SDTW Custom Wheels & Tires
Old 07-26-2010, 08:51 PM   #1
skcamaro
Drives: LS 2011
Gear shift points in 2011 LS
Hi guys,
I got a new Camaro (2011 LS). Its a stick shift, and I'm completely new to manual transmission. *sheepish grin*. But I just couldnt resist the Camaro....I'm trying to get a feel for the gear shift points. I'm able to get the car moving in first gear without problems, but I struggle with the 1st to 2nd gear change. The car jerks most of the time. (2nd to 3rd to 4th to 5th are all fine).
I was just wondering if theres some guidance on when to shift gears. I checked the owners manual and couldnt find the recommended maximum rpm's for each gear or something of that sort. Do you guys know if its listed somewhere?
I guess its a matter of practice..but I thought it might be useful info
skcamaro is offline   Reply With Quote
Old 07-26-2010, 08:56 PM   #2
fearless
Drives: 2010 camaro 1ss grey/black
dont pop clutch out so fast let it out a hair slower and it shouldnt jerk
fearless is offline   Reply With Quote
Old 07-26-2010, 08:57 PM   #3
RunningOnEmpty
RunningOnEmpty's Avatar
Drives: 2010 Synergy Green Camaro
That jerkiness is because your not shifting fast enough and the RPM drops real low, or because your letting off the clutch too fast.
I usually shift anywhere between 1500 and 2500 RPM. Stay in that range for normal everyday driving and you should be fine.
As far as not shifting quick enough, if that is the case, it shouldn't take you more than 2-3 seconds to complete a shift. If your taking longer than that then you should practice shifting quicker. It's not bad for the car at all, but could cause that jerking at low RPM and you might make other drivers mad at you.
Good luck to you and welcome to Camaro5 and congratulations on your new ride! The perma-grin will never go away.
RunningOnEmpty is offline   Reply With Quote
Old 07-26-2010, 08:57 PM   #4
FC_GIBB
FC_GIBB's Avatar
Drives: 2012 Impala LTZ
well you dont want to get at your "max rpm's" unless you plan on driving agressive. I learned how to drive stick on my first car almost 13 yrs ago. sound like you may be letting off the clutch too quick if its jerking though, every cars clutch is different. you'll figure it out
congrats on a beautiful car though and welcome to camaro5
A veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to "'The United States of America", for an amount "up to, and including my life". That is honor, and there are way to many people in this country who no longer understand it.
FC_GIBB is offline   Reply With Quote
Old 07-26-2010, 08:59 PM   #5
skcamaro
Drives: LS 2011
thanks fearless. I'll try it out like that. My apologies for asking such a basic question!
Old 07-26-2010, 09:03 PM   #6
skcamaro
Drives: LS 2011
thanks for all the responses guys! Very helpful!
Totally exciting learning to drive a stick shift. And the car is a beauty! Cant take my eyes off it! sigh
Old 07-26-2010, 09:12 PM   #7
reocamaro
Drives: car
Hey SK, I couldn't be more in the same boat as you if I lived in Arizona. I bought the car two weeks ago, and have been learning stick every night since. I'm getting a lot less jerky and it hasn't even been that long. I don't know how much the LS trans differs from the SS trans, but an individual by the name of infernO wrote a few tips for how to properly shift and drive in one of my threads. I don't know if it'll help you, but it helped me.
Have a great day and good luck!
reocamaro is offline   Reply With Quote
Old 07-26-2010, 09:59 PM   #8
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Dont shift into second at anything less than 8 mph or you increase the chances for jerking, nothing less than 15 mph from second to third, and then about 29 mph for third to fourth. Also you're probably getting back onto the gas too quick during your shifts. Make sure you're completely off the clutch consciously before giving it gas again.
Good luck.
DarkneSS is offline   Reply With Quote
Old 07-26-2010, 10:10 PM   #9
FC_GIBB
FC_GIBB's Avatar
if the clutch on the LS3 is the same or anything similar to the LS2 in a GTO then you picked the harder car to learn stick on the V6's clutch is very easy in my opinion
Old 07-27-2010, 10:40 AM   #10
Phake
Phake's Avatar
wow. and i thought i was the only person learning to drive stick on a new camaro. it's good to see other people doing it as well. some people i know said it was silly of me for to get manual when i don't know how to drive it well. i've had mine for about a month and a half and i'm doing great! ^0^ hope the same happens for you.
Phake is offline   Reply With Quote
Old 07-27-2010, 12:10 PM   #11
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
Always shift just before the fuel cut-off kicks in at max r's.
Seriously, if you want to drive "competitive" shift at around 200-300 r's before the cutout. If you want to drive like "most" people, shift at around 3200-3500 IMO. If you want to be a *****, shift at 2000. Pretty simple.
trm0002 is offline   Reply With Quote
Old 07-27-2010, 12:16 PM   #12
skcamaro
Drives: LS 2011
Its good to hear that I've fellow learners on the camaro, reocamaro and phake! I was feeling rather silly too with friends asking why the heck I bought a stick shift when I didnt even know how to drive it. (how can you not when you see the camaro )
Thanks Darkness, I was just about to ask the speeds at which shifting would be recommended.
Old 07-27-2010, 12:22 PM   #13
trm0002
trm0002's Avatar
Good luck.
Your car goes 8 ? Mine doesn't. Well, maybe near the end of braking...
Old 07-27-2010, 01:12 PM   #14
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
Bwahaha!
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Shift points SSCamaro2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 11-18-2011 05:39 PM
2011 Camaro Pricing Announced on Edmund's Inside Line LostInMoscow 5th Gen Camaro SS LS LT General Discussions 3 06-03-2010 02:36 PM
Camaro addiction test biojack 5th Gen Camaro SS LS LT General Discussions 37 04-16-2010 07:19 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Shift points Blacc Mamba Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 7 08-01-2009 09:21 PM
