Centerforce Clutches
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 07-30-2010, 03:42 PM   #1
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
Vector Motorsports Stage 2.5 cam kit installed! pics and video
Hey guys,
I've got a big 'ol smile on my face after the Stage 2.5 cam kit was installed from Vector Motorsports this week. Just picked up the car today. Got a little preview of what it sounded like last night though and I was pretty anxious to drive it! My mechanic Tommy at T&L automotive once again did it right and put in the new cam and all the hardware. The cam is a Comp cam 227/239 on 114 and it's moderately aggressive I'd say. It came with dual valve springs, hardened pushrods, and titanium retainers. All for less than $1k. It's a pretty detailed install taking a full 2 days with all the components that have to be removed, radiator, fluids flushed, put back in, etc. You can expect to pay for about a 16 hour install if not doing it yourself. The most time consuming part of the install is the valve springs. I got a nice little break on the price since I get all my work done there and did the sway bar install at the same time, so paid around $1100 altogether for the cam and sway bar install. I wasn't able to get a side by side comparison of the stock and new cam unfortunately.
The sound is awesome and truly sounds like an old muscle car with a big block. Now mind you, it already sounded pretty darn good (and loud) with the K&N intake, DT headers, SOLO hiflow cats and Magnaflow exhaust. So if you are just replacing the cam, it may not neccessarily sound the way mine does. The cam really didn't make mine too much louder at idle, but definitely on hard acceleration
RPMs fluctuate a couple of hundred idling. If you run the A/C, you'll notice it more. Got a good shake to the engine! Just in driving the car back, got all kinds of looks and thumbs up. At idle of course, it's most noticeable. People know you have something lurking under the hood. Good thing is that cruising, especially on the interstate the sound and ride quality is really no different than before. I took a video of it the car this morning so you can hear it at idle and a few revs. Open it up WOT, and hold on to your pants!! the increase in throttle response especially between about 3000 and 5000 rpms is an eye opener. Claims of 50 rwhp/rwtq gains? I believe it and maybe more. The 'ol butt dyno doesn't lie, but I'm getting it on the dyno and running the HP tuning program on it tomorrow morning which is supposed to be a lot cooler and drier than my last dyno run.
CEL light? yes, had a code 300 misfire but that is taken care of for now and we'll check it on the HP program. Make sure you bleed the fluids well, had to get the air out a couple of times in the power steering fluid, but is nearly back to normal now and the smoothness of the power steering will come back in time as any small amount of air works its way out. Since the line runs around the front through the condenser, there is more travel and more places for air to stay.
I've got a feeling the fiance won't like to ride in the car as much now with the rougher idle! but hey,that's ok, then I can play a little more often since I won't have to baby it when she's not riding with me!
Photos and video are attached. I don't know it Tommy is trying to tell me something with the photo of the cam with the BC headache powder was a headache to install or maybe it's just for scale!
If anyone can imbed the video, that would be great. The video does not do the car justice. You really have to be there. It shakes the house
Thanks Vector Motorsports, Comp Cams, and T&L Automotive!!
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 07-30-2010, 04:53 PM   #2
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
Can't wait to see your #'s.
RobertHarriSS is offline   Reply With Quote
Old 07-30-2010, 05:28 PM   #3
69lt1bird
69lt1bird's Avatar
Drives: 1969 Pontiac Firebid
These specs are getting pretty popular.
13017 - 227 .614
13020 - 239 .624
114 + 4
I am guessing 457 rwhp 430 rwtq
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler
1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
69lt1bird is offline   Reply With Quote
Old 07-30-2010, 07:21 PM   #4
topgun1
topgun1's Avatar
Well, looks like I'll have to wait longer for the dyno. Dyno shop had an issue with a guy's radiator hose exploding all over the place and got coolant on his computer. the software's not working right now and he may also have to get a new tower. so looks like I won't be off to the dyno in the morning :( It'll have to be a few weekends from now because I have something planned for the next two. I was really hoping for tomorrow since the temp will be down in the 80's with low humidity. Last dyno session it was up over 100 with high humidity. I'm definitely anxious to get it on the dyno and tuned up! I'll keep you guys posted.
13017 - 227 .614
13020 - 239 .624
114 + 4
yep, they seem to be. Mine is 227 .613 239 .623
that's a pretty good guess on the numbers. I was thinking somewhere b/w 450-460 rwhp and about the same on rwtq. But it'll have to wait
Old 07-30-2010, 07:44 PM   #5
coptzr
Resistance is futile
coptzr's Avatar
Drives: Anything thats fast
I have the same cam package in mine. You will really need to get the tune in it or at least some idle parameters.Call Kirk at Vector, he is "the man".Mine idles around 850-900 now and wont stall when coming to a corner.Plus the idle sounds "snarly" at 900 rpm.Your idle seems quite low. I also have the K&N intake but with LT's from SLP and gmpp mufflers. Was gonna take it down in the next week or so for the full dyno treatment, BUT the Edelbrock E-Force is on the way!! I'll post everything when she's done.You will love this package, drive very stock and makes GREAT power over stock.ENJOY!!!
Modifications (so far)
Edelbrock E-Force supercharger
JRE fuel system upgrade
Edelbrock CAI
VMS stage 2.5 cam kit
SLP LT's w/cat's
NPP muffler's w/x-pipe
Tuned at Vector Motorsports
606 RWHP and 567 RWT
Black 1LE 10 spokes.
Hotchkis drop springs.
coptzr is offline   Reply With Quote
Old 07-30-2010, 09:19 PM   #6
topgun1
topgun1's Avatar
Yep, definitely getting it tuned, it does idle low and has cut off a couple of times, mainly in reverse. I want to get it to idle a little higher and maybe a little smoother if I can.
thanks, I will for sure be enjoying it! can't wait to get it on the dyno and tuned
Old 07-31-2010, 12:21 AM   #7
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Grats! This is the cam I was planning to go with.
wbt is offline   Reply With Quote
Old 07-31-2010, 08:14 AM   #8
ssmike
BLACK is the new Chrome!
ssmike's Avatar
Drives: 2010 2SS/RS RJT M6
Nice job! Sounds sweet! Nothing like that good 'ol cam idle lope! Good post!
Old 07-31-2010, 09:58 AM   #9
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
curious on the numbers you hit with shortys on pushing that cam
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 08-01-2010, 07:36 AM   #10
Shifted Perceptions
Shifted Perceptions's Avatar
Drives: 2010 SS
sound great, it'll be a different car again after you get it tuned! Just curious why the shop that did the install removed the intake manifold?
Shifted Perceptions is offline   Reply With Quote
Old 08-01-2010, 08:17 AM   #11
topgun1
topgun1's Avatar
you know, that's a good question. I didn't really realize that until you mentioned it that. I assume for clearance for working on the valvetrain.
Old 08-01-2010, 01:02 PM   #12
Shifted Perceptions
Drives: 2010 SS
Really not necessary at all, I have to assume the tech didn't know you couldn't access the lifters from there like a conventional older small block. Just thinking it might have added to the labour and parts a little, just unnecessary that's all. Other than that, sounds great, and after it's tuned should be a monster.
Old 08-02-2010, 02:29 AM   #13
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
Sweet. Glad to hear you got your cam!
Bonemaro is offline   Reply With Quote
Old 08-03-2010, 09:42 AM   #14
Steve@Vectormotorsports
Drives: Firehawk
Drive it on over and I'll tune it glad your happy so far wait till its tuned!
If you have a power cal cable I can send you a calibration that will get you very close.
Steve@Vectormotorsports is offline   Reply With Quote
Old 08-03-2010, 09:12 PM   #15
topgun1
topgun1's Avatar
that was exactly what happened, he didn't know at first, but when he got it off, he said he sure wasn't going to put it back on until he was finished! provided some more work area for sure. Well, he cut me a good break since I'm a repeat customer
Old 08-03-2010, 09:15 PM   #16
topgun1
topgun1's Avatar
Haha, just a little too far of a drive! yep, just waiting patiently for the tune. Dyno tuning shops are few and far between in NC and only go to one guy. I don't have a power cal cable, but should be able to get it tuned right with the HP tuner on the dyno. But I'll check with my dyno guy and maybe you could send the calibration to him. Main thing is I want to change the idle parameters to idle up a little higher. it's only idling around 500-600 rpms right now.
but i'm really happy with it so far and have gotten quite a bit of looks and questions on it, especially at stop lights!
Old 08-04-2010, 04:24 PM   #17
Bonemaro
Bonemaro's Avatar
Old 08-04-2010, 06:32 PM   #18
SK360
Drives: 2005 Pontiac GTO
Congrats!
Almost the same camshaft I am running with my LS3 head conversion on my LS2, lobes are the same, I have more advance ground in.
I love it, sounds awesome and makes good power.
Dyno graphs through an automatic... locked converter vs unlocked. It would have made a few more HP on the locked runs but the converter was letting go up top. Your numbers should be higher due to the 6 speed and the extra cubes
This is idling at 750rpm through a magnaflow catback... I hate the way it sounds at idle through the magnaflow, I am swapping it out to a Corsa sport next month to solve this problem
SK360 is offline   Reply With Quote
Old 08-05-2010, 06:10 AM   #19
topgun1
topgun1's Avatar
NICE! I actually like the way yours sounds. You know I have the Magnaflow catback too, but my sound difference may be due to the hiflow cats, which really changed the sound of the exhaust. That's impressive numbers too. Yeah, it would be great if I could gain a little more than that!
I like your idle speed more, and will probably adjust mine to about 850 rpm. It's just too low right now.
Off the subject, I met a guy the other day that just moved from CA and had a car almost like yours, blacked out GTO with a nice exhaust system but it was the one with the hood scoops and the 6.0. I told him all about the website and to check it out, that there were GTO, T/A , Vette, and other owners and car enthusiasts. He heard my car coming through the parking lot at the grocery store and as soon as I got out he said "ok now, what size cam you got in there?" and i said to my fiance, "see Holly, he knows what's up!"
Old 08-18-2010, 07:26 PM   #20
topgun1
topgun1's Avatar
finally getting the car back on the dyno this saturday the 21st to get the cam tuned in with the HP, some adjustments to the idle speed and a/f ratio, should be running alot smoother. Pics, vids, and graphs to come!!
stay tuned
Old 08-21-2010, 08:49 PM   #21
topgun1
topgun1's Avatar
didn't happen today, delayed til next saturday, some tuner issues.
Old 08-21-2010, 10:24 PM   #22
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Sounds great and the pics you posted are great! Thanks for sharing.
CamaroFTW is offline   Reply With Quote
Old 08-23-2010, 12:55 PM   #23
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
congrats! You simply can't go wrong with that cam and Vector. I'm hoping to get mine back early next year (after the MI. thaw) to Vector for the maggie install.
KMSRS2SS is offline   Reply With Quote
Old 08-28-2010, 06:43 AM   #24
topgun1
topgun1's Avatar
thanks guys. man, it feels like i'll never get the car back on the dyno. new tuner guy at the shop and last night he had a family emergency, so got back real late, so not happening this morning. I am "guaranteed" next saturday morning the 4th, so we'll see how that goes.
Old 08-28-2010, 02:31 PM   #25
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I'm curious why you went with shorties...sick car though!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
