Flowmaster Exhaust
Old 08-03-2010, 01:20 AM   #1
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Red face Do you have to get new struts if you get lowering springs?
Im looking into getting a set of lowering springs but just wondering if i had to also get new struts since im going with a lower spring. Can anybody answer that question for me. Will i have any strut failure after a while. Im leaning towards hotchkis.
BAWLZ SS is offline   Reply With Quote
Old 08-03-2010, 01:41 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
No. You use your OEM struts. I don't think anyone makes aftermarket struts yet. I haven't heard of a rash of strut failures yet.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-03-2010, 01:45 AM   #3
BAWLZ SS
BAWLZ SS's Avatar
Cool
Thanks i appreciate the info. Any knowledge or preference on any particular brand of springs u recommend. Hotchkis vs. Pedders vs. Pfdat?
Old 08-03-2010, 01:57 AM   #4
axis
Search Ninja
axis's Avatar
That is something that everyone will debate. I think the top 2 are Pfadt and Pedders. Hotchkis and BMR are probably pretty close, although I haven't heard much on them since their springs are just now hitting the market. I'm just going by their name and quality with the parts that they have out now. Eibach would be next on the list with H&R and Vogtland bringing up the rear. When mine goes down, it will be either Pfadt or Pedders.
Halltech CF 102 fed
Old 08-03-2010, 06:13 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
What he said. You really have no choice and there isnt any reason you can't or shouldn't use them.
Old 08-03-2010, 09:56 AM   #6
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
The springs from most manufacturers were in fact designed to work 100% properly with the factory strut. Most springs have properly engineered springs rates which create a minimal increase in wear on the strut, as well as the travel on the strut is still with in its designed region.
Unfortunately there are not manufacturers that produced struts for the car yet, however I know many will release very soon.
If you have any further questions let us know.
Regards
IPS Brandon is offline   Reply With Quote
Old 08-03-2010, 12:17 PM   #7
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
The shock valving for the most part is actually pretty good on this car unless you go too low. As long as you don't lower it too far (below 1.4") the OE shocks will be fine dampening the higher rate lowering spring.
BMR guy is offline   Reply With Quote
Old 08-03-2010, 12:17 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
When lowering springs are installed they should not cause strut failure. Strut failures from lowering springs occur when the new spring with cut bumpstop allow too much travel resultiing in damage to the foot valve. I am not aware of ANY issues like this to date on the 5th Gen with lowering coils. That means you'll have to choose among a number of quality brands with no worries.
So many choices and so little time.
Old 08-04-2010, 12:56 AM   #9
BAWLZ SS
BAWLZ SS's Avatar
Thanks appreciate the info!
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
Eibach Lowering Springs & Sway Bars @ Phastek Performance Jason@Phastek Performance Suspension / Chassis / Brakes 0 01-29-2010 04:56 PM
