Old 07-28-2010, 04:09 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
L99 Cam Swap
MTI Racing just finished up another 2010 Camaro camshaft swap, lowering springs, and sway bar package. This L99 Camaro came in from Alabama wanting more power and better handling, no problem.
We started by installing our Stage 1 Camshaft with matching valve springs. The stage 1 Camshaft is designed to be used with the stock torque converter and the DOD system on the L99 Camaro. This camshaft makes awesome horsepower and torque by taking advantage of the great airflow the LS3 cylinder heads, plus the added benefit of headers the car already had installed. You will get a mild to moderate sound from this camshaft. This Camaro went from 312rwhp to 405rwhp.
We also installed a set of the MTI Racing Sport Lowering Springs to give the car a more aggressive look and improve the handling by lowering the center of gravity. Combined with the MTI Racing Sway Bars to limit body roll this Camaro is now ready to carve up those mountain roads with confidence.
List of Goodies
MTI Racing Stage 1 Camshaft
MTI Racing Dyno Tune & Computer Programming
MTI Racing Front Suspension Alignment
MTI Racing Kevin is offline   Reply With Quote
Old 07-28-2010, 04:17 PM   #2
DangerZL1
Drives: Accord
Is a sound file available for this cam/header combo?
DangerZL1 is offline   Reply With Quote
Old 07-28-2010, 04:59 PM   #3
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
wowzers
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 07-28-2010, 05:15 PM   #4
98_Camaro
The Purple People Eater
98_Camaro's Avatar
Drives: '98 BPM V6, '12 CFM SS Vert
Very impressive!
1998 Bright Purple Metallic Camaro: 1 of 336
2012 Carbon Flash Metallic SS Convertible A6: 1 of 1103
98_Camaro is offline   Reply With Quote
Old 07-28-2010, 06:17 PM   #5
John Shields
"Back in Black"
John Shields's Avatar
Drives: '10 1LT/RS Black w/Silver Stripes
I'd like to hear this too. Good output though.
To the Jerkoff in SW Denver Driving the Black Camaro:
Quit making us look bad by driving like a tool and cutting people off (my wife included)!
John Shields is offline   Reply With Quote
Old 07-28-2010, 06:29 PM   #6
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Ditto
csjcsj is offline   Reply With Quote
Old 07-28-2010, 06:42 PM   #7
Qatar eagle
Drives: 2010 victory red 2SS\RS
does that cam fit with supercharger kit ?
Qatar eagle is offline   Reply With Quote
Old 07-28-2010, 10:40 PM   #8
jimmyj333
Drives: 2010 CAMARO 2SS/RS Aqua Blue L99
What are the specs on this stage 1 cam??
jimmyj333 is offline   Reply With Quote
Old 07-29-2010, 11:02 AM   #9
DangerZL1
Drives: Accord
If you click the link in the original post, it gives the specs on the cam.
Old 08-02-2010, 11:09 PM   #10
tples69
Blaq Out
tples69's Avatar
Drives: Hummer H2, 2010 Camaro RS/2SS
How much should one expect to pay for a cam install and tune? I have Kook's 1 7/8"'s and a Rotofab... looking for next fun mod!
Would this cam be a problem if/when I go to a supercharger?
tples69 is offline   Reply With Quote
Old 08-02-2010, 11:16 PM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
It dynoed at 312 rwhp WITH headers already???
WTF?, THAT dude was in serious need of a fuse pull.
Were the headers installed loosely in the trunk? I'm a little confused.
Old 08-03-2010, 12:02 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I was thinking the same way. I've yet to see a cam, especially a stage 1 cam, that makes 90whp. This cam is suppose to be DOD friendly? It just doesn't add up. Even the GX6 cam doesn't give that much of a gain and it's pretty radical.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-03-2010, 12:15 AM   #13
Ivan @ Southwest Speed
Is that an EOD license plate up front??
-Ivan
Old 08-03-2010, 09:49 AM   #14
MTI Racing Kevin
Drives: 2010 Camaro
It was probably in need of a fuse pull, yes. But that was probably hurting it by about 10hp.
This is why we base line the car before we do the work, and then dyno it after we do the work.
The cam swap and dyno tuning were a great upgrade.
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
L99 Cam Swap MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 07-30-2010 09:00 AM
VVT cam swap with no AFM... Tips? cam- Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 02-25-2010 02:42 PM
expected gains with head, cam and intake swap? Yellow1lt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 02-21-2010 12:18 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 03:09 PM
