JDP Motorsports
Old 07-25-2010, 12:30 PM   #1
2011Black2SS
Drives: 2017 ZL1 M6
Rear End Leaking after Competitive Mode Launch
Has anyone else notice a leak at the rear end of the car after doing a competitive mode launch?
I did a launch for the first time yesterday and now I have a puddle of gear lube under the rear end of my car.
2017 Nightfall Gray Metallic ZL1 M6
2014 Black GMC Serria Z71
1996 Red Z28
2011Black2SS is offline   Reply With Quote
Old 07-25-2010, 12:37 PM   #2
Slim2SS
Black Thunder
Drives: 2010 Camaro 2SS/RS
Well thats not good. Should have nothing to do with the launch mode itself. You will need to get under the car and find the leak. Look closely at the pinion shaft and axles where they go thru the rear housing. I would not drive the car untill you find the leak and also determine what caused it. The last thing you want to do is run it dry. Was the there any noises or anything different after the launch that you heard or noticed?
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger
JRE Blower Cam package
Cooling Mist Water/Meth
3.25 blower pulley
FAST 65 lb. hr. injectors
JRE Edelbrock fuel system upgrade
GM ZR-1 Clutch
Roto Fab CAI
Kooks Headers Jet Hot Coated
Kooks High Flow Cats
3" Magnaflow Stainless Steel Exhaust
Barton Short Throw Shifter
JRE Dyno Tune
Slim2SS is offline   Reply With Quote
Old 07-25-2010, 12:40 PM   #3
2011Black2SS
Drives: 2017 ZL1 M6
No new noises after the launch. I am thinking its an axle seal, but am letting the car cool down (just drove it before I found the puddle) before I get under it.
1996 Red Z28
Old 07-25-2010, 12:53 PM   #4
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Unfortunately, that's one of the things I'm not pleased with about the new Camaro, along with the weak paint issue.
It seemingly is to the point in some people's cases where you can't USE the power that GM gave the car without something failing. Understandably, there are factors in each different case, but where as I don't even think twice about taking out my 02 SS and do some spirited driving, I'm not afraid of something snapping/breaking/grinding/slipping. The 2010 Camaro, while powerful...I'm not at that comfort level yet, I guess.
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 07-25-2010, 02:36 PM   #5
2011Black2SS
Drives: 2017 ZL1 M6
I just dropped it off at my dealership and I'll be giving them a call first thing in the morning. I'll give an update when I know more, but I think it is one of the axle seals.
1996 Red Z28
Old 07-25-2010, 02:37 PM   #6
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
After actually getting my car and reading through the manual, it says to change the differential fluid before using competitive driving. Did anyone follow this?
OUTATIME is offline   Reply With Quote
Old 07-25-2010, 02:53 PM   #7
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
I did. I was amazed at the amount of metal shavings that drained out of the differential (2000 miles / 8 months of driving). There are a few threads on here with pictures demonstrating the "break-in" shavings you're bound to see. This is normal from what I understand and yes, the fluid has a foul odor.
Sorry to hear about the leakage. Let us know what the dealer says.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is online now   Reply With Quote
Old 07-26-2010, 06:56 AM   #8
Pro Street
Pro Street's Avatar
Drives: 2SS/RS
I changed mine at 1200 miles and did the engine oil and filter at 1200 miles also!
2016 ZO6 2LZ A8
CamaroFest II-III-V
Pro Street is offline   Reply With Quote
Old 07-26-2010, 07:51 AM   #9
Russell James
Russell James's Avatar
Drives: Camaros
Best thing to do with launch mode is never use it. There is about half a dozen things in the driveline not up to the task of that kind of abuse.
I know somebody that broke his driveshaft, then smoked his clutch, then broke an axle.... then stopped using launch mode. I think he tried it 4 times, 3 of which resulted in a flat bed ride to the dealership.
Old 07-26-2010, 10:49 AM   #10
2011Black2SS
Drives: 2017 ZL1 M6
Well just talked to the dealer and they said it was a bad drain plug. We'll see how it holds up.
1996 Red Z28
Old 07-27-2010, 09:28 PM   #11
2011Black2SS
Drives: 2017 ZL1 M6
So, I picked the car up today. Drove it a total of 20 miles and it is leaking again. I am thinking the drain plug was cross threaded. It only leaks when the fluid is warm.
I'll be talking to the dealership and dropping it off again tomorrow.
I wonder if it was cross threaded if they would replace the diff because I would rather not have a drill and tap job on the car.
1996 Red Z28
Old 07-27-2010, 09:55 PM   #12
wow, hope they fix it.
Old 07-27-2010, 09:58 PM   #13
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
I'm not really sure that launch control is harder on the car then simply popping the clutch and hammering it down. From experience, the launch control will slow the engine rpm to limit power until the wheels catch and then give full power. If anything the launch control is somewhat protective over just hamming the gas to the floor!?!
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 07-28-2010, 05:26 AM   #14
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Yeah but launch control is having you rev up to around 4k to 4.5k and pop the clutch. Man not good. With my gen 4 I would only go to like 2.5 to 3k max and drop it.
Scott@Bjorn3D is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 10:47 AM
Rear end clicking SS m6 Vinz68 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 05-29-2010 07:04 PM
4:10 rear end or LT headers & tune? wildthing001967 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-06-2010 10:21 AM
