's Avatar
Hmmm...didn't know that! Great idea! Would have saved me from almost overheating that day and the car telling me to pull over and shut her off ;(
Old 07-27-2010, 12:10 PM   #10
ffrcobra_65
Yep, that way too. I didn't wanna recommend that for safety reasons. If a big bubble of air is trapped in the system and a noob is standing over the hole filling it and the systems does a big burp, there is the potential for a scalded face. The reservoir/recovery bottle is vented and is typically is the highest point in the cooling system and where the burping occurs (air rises to the highest point), hence, my recommendation. Either way works.
Old 07-27-2010, 06:25 PM   #11
Eric Baker
Only problem with that is it won't bleed air properly because it needs to build pressure before the radiator cap opens to the reservoir to let out coolant/air. Ideally, you'd put a funnel on the radiator opening and fill it above the neck, so it won't violently slash all over.
Old 07-27-2010, 08:26 PM   #12
revron
revron's Avatar
Drives: camaro 2lt rs auto silver
If its not a problem with an air pocket in the coolant.
You may need to have the fans (computer ) reprogramed to come on sooner.
Ron
revron is offline   Reply With Quote
USB Port problem w/ Ipod touch Arsenal11 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 06-03-2011 07:42 PM
Cooling System problem? nusong Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 09-29-2010 12:58 AM
Found a problem with my camaro Agostino13 5th Gen Camaro SS LS LT General Discussions 19 04-27-2010 12:59 PM
pm problem drivingincamaro Site Related Announcements / Suggestions / Feedback / Questions 4 06-23-2009 11:20 PM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
