Solo Performance
Old 07-24-2010, 07:26 PM   #1
hummerman
Drives: 2010 2SS
1/8 mile run
Ok went to track today and thought it was 1/4 but they only were doing 1/8 mile runs.
I couldnt get the launch down pat and had alot of wheel spin or no wheel spin and lugging.
Here is my best time of the day.
Reaction = .952
60ft = 2.36
594ft = 8.725
1/8 mile = 9.292 @ 79.38 mph
Any idea of approx 1/4 mile time of this?
These bad 1/8 times for a bone stock camaro?
hummerman is offline   Reply With Quote
Old 07-24-2010, 09:20 PM   #2
hummerman
Drives: 2010 2SS
anyone?
These ok or terrible times??
Old 07-24-2010, 09:42 PM   #3
69lt1bird
69lt1bird's Avatar
Drives: 1969 Pontiac Firebid
About 14.4 in the 1/4
What engine is in your Camaro, might be good to know.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler
1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
69lt1bird is offline   Reply With Quote
Old 07-24-2010, 11:59 PM   #4
hummerman
Drives: 2010 2SS
Its the SS with ls3
Old 07-25-2010, 12:03 AM   #5
by your 60 ft. looks like you were spinning tire.
Old 07-25-2010, 12:12 AM   #6
hummerman
Drives: 2010 2SS
yeah was spinning steady...... Guess i was nervous / excited.
Oh well........ first time and i had fun.
Just need more experience i guess.....
Old 07-25-2010, 09:32 AM   #7
69lt1bird
69lt1bird's Avatar
In our fine summer air here in Michigan a few weeks back, I went to the track. A guy had a SS with CAI and cat-back, he was complaining too about running 14.5-14.6. His 60's stunk so I was trying to help him out. Seat time is the only thing that will help, especially on street tires.
Old 07-25-2010, 09:45 AM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Practice makes perfect. It will get easier the more track time you have.
You just need to work on your 60' times. If your spinning your tires, you're just wasting time.
Guys get nervous and they drive overly aggressive at the track. You'll need to learn to leave the line smoothly (without wheel spin).
I'd try a knee jerk launch if I were you. That's where you launch by holding the car at a constant rpm (say 2500) and then you just lift up on the clutch (knee jerk) WITHOUT adding any additional gas. Once your car starts moving off the line, then you roll into the gas. This type launch will keep you from just spinning your tires leaving the line.
When your learning this method, you might bog the launch. That's ok. You'll still run much faster than 2.3 sec 60'. Eventually you'll get where you can launch at a little higher rpm and then quickly roll into the gas as soon as your car starts moving. You should be able to pull pretty easy 2.0 sec 60' with this method.
Old 07-25-2010, 12:37 PM   #9
hummerman
Drives: 2010 2SS
Ill keep trying and sooner or later ill get er figured out
What about the launch mode?
How do i use it?
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
NEW PB but only on an 1/8th mile track freemaSSon Dragstrip and Launch Techniques Discussion 3 12-05-2009 10:30 PM
What are typical 1/8 e.t.'s the LS3 is seeing? topgun1 Dragstrip and Launch Techniques Discussion 10 11-29-2009 03:02 PM
Going to 1/8 mile this weekend any suggestions speeflo Dragstrip and Launch Techniques Discussion 2 07-14-2009 01:38 AM
