BORLA
Old 07-25-2010, 08:51 AM   #1
John Shields
"Back in Black"
John Shields's Avatar
Drives: '10 1LT/RS Black w/Silver Stripes
Odd Ticking Sound (V6) and Camaro "Bug"
Ok, so I was in the drivethrough... ... I absolutely hate fast food but needed something for breakfast and didn't have anything good at home. Anyway, I was pretty close to the building waiting and tapped the accelerator. At EXACTLY 1,000 RPM's I hear a ticking sound. The best way I can describe it is the sound a playing card makes in the spokes of a bicycle. This sound continues past 1,000 RPM's but is masked by the rest of the engine noise. As I moved away from the building the sound is no longer heard over the normal engine noises.
Any idea what that could be?
Now the "bug" I found with the Camaro and would love to hear a solution on how to fix this is if you:
1. Unlock the doors
2. Open the passenger door
3. Insert the key and turn it to standby (just before starting the vehicle)
4. Stereo should come on if it was one prior to turning off the vehicle
5. Close the passenger door and lock them with the remote
... the stereo stays on. The only way I found to turn it off was to go to the driver door, open and then close it. I only went through the passenger side to close my window all the way after noticing it was down.
Any way to make it so it turns off? Luckily I had the music up or else I might not have noticed and my car could have had the stereo on for hours.
To the Jerkoff in SW Denver Driving the Black Camaro:
Quit making us look bad by driving like a tool and cutting people off (my wife included)!
John Shields is offline   Reply With Quote
Old 07-25-2010, 08:55 AM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Ticking is the fuel injectors. Bug is so you can continue to listen to the radio for ten minutes after you turn the car off. Just turn the radio off after you turn the car off.
ROD1 is offline   Reply With Quote
Old 07-25-2010, 08:59 AM   #3
John Shields
"Back in Black"
Hmm... so the sound is normal... that's good. I saw a couple YouTube videos of people claiming the same type of sound on different cars. Anyway to reduce that noise or get rid of it? Haha.
As for the stereo... does it only last 10 minutes? I've never sat down and tested it. But I like the fact that the radio comes on when I turn the car on... kind of defeats that purpose if I turn it on and off all the time.
Old 07-25-2010, 09:12 AM   #4
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
The radio turns off as soon as you open the drives door - the passenger door is not "monitored" in this case - hmm now that I think about it - maybe it doesnt I'll have to go play around and see.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 07-25-2010, 09:14 AM   #5
John Shields
"Back in Black"
Yeah the driver door will turn it off, but in my case I opened the passenger door (which I imagine plenty of people open the passenger side to load something). But I'm not sure many people would turn the car on from the passenger side like I did. But the unfortunate thing is that the stereo will stay on (for how long I have no idea).
Old 07-25-2010, 10:10 AM   #6
ketel0ne
Drives: Used to have 2010 SGM
10 minutes.
ketel0ne is offline   Reply With Quote
Old 07-25-2010, 10:28 AM   #7
spyderbuddy
spyderbuddy's Avatar
Plus if you want you can open the either door (no key) press the on/off knob on the radio and it will come on for about ten minutes.
I use this mode when i'm cleaning the car
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 07-26-2010, 10:56 PM   #8
mastertypodemon
Late Night Crew
mastertypodemon's Avatar
Drives: 2010 SIM 1LT
Well why would you get in on the passenger side, turn on the car, then leave?
mastertypodemon is offline   Reply With Quote
Old 07-27-2010, 01:18 AM   #9
Homestar1217
Technology Specialist
Homestar1217's Avatar
Drives: 2014 IS 250 F Sport (Not named yet)
Send a message via AIM to Homestar1217
pretty much all GM cars, and most other cars have rundown protection. even if the radio did stay on for more than 10 minutes, if the battery level gets low enough the computer will shut everything electrical off so that the car will start next time you get it. great feature. saved my Cobalt's battery when I locked my keys in it (which I did all the freakin time) once and left accessory mode on. It shut the lights and everything off and when I got it unlocked it started right up.
I eat Rice for lunch :-) (Can't really say that anymore!)
2014 Lexus IS 250 F Sport - Bone stock!
Homestar1217 is offline   Reply With Quote
Old 07-27-2010, 12:25 PM   #10
04Ram2500Hemi
Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS
I never knew this- good stuff! I'm going to do this the next time I'm cleaning the inside of the car. I hate listening to the door ding.
04Ram2500Hemi is offline   Reply With Quote
Old 07-27-2010, 12:55 PM   #11
Russell James
Russell James's Avatar
Drives: Camaros
The direct injection fuel pump makes quite a ticking noise. Also the DI injectors are louder than low pressure injectors.
You should hear a DI 4 cylinder fuel pump tapping away. I test drove a 4 cyl GM Terrain the other day with a 4 cy direct injection engine. Opened the hood while at idle, would swear it had a spun bearing the thing was tapping so loud.
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
