Solo Performance
Old 08-06-2010, 02:14 PM   #1
Cal 20112SS
Drives: 2011 2SS/RS
Open and close window?
Anyone else get this message on their DIC? Itís my third time.
The driver side window is not closing all the way and stays open about a quarter inch. When I open the door to exit I noticed itís lowering a bit more than normal then it has to raise itself a lot more to close. So it just gives up mid way and stays open
Cal 20112SS is offline   Reply With Quote
Old 08-06-2010, 02:17 PM   #2
600hp-lpe
Drives: 2010
go to the dealer.
600hp-lpe is online now   Reply With Quote
Old 08-06-2010, 02:25 PM   #3
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
Your window(s) needs to be re-indexed.
Push down the window switch and hold for 5 seconds after the window is fully opened. Then pull up on the window switch and keep holding it for 5 aseconds after your window is closed. This should solve your problem. If not, see the post above.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 08-06-2010, 02:37 PM   #4
Cal 20112SS
Drives: 2011 2SS/RS
^ I'll give that a try. I also noticed the auto open/close feature does not work while it's displaying that message.
Old 08-06-2010, 03:46 PM   #5
xtreme industries
Drives: 2010 Camaro 2lt RS
i have had that message 3 times as well, i just play with the window until it goes away. but the procedure listed in a previous post sounds like a good way to fix it.
xtreme industries is offline   Reply With Quote
Old 08-06-2010, 03:48 PM   #6
Wild Bill
Wild Bill's Avatar
Correct, the auto feature should return and be ok after you re-index.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
Old 08-07-2010, 11:20 AM   #7
IcallitROOSTER
Drives: Black 2011Auto/v6 2LT/RS blackint
i had this same problem, and re index like the above stated, .................
Can this be caused by holding your button down too long when rolling down? I mean you know how all you have to do is tap it and it will go ALL THE WAY DOWN maybe this si being caused because we are holding the button too long to roll down?
IcallitROOSTER is offline   Reply With Quote
Old 08-08-2010, 12:14 PM   #8
Cal 20112SS
Drives: 2011 2SS/RS
Just got that Open then close driver side window message again. I did what Wild Bill recommended and it worked like a charm! Thank you!! Now I have to find out why it keeps happening.
Old 08-09-2010, 08:50 PM   #9
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
I just had it happen too. Did the reindex and all good now.
cybercoaster is offline   Reply With Quote
Old 08-10-2010, 10:12 AM   #10
Wild Bill
Wild Bill's Avatar
Glad I could help! I have had the car for over a year and I have had to re-index my driver window and the passenger window once each. I don't know why it happened though.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
Old 07-27-2013, 02:58 PM   #11
njweatherman
Drives: 2013 Camaro 2SS
Hey guys! I got the message, "Open, then close passenger window for the first time."
I only have 1500 miles on my 2013 2SS camaro. Has anyone mentioned this to the dealer?
njweatherman is offline   Reply With Quote
Old 07-27-2013, 06:10 PM   #12
Godon Hutchinson
Godon Hutchinson's Avatar
Drives: 2010 1SS/RS Imperial Blue Metallic
just reindex your windows
Godon Hutchinson is offline   Reply With Quote
Old 01-03-2014, 02:40 PM   #13
NorthRoutt
NorthRoutt's Avatar
Drives: 2013 1SS/RS LS3 SIM
This just worked for me. Got the message this morning and didn't know what to think. Found this thread on a quick search.
CAI Intake, Skip Shift Eliminator, Loud Mouth 1, Apex Scoop & W/W, Elite Catch Can, Vmax Ported TB
NorthRoutt is offline   Reply With Quote
How to RESET your Camaro Door Glass Window MEMORY TAG UR IT Camaro DIY & HOW-TO instructions & discussions 32 02-26-2018 05:22 AM
Minor Problem With My Window Indexing roadie2991 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 41 01-31-2011 08:11 PM
Camaro won't start unless door is open Evokatana Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 07-01-2010 07:50 PM
Auto Indexing Window Broken Gen5SSRS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 19 01-21-2010 07:29 AM
No Power to Driver's Side Window? 67 Convertible Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 11-19-2009 04:48 AM
