| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: 2010 Camaro, 68 El Camino Join Date: Jul 2010
LSA supercharger on Ebay
Wanted to know what it would take to get this supercharger to fit and how much power with a stock cam.
http://cgi.ebay.com/ebaymotors/LSA-L...item2c562c2590 |
![]() ![]() ![]() ![]() ![]() Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
it should be a direct bolt on. the stock psi will be too much for a un forged ls3 though
my question, other than the supercharger what else u need to make it work
Do you know what psi the stock LSA's run at?
Drives: 2011 2SS Join Date: Jun 2010
9psi I believe. Might not be out of the realm of possibilities on a stock motor. I don't know much about them. Everything can be changed.
#6 |
I think most of the other aftermarket kits are at 8psi will 1 psi really make a difference?
#7 |
![]() Drives: 2011 Fasties Maxies Join Date: Jun 2010
there r people running 9.5psi with no problems
#8 |
Layla
Drives: '10 2SS/RS, LS3, CGM/IO Join Date: Dec 2009
#9 |
lsa does have cast pistons and pauter rods. the lsa also has piston oil squirters that the ls3 does not. the lsa makes 7psi.
you will need all new accesories and crank pulley as well. |
#10 |
well if other superchargers are running higher psi on a stock LS3/L99 engine. you shouldnt need forged internals, the LSA might use forged parts for extra precaution but it isnt required.
#11 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
LSA SC will NOT fit under the cowl without modifications! Look for some posts by Uncle Robin and his LSA-powered SS. He had to cut up the upper rear of the intake to get it to fit under the cowl.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#12 |
#13 |
![]() Drives: Toys sold and waiting for droptop! Join Date: Mar 2010
It looks like it didn't fit under the COWL, not the hood. Just buying a hood would not solve the fit problem.
Sorry Danny
" I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I require the same from them" -John Wayne "The Shootist"
#14 | |
Petro-sexual
- Sorry.
#15 | |
It will also directly bolt to your ls3, you will have fabricate inlet to the blower and then change of the drive system on the front of the engine to accommodate the larger ribbed belt used by the blower. Regards |
#16 |
Oh you could swap over the ls9 S/C interecooler and cover...
#17 |
![]() Drives: 2010 Camaro SS/RS Join Date: Sep 2009
Not too much boost for a stock "non-forged" ls3. I can attest.
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's |
#18 |
Hey that's some nice work done on that cover. If that's the case then you could probably go with something totally fabbed up from Hogans Racing Manifolds that would really make your car stand out.
#19 |
Any idea on what kind of HP?
#20 |
Will it at least break into 500 hp?
#21 |
![]() Drives: 2010 Camaro 69 Nova Join Date: Oct 2008
Huh? The LSA is 556 Horsepower in the CTS-V.
A TVS 1900 Supercharger is capable of movng enough air to produce 800 Horsepower. Mine is about 700 right now. Robin
Holley Performance Products
| Thread Tools | |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 205 | 05-15-2013 09:30 PM |
| Stock L99 A6 Supercharger options, opinions, & experiences | 2010 Bumblebee | Forced Induction - V8 | 103 | 03-24-2013 06:24 PM |
| The mighty LSA supercharged V8. | Mr. Wyndham | Camaro ZL1 Forum - ZL1 Specific Topics | 137 | 05-07-2011 10:05 PM |
| Supercharging options available from BMC Performance! | Curt@BMCPerformance | Forced Induction | 17 | 02-18-2010 07:17 PM |
| EBay, GM set to start car-selling trial Tuesday | camaro5 | General Automotive + Other Cars Discussion | 1 | 08-10-2009 09:57 AM |
