sjm autoprod
Old 08-03-2010, 06:01 PM   #1
sparaz
867-5309
sparaz's Avatar
Drives: 2010 CMG RS & 86 black Z28 3rd gen
RPM oscillation between 1800-2700 RPM
My car's RPMs jump up and the power radically shifts upward eratically when in 3rd to 6th gear from the top end of the 1k's to the top end of the 2ks and then doesnt seem to be as defined past that range in any gear (it may be prevelant in 1st and 2nd but those gears go by so quick its not an issue).
If I am just floating on a straight road at the same speed in that range it shifts slightly but not much, but the minute I give it more peddle pressure the shift goes up and down erratically. Additionally, if i'm in cruise control at that range and I go up a slight incline where the system has to add power to keep at speed... the cruise control will shut out if the power spikes hit it just right.
Extremely annoying and it makes it sound like the car is revveing higher while in gear randomly... It's almost embarassing when getting up to speed in an area. Anyone have a clue what this could be?
I have recently had this issue appear out of nowhere and it does not trigger the CEL... The dealership is telling me to wait till next week when they are not busy as on the saturday I tried to take it in they couldn't figure it out though they drove it with me and agreed that it was happening.
sparaz is offline   Reply With Quote
Old 08-06-2010, 05:19 PM   #2
HBMike
HBMike's Avatar
Drives: 2010 Synergy Green HBR
Possible vacuum leak, poke your head under the hood and see if you hear a hissing noise from any hoses.
Wilwood 6 Pistons -Magnaflow X-Cat back - CDC Havoc Styling - TSW Wheels - Roadwire Custom Green Leather Interior - Hotchkis Race Suspension - Whiteline Flatout - KW V3 Suspension - 3M Wraps - Toyo Tires - IPF Supercharger - Vortech V3 - Airaid Filters
HBMike is offline   Reply With Quote
Old 08-08-2010, 02:55 AM   #3
sparaz
867-5309
sparaz's Avatar
Should I be able to hear it while it's idle? Will try it out tomorrow, thanks.
Old 09-27-2010, 10:24 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Wouldn't a vacuum leak throw a code?
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 81 07-01-2016 10:00 PM
RPM Automotive Festival - Chicago, IL - 7.10.2010 rpm2010 USA - Great Lakes 1 06-29-2010 08:58 PM
We may just have an FI option.... devildoc Forced Induction - V6 30 06-23-2010 07:22 PM
2011 Mustang Info (Keep all threads here) RealQuickCamaro General Automotive + Other Cars Discussion 2648 04-15-2010 09:09 PM
Exhaust whine at 1800 RPM GMSPOON Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 10-29-2009 12:27 PM
