IPS Motorsports
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 07-27-2010, 08:58 PM   #1
Ex-stang
Ex-stang's Avatar
Drives: "Sergeant" a 1LT/SIM/RS/CONN/BA/M6
squeaking noise up front with eibach pro-kit springs
Got a pain in the ass squeak coming front the front end whenever i go over a small hump in the road....low speed , high speed , does it all the time...Could it be the bushings with the lowered height have worked around and need to be replaced?
Have no clue what it could be .I googled squeaking after eibach pro-kit and it seems to be a pretty common issue?
Any clues anyone.
Thanks in advance for the responses.
ISSUE LOCATED
Dont know what they are called but they connect vertically to the front sway bar ends ...one was hanging loose ! bolt up top completely sheared off and was connected to the sway bar only...
what are those called?
Ex-stang is offline   Reply With Quote
Old 07-27-2010, 09:07 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: 2010SIM/RS
had issues w/ rear 'clunking', until I tightened the sways(had a little play). Check those connections..
Old 07-27-2010, 10:27 PM   #3
Ex-stang
Ex-stang's Avatar
will do first thing in morning , thx !
Old 07-28-2010, 11:08 AM   #4
Ex-stang
Ex-stang's Avatar
Bump please read update and question related to it in OP.
Old 07-28-2010, 11:15 AM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi Ex-stang,
Do you know if you have the new GM upper spring isolators installed? This has been rumored to alleviate some front end noise, although I can not confirm. Are you aware of this? Thread below:
http://www.camaro5.com/forums/showthread.php?t=79323
Old 07-28-2010, 11:18 AM   #6
Ex-stang
Ex-stang's Avatar
Originally Posted by PfadtRacing View Post
Hi Ex-stang,
I have the original isolators...the ones on the right in your pic....as you can see in my OP update the sway bar endlink on one side has completely tore off on the top....this may be whats causing the issue...
Old 07-28-2010, 12:02 PM   #7
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
The vertical rods attached to the ends of the sway bars are the sway bar links. A pivot on each end. They are common to break on Cobalts, Uplanders as well as all of the Enclave/Acadia/Traverses and Impala's. I've yet to hear anything about the Camaro's though.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is online now   Reply With Quote
Old 07-28-2010, 08:26 PM   #8
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Your endlink would probably not be the squeak, thought it does require attention. Two quick questions.
1. Who did the installation? Was it a shop or did you do it?
2. Did you install sway bars when you did the springs?
Old 07-28-2010, 09:08 PM   #9
Ex-stang
Ex-stang's Avatar
i had a shop do the install, they broke off the swaybar end link while installing the springs and they welded it back on without even telling me....!!!! check out my post about it.....bunch of retards are putting a new swaybar end link this week and arent ever seeing the car back again ever !
Old 07-28-2010, 09:14 PM   #10
JusticePete
Needs Lowering
Doh
Back to the squeak, springs only and no sway bars, right?
Old 07-28-2010, 09:28 PM   #11
Ex-stang
Ex-stang's Avatar
yup no sways on it atm but its my next mod just havent gotten the mod fund piggybank full enough...and then il have to make a choice on what brand.
Old 07-28-2010, 09:38 PM   #12
JusticePete
Needs Lowering
Back to your queak. Did the squeak go away when the endlink failed or do you still have it?
Old 09-19-2011, 03:51 AM   #13
TankMorph
More Human Than Human
TankMorph's Avatar
Drives: 2011 1LT IOM M6
Here's my solution:
http://www.camaro5.com/forums/showpo...4&postcount=11
TankMorph is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 138 05-09-2013 03:58 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 79 03-04-2013 09:25 AM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 09:09 PM
Eibach swaybars and springs $499 shipped @ PFYC.com Redshift Suspension / Chassis / Brakes 3 01-02-2010 11:49 PM
