Emblempros
Old 07-31-2010, 09:42 PM   #1
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
High RPM smoke
Ok guys I need some help.
Ok just got done getting my cats removed like 45 minutes ago.... Must say it sounds awesome!!! Only down side if when you get the rpms over 5K and let off the throttle uy poors smoke out , didn't do that before. You can smell fuel really bad. I was thinking we might have messed up a oxygen sensor or I have bad gas? Performance is way down like 0-50 in 9 seconds. I'm stoked on what it would be. And really need help. Only mods are a 228R cam, muffler delete, dyno tune and now no cats.
WICKEDSS is offline   Reply With Quote
Old 08-02-2010, 08:29 AM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
So what did they put in place of the cats? Straight pipes? It's probably just the oil residue on the inside of the new pipes burning off. Give it a couple of miles...
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 08-02-2010, 08:40 AM   #3
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
They just removed the guts the shells are still there just empty..... What gets me is it only does it when you take your foot off the throttle
Old 08-02-2010, 11:33 AM   #4
Hicompression
Rumbly Bumble Bee
When letting off of the throttle, vacuum is at it's highest. You are probably sucking oil into the air intake system from the line that runs from your intake elbow to the top of the passenger side valve cover. A lot of people run an oil "catch can" to eliminate this problem.
-OBX Longtubes FTW!
Old 08-02-2010, 12:39 PM   #5
ffrcobra_65
no cats = what you are experiencing.
Old 08-02-2010, 02:30 PM   #6
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Ok and a drop in performance is normal at first? Guess the ECM needs to make adjustments
Old 08-02-2010, 03:38 PM   #7
ffrcobra_65
you might need to retune.
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
2011 Mustang Info (Keep all threads here) RealQuickCamaro General Automotive + Other Cars Discussion 2648 04-15-2010 09:09 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Will The Z28 Be as Powerful as The SS? Oracle646 Camaro ZL1 Forum - ZL1 Specific Topics 43 07-04-2009 03:16 PM
2010 camaro High RPM Rev VID 5th_GEN_SS Camaro Photos | Spyshots | Video | Media Gallery 8 02-23-2009 12:00 AM
