Centerforce Clutches
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 07-28-2010, 10:16 PM   #1
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
How do I get my Halo's to turn on all the time like DRL?
I have tried searching - though if you can find the post that I couldnt, I would REALLY appreciate it...
I need a harness that plugs into the OEM wiring harness that will turn on my halo's every time the car is started/running (like DRL) and allow me to leave my headlight switch in the "auto" setting.
All I want to do is make my Halo's turn on anytime the car is on, without having to "turn the knob"... I dont care if they are somehow connected to the DRL and the DRL stay on all the time (that would actually be preferable) I just know I want my Halo's on all the time.
Why have them if I cant show them off?
Does someone sell a harness? I dont need a bunch of options, I just need the Halo's on ALL the time.
Thanks!
-Ryan
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 07-28-2010, 10:57 PM   #2
Kreature
Kreature's Avatar
Drives: Summit White 1LT/RS
lol is this a joke? but what ever. Theres a turn knob on the left side of the steering wheel, i believe if you turn it once to the right it will keep your halos on, just dont forget to turn it off after your done.
Kreature is offline   Reply With Quote
Old 07-28-2010, 11:04 PM   #3
Zalirid
Drives: CGM 1LT RS
Yep, the knob does it one turn right is halos, 2 turns is halos and hids....there are harnesses availiable, one on here is around 70 for a wired harness that will keep halos on with drls...just depends on what route you want to go, money or no money spent. The car will beep at you if you dont turn the knob back to auto when its off and the door is open, like pretty much any other car. I turn mine on because parking in the garage I do not like my hids going on than off for a minute or so each time I pull in and out.
Zalirid is offline   Reply With Quote
Old 07-28-2010, 11:09 PM   #4
Topdown
The wait is over!
Topdown's Avatar
Originally Posted by Kreature View Post
lol is this a joke? ... just dont forget to turn it off after your done.
No, not a joke...
maybe I should have been more specific... hows this:
Does that make it more clear and less joke-like?
Ordered - 4/17/2010
Old 07-28-2010, 11:11 PM   #5
Topdown
The wait is over!
Topdown's Avatar
Do you know who makes the harness?
I have seen harnesses that turn DRL into always-on, but havent found one that makes the Halo's always-on WITH the DRL.
Ordered - 4/17/2010
Old 07-28-2010, 11:14 PM   #6
christianmotox
christianmotox's Avatar
Drives: 2010 Silver LS (sort off)
I did mine the the old and cheap way. i just ran a cable to the ignition fuse on the fuse box, so when ever i turn the key the Halos come on.
The last cable of the harness is the Halo, and it already has ground from the OEM harness.
It took like 10 minutes and it cost nothing.
christianmotox is offline   Reply With Quote
Old 07-28-2010, 11:14 PM   #7
cybercoaster
cybercoaster's Avatar
Drives: '12 ZL1 AGM
Start here http://www.camaro5.com/forums/showthread.php?t=95273
Plasma DRL, footwell LED, Technostalgia taillights
cybercoaster is offline   Reply With Quote
Old 07-28-2010, 11:16 PM   #8
Topdown
The wait is over!
Topdown's Avatar
Originally Posted by cybercoaster View Post
I saw that thread, but it sounds to me like that harness turns the DRL on ALL the time, not the halo's
Just so everyone is on the same page with this wired harness your drl lights will always be on when your headlights or halos are on, you will not be able to turn them off at night if your headlights or halos are on. This is the same way the other vendor harness operates
Ordered - 4/17/2010
Old 07-28-2010, 11:18 PM   #9
Topdown
The wait is over!
Topdown's Avatar
I am almost ready to do that... I was just hoping to not have to cut/splice the OEM harness if I could avoid it, but I DO appreciate you letting me know which wires to splice, that will make things easier if I cant find a harness. thanks!
Ordered - 4/17/2010
Old 07-29-2010, 12:25 AM   #10
bobby35ny
bobby35ny's Avatar
Drives: 2010 2SS/RS M6 R6P
I requested this many times in other threads, nothing out there right now does what we want.
I too want to ditch the DRL's and light up the halos without using the knob, no luck
-bobby
Gone 12.28.12 Lets see if and when a Z-28 gets done.
J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-29-2010, 06:58 AM   #11
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
-bobby
Why don't you run the DRL hotwire to the halos and the halo hotwire to the DRL's?
Hylton is offline   Reply With Quote
Old 07-29-2010, 09:49 AM   #12
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT (2SS/RS)
If you're looking to have the halo's on with the DRL's everytime you start your car, you're going to need to splice/tap into wires. Find the blue wire at the DRL and connect with the purple wire on the drivers side and do the blue wire at the DRL and brown on the passengers side. So its one connection per side. Hope this helps.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 07-29-2010, 10:04 AM   #13
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
I can make a harness but it is going to cost a little more than what I am charging for the others I'm selling because it will require more GM factory plugs and another relay, possibly two. But these would be on a one by one basis and you can't expect to get them right after you pay. I would have to order the parts and redesign my harness so that everything is still plug and play.
fieldgoal00 is offline   Reply With Quote
Old 07-29-2010, 03:26 PM   #14
Topdown
The wait is over!
Topdown's Avatar
that sounds relatively straight forward... I will take a look tonight.
Thanks!
Ordered - 4/17/2010
Old 07-29-2010, 03:27 PM   #15
Topdown
The wait is over!
Topdown's Avatar
No problem, if you can get me (us) a quote for the harness and a (very) rough estimate on time, that would be great.
Ordered - 4/17/2010
Old 07-29-2010, 03:28 PM   #16
fieldgoal00
PM me and we can discuss via PM's we aren't in the vendor section so I don't want to really talk prices in this thread
Old 07-29-2010, 03:35 PM   #17
Topdown
The wait is over!
Topdown's Avatar
Thinking about this more... would there be any feedback issues between the DRL system and the headlight system?
Since the DRL turn off when the HL turn on, there shouldnt be an issue, other than the DRL will then be powered by the Halo's when the headlights are on and the other-way around when the headlights are off.
I suppose if I change out the DRL bulbs with LED's the draw would be reduced so much that it probably wouldnt be an issue... I just would hate to burn anything out.
Ordered - 4/17/2010
Old 07-29-2010, 03:36 PM   #18
Topdown
The wait is over!
Topdown's Avatar
ooh sorry... will-do.
Ordered - 4/17/2010
Old 07-29-2010, 03:36 PM   #19
AACstyle
C5 Lighting Specialists
AACstyle's Avatar
Drives: www.CamaroLighting.com
If anyone can do it Jeff can
AACstyle is offline   Reply With Quote
Old 07-29-2010, 03:37 PM   #20
fieldgoal00
There may be a feedback issue especially if you just splice the wires. None of my harnesses will ever have feedback issues based on the design I use to power the lights
Old 07-29-2010, 03:37 PM   #21
fieldgoal00
Thanks Justin
Old 07-29-2010, 03:41 PM   #22
Topdown
The wait is over!
Topdown's Avatar
PM Sent... I think I have a plan of attack... but want to get your feedback, you have 1000000000000 times more experience in this than I do.
Thanks!
Ordered - 4/17/2010
Old 07-29-2010, 03:43 PM   #23
Kendell347
Doc
Kendell347's Avatar
I have LED's (P13W's) from AAC and have the car wired up this way, I haven't had any issues and if anything I get compliments for the way the car looks.
See pic below, ignore the driver's side projector reflection / glow.
Old 07-29-2010, 03:59 PM   #24
Topdown
The wait is over!
Topdown's Avatar
that's exactly what I am looking for!
that's a good lookin ride you got there!
Ordered - 4/17/2010
cant find it - Halo's on with DRL - "auto-on" - can it be done? Topdown Cosmetics and Lighting Modification Discussions 18 06-01-2010 12:34 AM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 08:39 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
Those WITHOUT the Halos? caverman 5th Gen Camaro SS LS LT General Discussions 43 08-27-2009 03:32 AM
Non-RS Headlight HALO's available(Entire Headlight with Halo's) CustomCarWorx Exterior Parts & Accessories 29 08-16-2009 11:04 PM
