Old 11-17-2008, 09:15 AM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Keep My 2SS Going
I am going to be 46 if GM survives and get my 2SS. I plan on this being my last car. Meaning I want to keep it running 30 years.
With that said can any of you car buffs tell me the following:
1. Best Oil to use.
2. How often to change it
3. How often change transmission fluid. Going with Auto.
And last but not least what do you guys use to keep interior in good shape and how often?
Thanks
Scott
Scott@Bjorn3D is offline   Reply With Quote
Old 11-17-2008, 09:25 AM   #2
kdbolt70
kdbolt70's Avatar
Drives: 2010 Camaro 2SS/RS
I'm a fan of Mobil 1. They recommend changing your oil every 3000 miles, though you should be fine doing about 5k before changing.
2SS/RS Victory Red M6 w/ Black Rallys #3305
Muffler Delete, Lloyd "SS" Floormats, K&N Aircharger, Skip Shift Eliminator, Blacked Bowties
kdbolt70 is offline   Reply With Quote
Old 11-17-2008, 09:49 AM   #3
dieseldave24v
PowerStroke this Ford boy
dieseldave24v's Avatar
Drives: Like Don Garlits "Big Daddy"
You will hear alot of people tell you different things about oil
follow the manufactures recomendations. The pay engineers millions of dollars to figure this stuff out. Follow what the owners manual says and you will be fine
Oil never looses it lubricisity (SP) oil gets contaminated as a by product of hydrocarbon emmisions that a internal combustion engine creates. Oil will always lubricate.
I dont believe in changing transmission fluid on a auto....but thats just me most people will disagree with that statment. To each his own.
dieseldave24v is offline   Reply With Quote
Old 11-17-2008, 09:56 AM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I'd say 5 - 7k on synthetic is fine. I will be doing it every 3k though. My thoughts is that it is cheap peace of mind and certainly can't hurt. Oil is your cars blood ..
On as side note .. I wouldn't listen to all manufacturers recommendations ... my 135i .. turbo 3.0L which also uses the oil for the turbo as well.. the recommend every 15k .. LOL ... That might be fine for someone who has a lot of money or doesn't want to keep the car (poor bastard whoever does get it used though) ... I think some people have tested their oil and seems like 7k is good but don't push it past that (with synthetics) ..
Crowley
Crowley is offline   Reply With Quote
Old 11-17-2008, 10:14 AM   #5
Scott@Bjorn3D
Found this, interesting read.
http://neptune.spacebears.com/cars/stories/mobil1.html
I will go with Mobile one and maybe 5-8k Oil/Filter changes.
Old 11-17-2008, 11:06 AM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Sounds like a plan .. always keep this flexible as well .. if you do any track time or run the car hard, you may want to bump your time frame up a little. Either way .. sounds like your on the right track ..
Crowley
Old 11-17-2008, 11:10 AM   #7
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Roal Purple is suppse to be the best of the best. . . I never used it. . I use Mobil 1. . .Change oil filter at 3k. . at a qt and change filter and oil at 6k.
franknbeans is offline   Reply With Quote
Old 11-17-2008, 11:11 AM   #8
99b4c
Drives: 89 RS/99 GTP/1SS soon
I run mobile 1 in all my vehicles and change it every 3-4K. I would change the trans fluid and filter at 10k and every 30-40k, rearend lube at 10k,every 50k after IMO.
99b4c is offline   Reply With Quote
Old 11-17-2008, 12:08 PM   #9
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
What is a rear-end lube?
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 11-17-2008, 12:34 PM   #10
Grape Ape
Drives: 96 Bronco w/ a 5 speed
I guess we can't blame you for not googling that.
He means the oil in the diferential.
Grape Ape is offline   Reply With Quote
Old 11-17-2008, 12:39 PM   #11
matt55
matt55's Avatar
Drives: CTS-V
All synthetic are not full synthetic , do a little more digging and you see what Iam talking about .
I run Amsoil's fluids and like them very much .
If you what to run Mobil 1 get the "Extended Performance" oil .
And for the love of your car dont use R.P. rearend fluid , Ive seen independent test where it thins WAY out quickly .
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 11-17-2008, 12:41 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If you race or drive your car hard a lot you need to change oil every 3k or less depending on how often you do these. For the typical driver though change the oil between 5k and 7k but no more then 7k.
Other then the 1st 5k of owning a vehicle, I've never seen anyone change the tranny fluid in an auto.
Old 11-17-2008, 12:44 PM   #13
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
the Auto trans is a sealed system and you do not change the fluid in it very often.
headpunter is offline   Reply With Quote
Old 11-17-2008, 01:29 PM   #14
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I have an uncle that retired after a lifetime of being an automatic transmission specialist. He always recommended fluid and filter change after 50K. As long as the clutch packs have not been burned and the shifting is normal, there is really no need to take any action. That's why there is a dipstick and no drain plug usually. Pull the dipstick occasionaly, which most oil change centers do for you, to see if the fluid is clean. Smell it to see if it smells burnt. If not and fluid level is normal you have nothing to worry about. If the fluid doesn't look or smell normal you could have any of several problems. IE: torque converter, clutch pack, planeteary gears, etc.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
why get an rs package on the 2ss? LS3SSRS 5th Gen Camaro SS LS LT General Discussions 66 08-16-2009 06:14 PM
Official Camaro Options & Standard Equipment for all Trim Levels headpunter Camaro Price | Ordering | Tracking | Dealers Discussions 300 02-18-2009 01:23 AM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 07:51 PM
Question for the Pedders folks on recommendations for my forthcoming 2SS PatrickfromMD Wheels and Tires Talk Sponsored by The Tire Rack 13 10-25-2008 09:18 AM
2SS standard equipment and options Tran Wiki 3 10-23-2008 05:58 PM
