Gen5DIY
Old 07-29-2010, 11:56 AM   #1
ffrcobra_65
Who is suffering or suffered from Engine Rear Cover Leak
Service Bulletin: #05-06-01-034K: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L-Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Apr 8, 2010)
Condition
Some customers may comment on an engine oil leak.
Cause
Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only.
The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Engine cover MOD d69chris Camaro DIY & HOW-TO instructions & discussions 50 01-11-2013 02:17 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
ENGINE COVER "SS" RED EMBLEM & POLISHED STAINLESS NAMEPLATE Kirban Performance V8 Bolt-Ons & Tunes 0 03-04-2010 01:43 PM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
