Old 07-27-2010, 10:29 PM   #1
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
Wheel hop?
When i put my camaro in S mode and get into the throttle about half way, it feels like there is wheel hop. Not sure if it is wheel hop but thats the best way i can explain it. Not sure what it really is. Has anyone had or experienced this, what is it?
69 Rebel is offline   Reply With Quote
Old 07-27-2010, 11:16 PM   #2
jordan 572
jordan 572's Avatar
Drives: none
does the back end vibrate up and down? Are you hearing very short chirps like the tires are leaving the ground and then when they hit make a chirping noise?
jordan 572 is offline   Reply With Quote
Old 07-27-2010, 11:24 PM   #3
69 Rebel
69 Rebel's Avatar
it feels like there's a hop, iam not in WOT so i don't think there's enough power there to actually cause wheel hop, no chirp
Old 07-27-2010, 11:43 PM   #4
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
It sure is wheel hop. The rear trailing arms are very flimsy and have soft rubber bushings. You need to eliminate that by installing some aftermarket rear trailing arms. I went with SPOHN from JDP Motorsports. Wheel hop went bye-bye! Give Jordan a call. He will hook you up with the best prices guaranteed!
Old 07-27-2010, 11:51 PM   #5
69 Rebel
69 Rebel's Avatar
Well car going to Jannety Racing in 2 weeks for S/C install and a few other goodies.
I guess i will add trailing arms to the list.
Old 07-28-2010, 01:07 PM   #6
GFORCE1320
Drives: 05 GTO
Yep, it's wheel hop. Even though GM used different diameter axles on each side the cars still wheel hop.
Our axles have our proven anti wheel hop technology, you dont get any wheel hop and if you do it is very slight (like on wet roads).
It's all in the axle material (300m) and the twisting properties.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
wheel hop Gr8_syder 4th Generation Camaros 8 02-09-2010 05:24 PM
wheel hop ktspops Suspension / Chassis / Brakes 0 11-07-2009 05:16 PM
Wheel suggestions teapot Wheels and Tires Talk Sponsored by The Tire Rack 8 11-05-2009 08:59 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
