BeckyD @ James Martin Chevy
Old 07-30-2010, 02:47 PM   #1
Black on Black
Smokin Bowties Member
Black on Black's Avatar
Drives: 2010 Camaro 1LT/RS
V6 dyno results
Please only post actual dyno result here for the V6. Also please list any mods used to achieve this.
Black on Black is offline   Reply With Quote
Old 07-30-2010, 02:54 PM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
This was with SLP blackwing cai, ARH headers, MRT V2 axleback (no tune )
ROD1 is offline   Reply With Quote
Old 07-30-2010, 03:09 PM   #3
Black on Black
Hey ROD1 your car has the same birthday as my wife!!
Old 07-30-2010, 03:18 PM   #4
SDCamaro10
SDCamaro10's Avatar
Drives: 2010 Camaro 1LT RJT
Just so you know, theres already a thread with this info. Check it here: http://www.camaro5.com/forums/showthread.php?t=44635
Side note, heres my dyno sheet. A6, Injen, Magnaflow x-pipe, magnaflow axleback.
SDCamaro10 is offline   Reply With Quote
Old 07-30-2010, 04:36 PM   #5
KMPrenger
KMPrenger's Avatar
The two above are perfect example of how different dynos, dyno setup, and weather can play into the power readings.
ROD1s car with LT headers, intake and exhaust, is pulling a fair amount lower TQ and nearly equal horsepower, than SDcamaro's which basically has intake and exhaust.
But we all know ROD1 ran a high 13 1/4 mile pass while N/A....so don't believe everything the dyno tells ya lol.
Old 07-30-2010, 04:48 PM   #6
SDCamaro10
SDCamaro10's Avatar
Very true. I havent had the chance to run at a 1/4mile track. But yes, each car is different from the factory, some come with higher stock numbers then others. But even so, weather, humidity, heat, and numerous other conditions can affect the way the numbers turn out. Not every dyno will give you the same numbers either. Even though his numbers and mine are very close, I would be willing to bet his numbers on the track will be, maybe not too significantly, but definitely better than mine.
I really want to get to a track and see what my numbers would look like.
Old 07-30-2010, 10:28 PM   #7
kga10734
Don't Feed the Troll
kga10734's Avatar
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
WOW!
That would make your wife only about 16 months old.
kga10734 is offline   Reply With Quote
Old 07-31-2010, 04:39 PM   #8
Black on Black
Originally Posted by kga10734 View Post
WOW!
well she is younger than me
V6 Dyno results collection HannoverFist Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 42 02-01-2011 07:01 PM
Airaid Version 2 tube Dyno Results devildoc Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 89 06-11-2010 10:40 PM
Latest dyno results are in! Huggerorange73 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-28-2010 08:02 PM
baseline dyno results blueallie 5th Gen Camaro SS LS LT General Discussions 13 02-16-2010 03:09 PM
Texas Speed Cold Air Install Dyno Results gomer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 01-26-2010 10:42 PM
