Old 08-02-2010, 12:23 AM   #1
fearless
Drives: 2010 camaro 1ss grey/black
Clank noise when I enguage clutch.
I have a 2010 1ss M6 and I just drove it 1k miles to Tucson AZ. on the way to Vegas and It seems to be making a weird noise when I engage clutch taking off in first gear.
Almost like the drive shaft could have slop in it I feel it in shifter also but only If i take off slow. If I give it decent amount of throttle it isnt doing it. It happens right when I release clutch. I am worried becuase I am a long way from home going to into Vegas tomorrow and see if contact a dealer. Anybody have similar problems?
fearless is offline   Reply With Quote
Old 08-02-2010, 12:28 AM   #2
Big J
Big J's Avatar
Drives: 2010 Camaro 2ss/rs ls3
I got a 2ss m6 and it does the same thing in first gear i have put 2200 miles on it and hasn't affected the car at all
Big J is offline   Reply With Quote
Old 08-02-2010, 08:25 AM   #3
fearless
I am not sure how long its been doing it I usauly have music playing or dont take off real slow I noticed it in a parking lot having to stop and go a few times maybe its normal and just the sound the clutch makes but it seems to have a hair of slack even if its fully in engaged in first gear like if you burp throttle almost like sloppy drive shaft or a possible U joint problem you can deff feel it in the shifter its most likely fine I guess.
Old 08-02-2010, 08:52 AM   #4
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
I think it's normal from what I've read . . . something about driveline slack
OUTATIME is offline   Reply With Quote
Old 08-02-2010, 12:36 PM   #5
ffrcobra_65
normal.
Old 08-02-2010, 12:46 PM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I have that too, damn that driveline slack!
Old 08-04-2010, 11:45 PM   #7
camarogolfguy
Camarogolfguy
camarogolfguy's Avatar
Drives: 2012 ssrs
This question has been asked and answered by those in the know on this site many times. I had the same concern and still do to this day after 8,600 miles. I even get it some times between 5th and 6th gear. They say its normal. I still don't think clunks are normal. Even two dealers told me its normal. Thats why we have a 5yr 100,000 drive train warranty I guess. Not to worry.
camarogolfguy is offline   Reply With Quote
Old 08-04-2010, 11:45 PM   #8
camarogolfguy
Camarogolfguy
Drives: 2012 ssrs
Nice car Paul SS.
Old 08-06-2010, 09:20 PM   #9
CHEROB10
CHEROB10's Avatar
Drives: 2012 2LT Synergy
I have it too...it comes and goes.
"If A equals success, then the formula is: A = X + Y + Z. X is work. Y is play. Z is keep your mouth shut." -Albert Einstein
CHEROB10 is offline   Reply With Quote
Old 08-06-2010, 11:53 PM   #10
usmcjlp
Drives: 2SS/RS LS3 RJT
Yeah if you never mod it. This is supposed to be american muscle. Retune your computer and see how well they support that warranty.
usmcjlp is offline   Reply With Quote
Old 08-09-2010, 10:20 PM   #11
mcarney
mcarney's Avatar
Drives: SSRS CGM LS3
Can someone explain driveline slack
When you're really good in a past life, you come back as yourself
mcarney is offline   Reply With Quote
Old 08-10-2010, 03:38 PM   #12
Ronn
Ronn's Avatar
Drives: 2010 Camaro
I get a similar noise when I'm in first gear, car is idling along at 2-3mph at 1100rpm. If I engage the clutch I get a little clunk. Dealer said this is normal operation.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 08-30-2010, 03:04 PM   #13
bob2010ss
bob2010ss's Avatar
Drives: Turbocharged 2010 SIM 2SS LS3
not normal
mine started at first to happen when disengaging clutch in first or reverse you would hear a clank/clunk
8 days later same thing but also when you shift 1st to 2nd
went to my dealer
they told me there is a tsb for this and they had to order a wash to shim the axle too much play and when the torque hits it :clank:
mine is going in next week to repair
bob2010ss is offline   Reply With Quote
Old 08-30-2010, 08:18 PM   #14
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
There are several different noises. The axles clicking in the back are not normal, and you can recreate that noise without the clutch. When you get on the power, and here a click click ( one click out of each side of the rear), that's the axle issue on early built cars that the spacer fixes.
Real low speed parking lot type driving, sometimes turning a little bit... popping the clutch in and hearing some clunks... that's the normal driveline slack. The G80 LS diffs add to it a bit by adding a little drag during turns as the clutches back there are slip/sticking. As the LS additive wears out, it can become more noticeable.
Change the rear diff lube, do 10 low speed figure 8's in a parking lot, and it often makes low speed turns less clunky/jerky when popping the clutch in. Every gear in the driveline has to have a clearance. When you release the clutch, your taking the load off the driveline quickly and the clearances can clunk. An LS diff that the clutches are dragging a bit from the additive wore out, can put a little more bind in the driveline that really clunks when you push the clutch in.
If your car has gotten annoying clunky in low speed parking lot type driving, try changing your rear diff lube and do the 10 low speed figure 8's.
Clutch noise. luisgayoso V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 06-23-2010 06:18 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Heads Up - Clutch Spring noise ffrcobra_65 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 11-22-2009 10:04 AM
Clutch Noise? GLBL WMR V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 05-24-2009 01:04 AM
