| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
![]() Drives: 2010 2SS Yellow Camaro Join Date: Jan 2010
Check engine light on
I got trouble with the codes 0172 and 0175. Told by the dealer first that was due to alcohol on the gas. Recommended me to change gas brand. I did and the light still on. Has anybody else got the same trouble and found the cause for it?
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
The 0172 and 0175 are banks 1&2 fuel systems rich.
Check out google. Common Problems That Trigger the P0172 and P0175 Code
Polluting Gases Expelled
The Basics Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1—14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture. Rich Mixture = Too much fuel, not enough air Lean Mixture = Too much air, not enough fuel To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel. The control module operates within specific parameters and under normal conditions, it will make minor adjustments to the air/fuel mixture. When these adjustments become too large, a fault code is set. When the P0172/P0175 code sets, the oxygen sensors are detecting too little oxygen in the exhaust and the control module is removing the maximum amount of fuel in its effort to maintain the proper air/fuel mixture. P0172/P0175 Diagnostic Theory for Shops and Technicians When a vehicle has the fault code P0172 and or P0175, it means that computer can no longer automatically adjust the mixture between air and fuel. Code P0172 applies to Bank 1 and P0175 applies to Bank 2. Code P0175 mainly applies to V6 or V8 engines because 4-cylinder engines generally have only one bank, though there are a few exceptions. Some of the high performance 4-cylinder and straight 6-cylinder engines (such as those in BMW and Lexus) split the cylinders into groups of two or three and call them separate banks. When the code says that the Fuel System is "too rich," it means that the computer has been subtracting more and more fuel, which is called Long Term Fuel Trim. Ideally, the Long Term Fuel Trim should be close to 1 to 2 percent. When a code P0172 is set, it means that the Fuel Trim is anywhere from -15 percent to as low as -30 percent compensated. When this happens, the computer knows that there is an improper condition in the control of the Fuel System. The first step in the diagnosis of a code P0172 and/or P0175 is to look at a minimum of three ranges of the Long Term Fuel Trim numbers on a scanner. Check the idle reading—3000 RPM unloaded and 3000 RPM with at least 50 percent load. Then check the freeze frame information for the code to see which range(s) failed and what the operating conditions were. Before we get into the main causes of P0172, let's explore why this code matters. Why Does a P0172/P0175 Code and Running "Too Rich" Matter? "Rich" running cars and trucks are highly polluting vehicles. CO pollution, which is poisonous and helps create ozone, is caused by vehicles that are running too rich. A rich condition can also cause misfires from "overfueling" (too much fuel for the Ignition Spark to burn), which puts raw fuel (HCs) into the atmosphere. When inhaled, these raw fuel droplets are very poisonous to living beings and contribute to the yellow/brown color in a polluted sky. When you are driving behind a "rich" running car or truck, it can smell very bad, somewhat like rotten eggs, and make you feel dizzy. This is caused by the Catalytic Converter consuming too much sulfur (part of vehicle fuel). However, it should be noted that a "rich" running engine can also have little or no smell, since CO itself is odorless. P0172 is not an Oxygen Sensor problem. Before a P0172 code is possible, the computer first ran a series of tests to validate the readings from the oxygen sensors. Since the oxygen sensors passed their readiness tests and didn't set any codes, the computer then looked to the Fuel Trim adjustment. When the computer determined the air-to-fuel mixture to be too rich, it then set the P0172 code. What Are Some Common Causes of Code P0172/P0175? Always check to make sure that there is not a PCM software update due or available. Often, as the vehicle's engine wears, the PCM's Fuel Map software inaccurately compensates for this condition. The fuel mixture grows rich and eventually, the code sets. An "over reporting" Mass Air Flow Sensor can be a common cause of a code P0172 and P0175. Essentially, this means that the Air Flow Sensor is telling the computer that much more air is entering the engine than actually is. Based on this large amount of air entering the engine, the engine computer or PCM sprays more fuel into the combustion chambers. Since the oxygen sensors are telling the computer that less fuel is needed, this causes confusion in the computer because the Mass Air Flow Sensor is still saying there is too much air and the Oxygen Sensor is reporting that the mixture is still too rich. The computer tried to compensate, but since resolution is impossible, it sets the code. It is important to restate that the Oxygen Sensors are accurate—the fuel mixture is too rich. In this case, the Air Flow Meter or Sensor is inaccurately reporting the real amount of air entering the engine. How Do I Know if the Problem Is the Mass Air Flow Sensor? There is a very effective "truth test" for any Mass Air Flow Sensor. Start the engine, let it idle, and then check the Barometric Pressure reading on the scan tool data. If the reading is about 34.5 Hg and you are close to sea level, you know that you have a defective Air Flow Meter because it is telling you that you are at about 4000 feet below sea level. (These conversion tables will help.) When the Mass Air Flow Sensor sees this Barometric reading, it adjusts its Air Density table and then "over reports" the actual amount of air entering the engine. It does this because the Barometric Pressure Sensor is actually part of the Mass Air Flow Sensor. Sometimes the Air Flow Sensor and the sensing wire get covered with dirt, dust, or oil residue, which can also set a P0172. Cleaning the sensor might hold off problems for a while, but eventually, the MAF sensor should be replaced. Always make sure the Air Filter and its enclosure are dirt-, dust-, and oil-free. If you clean and replace the filter and its enclosure as needed, you will prevent the new MAF from failing. Additional Causes of Code P0172/P0175
Thanks USA1camaro1969, I left my car at the dealer to check the problem. Good information I greatly appreciate. Have you heard if the Vortec Cyclone thing really work or can cause problems?is similar to the tornado thing. Suppose to help improve the mileage. Do you know if anybody has done test to confirm or denie their claims?
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
WOW, great information!
Fixed my problem with the engine light. I was trying a vortec cyclone(like the tornado thing) the instruction were saying to install it before the MAF and that was creating a wrong reading I guess. Remove the thing and installed the K&N filter back and car is running great again!!! Incredibly the mechanic at the delaer was blaming the K&N filter with the vortec. I got a little over 20k on my car!! tires still got a lot of tread left and I keep loving the car.
| Thread Tools | |
| check engine light with k&n cai | need4spd | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 16 | 08-02-2011 04:16 PM |
| check engine light question | shroomjohn | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 08-02-2010 01:25 PM |
| Will LT headers cause check engine light? | jpizzle007 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 06-03-2010 02:22 PM |
| P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 01:45 PM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
